Totenkopfe Neutral Newbie April 12, 2005 Share April 12, 2005 Hi, Can anyone tell me the size of the front and rear speakers for the Aveo? TIA ↡ Advertisement Link to post Share on other sites More sharing options...
Guest Aveo_powered Neutral Newbie April 13, 2005 Share April 13, 2005 Hi, If it's a notchback, front and rear should take 6.5inch speakers. If it's a hatch, 6.5inch for the front ones and 4 x 6 inch for the rear shelf-mounted speakers. But very few folks actually replace the 4 x 6. Most would just cut the board and fit 6 x 9s or 6.5inch components. Cheers! Link to post Share on other sites More sharing options...
Superchevy 1st Gear April 16, 2005 Share April 16, 2005 front is only 4.5 inch and rear can go to 6 inch normal and if modify can put sub woffer to 8 inch .. take note front can only be 4.5 inch cause of the mirror and motor . Link to post Share on other sites More sharing options...
Guest Aveo_powered Neutral Newbie April 16, 2005 Share April 16, 2005 Hi bro, You are correct about the oem front speaker size, it is 4.5 inch. However, a 6.5 inch can be fitted by a good installer so that it will not block the movement of the power window mechanism. I have done it. Cheers! Link to post Share on other sites More sharing options...
Superchevy 1st Gear April 16, 2005 Share April 16, 2005 yes , today i hunt for a shop who he claim that he has done one before dont tell me is you man ... any way which shop u done at and what speaker and $ how much . it can be fitted with a german made speaker but the price is man .. so never get it . wait for your reply . Link to post Share on other sites More sharing options...
Madman Neutral Newbie April 18, 2005 Share April 18, 2005 Hi bro, You are correct about the oem front speaker size, it is 4.5 inch. However, a 6.5 inch can be fitted by a good installer so that it will not block the movement of the power window mechanism. I have done it. Cheers! Hi Aveo_Powered, I am interested in changing the front stock speaker to a pair of 6.5 in component speaker. Please do let us know where you did yours. Thanks! Link to post Share on other sites More sharing options...
Superchevy 1st Gear April 18, 2005 Share April 18, 2005 yesterday meet up saw one fix also 6 inch sound very good but expensive leh.... Link to post Share on other sites More sharing options...
Guest Aveo_powered Neutral Newbie April 19, 2005 Share April 19, 2005 Hi Bro, Actually, I did it myself. Basically, you need a set of slim mid-bass speakers to start with, ie. mid-bass speakers with magnets that are not too big. Also, you would need to fabricate a spacer from MDF board, so that there is enough clearance between the window mechanism and the rear of the speaker. Most installers should be able to do it, it's a matter of price i guess... Link to post Share on other sites More sharing options...
Treesmaker Clutched April 19, 2005 Share April 19, 2005 Can you recommend your installer. I want to replace the tiny 4" front speakers. What speaker did you install in the front? Link to post Share on other sites More sharing options...
Superchevy 1st Gear April 19, 2005 Share April 19, 2005 ok thanks . ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato speakers spoilt. Advise pls
Quad Light Bulb Size
Speaker Tan Chuan-Jin, MP Cheng Li Hui resign
New Study Explores Connection Between The Size Of Your Manhood And Sports Cars
Tire size not available in Singapore, how?
Is a subwoofer necessary?
