Enilyks Neutral Newbie June 28, 2004 Share June 28, 2004 Can anyone enlighten me wats the difference between honda fit and honda jazz? nothing important, jus to ease my curiosity... ↡ Advertisement Link to post Share on other sites More sharing options...
DarkLord 1st Gear June 28, 2004 Share June 28, 2004 Hmmz, you can go to http://forum.sg-fit-jazz.com to look for the information! Link to post Share on other sites More sharing options...
Tien Neutral Newbie June 28, 2004 Share June 28, 2004 same. Jazz=Fit Fit is the JDM while Jazz is for export. Fits running in SG are imported by PI while Jazz is distributed by the authorised dealer. notice the red/ blue dot on the car? Red is 1.4L and blue is 1.5L... or is it the other way round? haahhaha Link to post Share on other sites More sharing options...
Enilyks Neutral Newbie June 28, 2004 Author Share June 28, 2004 ok sure thanks bro Link to post Share on other sites More sharing options...
Lightspeed Clutched June 28, 2004 Share June 28, 2004 You're correct. Red dot is 1.3L (M) or (A) Blue dot is 1.5L (A) 7-Spd CVT Link to post Share on other sites More sharing options...
Enilyks Neutral Newbie June 28, 2004 Author Share June 28, 2004 oh i see.. so both comes with manual transmission? Link to post Share on other sites More sharing options...
DarkLord 1st Gear June 28, 2004 Share June 28, 2004 No problem! Link to post Share on other sites More sharing options...
Dhti Neutral Newbie June 29, 2004 Share June 29, 2004 Posted: Sat May 15, 2004 4:30 pm Post subject: Differences between Fit1.3 and Jazz1.4 -------------------------------------------------------------------------------- Which to get huh?? Jazz or Fit huh?? If this is something bugging you, listed here are the contributions from all bros in identifying the differences between FIT 1.3 and JAZZ 1.4. No similiarities is reflected here. Jazz - Export purpose (EU) Fit - Domestic (Both made from Japan) Jazz - 83bhp Fit - 86bhp (different ecu programming) Jazz - side signal indicator Fit - no side signal indicator Jazz - rear seats only 1 angle Fit - rear seats 2 angles Jazz -to shift the seat forward lever at bottom of seat Fit - lever at shoulder to shift the seat forward Jazz - max speed on speedo is 220km/h Fit - max speed on speedo is 180km/h Jazz - master control for all door lock at the driver door Fit - to lock all door, need to push the lock down Jazz - air con is fitted locally Fit - air con fitted in japan Jazz - antenna at centre of roof Fit - at right side, need to extract manually Jazz - no factory fitted insulator for bonnet & firewall Fit - factory fitted insulator for bonnet & firewall Jazz - immobiliser key Jit - no such function Jazz - both sunvisor comes wif mirror Fit - only driver's side has Jazz - bigger front brake calipers Fit - smaller Jazz - aftermarket radio given Fit - integrated sound system, freq not tuned to local station, needs to install FM modulator Jazz - comes wif 4 speakers Fit - only front 2 Jazz - comes wif mug like ash tray/container Fit - doesnt have Jazz - when reverse gear engaged, no sound Fit - beeping sound when reverse gear is engaged Jazz - front seats cannot fold all the way down and flush wif the rear Fit - can bring down the front seats (w/o headrest) and flush wif the rear Jazz - horns are at the left side Fit - horns in the centre Jazz - factory fitted rear wheel arc inner fender cover(lower portion) Fit - dosen't come wif it Jazz - manual transmission option Fit - doesn't have Jazz - fuel lid is not locked, but fuel cap is locked. Fit - fuel lid is locked by cable operated Jazz - Boot cover & Boot light in Jazz Fit - doesnt have Jazz - comes wif 2 pin to secure floormat in place Fit - doesnt comes wif it Jazz - has MPH reading on speedometer Fit - only KMH Jazz - Slight tinting on all windows for EU specs Fit - JDM has rear heavy tinting which fails LTA specs. Jazz - 3 yrs warranty Fit - 1yr extracted from Fit/Jazz Forum Link to post Share on other sites More sharing options...
Luckcent 4th Gear June 29, 2004 Share June 29, 2004 Wow, you make a complete study of this car. Link to post Share on other sites More sharing options...
Dhti Neutral Newbie June 29, 2004 Share June 29, 2004 not really... but the piece of information is consolidated by all the Fit / Jazz lovers at http://forum.sg-fit-jazz.com Great Efforts by the bros! Link to post Share on other sites More sharing options...
Supermario Neutral Newbie November 17, 2004 Share November 17, 2004 Anyone knows what's the 0-100km/h timing for a FIt 1.5? Link to post Share on other sites More sharing options...
Ahhan7 Neutral Newbie December 7, 2004 Share December 7, 2004 if im not wrong it's abt 10.5 secs. Link to post Share on other sites More sharing options...
Bryanho Neutral Newbie December 20, 2004 Share December 20, 2004 Clap Clap!!! Very informative... Link to post Share on other sites More sharing options...
Antonee 6th Gear January 21, 2005 Share January 21, 2005 anyone own or seen a manual tranny jazz, is the gear stick greyish like the liteace van.. very ah pek[confused] hopefully...not hehe Link to post Share on other sites More sharing options...
Discoburg Supersonic January 23, 2005 Share January 23, 2005 Which to get huh?? Jazz or Fit huh?? If this is something bugging you, listed here are the contributions from all bros in identifying the differences between FIT 1.3 and JAZZ 1.4. No similiarities is reflected here. Jazz - Export purpose (EU) Fit - Domestic (Both made from Japan) Jazz - 83bhp Fit - 86bhp (different ecu programming) Jazz - side signal indicator Fit - no side signal indicator (New Fit now has) Jazz - rear seats only 1 angle Fit - rear seats 2 angles Jazz -to shift the seat forward lever at bottom of seat Fit - lever at shoulder to shift the seat forward Jazz - max speed on speedo is 220km/h Fit - max speed on speedo is 180km/h Jazz - master control for all door lock at the driver door Fit - to lock all door, need to push the lock down Jazz - air con is fitted locally Fit - air con fitted in japan Jazz - antenna at centre of roof Fit - at right side, need to extract manually (New Fit also centre) Jazz - no factory fitted insulator for bonnet & firewall Fit - factory fitted insulator for bonnet & firewall Jazz - immobiliser key Jit - no such function Jazz - both sunvisor comes wif mirror Fit - only driver's side has Jazz - bigger front brake calipers Fit - smaller Jazz - aftermarket radio given (New Jazz also integrated radio) Fit - integrated sound system, freq not tuned to local station, needs to install FM modulator Jazz - comes wif 4 speakers Fit - only front 2 Jazz - comes wif mug like ash tray/container Fit - doesnt have Jazz - when reverse gear engaged, no sound Fit - beeping sound when reverse gear is engaged Jazz - front seats cannot fold all the way down and flush wif the rear Fit - can bring down the front seats (w/o headrest) and flush wif the rear Jazz - horns are at the left side Fit - horns in the centre Jazz - factory fitted rear wheel arc inner fender cover(lower portion) Fit - dosen't come wif it Jazz - manual transmission option Fit - doesn't have Jazz - fuel lid is not locked, but fuel cap is locked. Fit - fuel lid is locked by cable operated Jazz - Boot cover & Boot light in Jazz Fit - doesnt have Jazz - comes wif 2 pin to secure floormat in place Fit - doesnt comes wif it Jazz - has MPH reading on speedometer Fit - only KMH Jazz - Slight tinting on all windows for EU specs Fit - JDM has rear heavy tinting which fails LTA specs. Jazz - 3 yrs warranty Fit - 1yr extracted from Fit/Jazz Forum Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie February 24, 2005 Share February 24, 2005 same. Jazz=Fit Fit is the JDM while Jazz is for export. Fits running in SG are imported by PI while Jazz is distributed by the authorised dealer. notice the red/ blue dot on the car? Red is 1.4L and blue is 1.5L... or is it the other way round? haahhaha Thought Jazz is from Thailand while Fit is from Japan? Link to post Share on other sites More sharing options...
Nickppt Neutral Newbie February 24, 2005 Share February 24, 2005 Dun think Honda make any of their car in thailand... JAZZ is japan made i believe... Link to post Share on other sites More sharing options...
Toalson 1st Gear February 24, 2005 Share February 24, 2005 There is a huge factory in Thailand that manufactures Jazz. But some say its only for their domestic market. But it is also seen regularly that truck loads of such Jazz being transported to the port. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
