Laser Neutral Newbie September 9, 2005 Share September 9, 2005 My 3 yr Ford Laser is having some leaking at the bottom of the radiator. Any idea besides changing a new radiator, what alternatives can I take. And how much is a new radiator. Thanks Laser ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 9, 2005 Share September 9, 2005 Is it from the rad itself or the bottom hose? Temporarily you can use one of the radiator cheimi-weld stuff. Link to post Share on other sites More sharing options...
Laser Neutral Newbie September 9, 2005 Author Share September 9, 2005 It is from the radiator itself, the black bottom plastic cover of the radiator. But the leak now is very minor. Laser Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 9, 2005 Share September 9, 2005 Bring it to a radiator place to get it checked out first as those can be removed. The seal might just be broken, warped, etc. Link to post Share on other sites More sharing options...
Kanr 1st Gear September 9, 2005 Share September 9, 2005 proably u are right,men!!!Cheeers!!!!!! Link to post Share on other sites More sharing options...
Linus Clutched September 10, 2005 Share September 10, 2005 ah.. 3 yo aldy got leak ah... wats ur mileage like ? Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 10, 2005 Share September 10, 2005 Since it is already three years old,it is best to do a pressure test to detemine whether there is other about-to-leak locations. If the leak is not due to corrossion but peeling off of botton tank due to poor sealing ( plastic type ) or dry soldering then doing minor repair is worth the time and effort. Link to post Share on other sites More sharing options...
Laser Neutral Newbie September 11, 2005 Author Share September 11, 2005 Mileage just past 70,000km. The problem is about 2 months ago there is a leakage in aluminum tube within the radiator for cooling of the ATF oil, and it cause the ATF oil to split into my radiator. Sent to Stamford for rectify and they suggust changing only the aluminum tube. And that cost me $350! Now this problem, so I suspect they did not do a good job. Anyway how much will it cost for a new radiator ? Laser Link to post Share on other sites More sharing options...
Mivec9 1st Gear September 11, 2005 Share September 11, 2005 My 3 yr Ford Laser is having some leaking at the bottom of the radiator. Any idea besides changing a new radiator, what alternatives can I take. And how much is a new radiator. Thanks Laser if its leaking via the bottom rubber hose, juz change the hose. If radiator, think possible to mend the leak. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 13, 2005 Share September 13, 2005 Bring it back to them and see what they say. Now that you mention that work has been done, i think it would most likely be a bad job on their part. Esp since they had to open the rad to do the work on the ATF cooler bits. Link to post Share on other sites More sharing options...
Laser Neutral Newbie September 13, 2005 Author Share September 13, 2005 I think so too, but the problem is that it has already been 2 mths since the incident Laser Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 13, 2005 Share September 13, 2005 Just try. No harm. There's a 6mth warrant on works done in aust. Maybe i'm used to it ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
RE :Jaguar Owners Servicing
KIA K3 Owners check-in!
Swift Owners
Swift Owners
Mercedes Owners Thread
Lexus Owners (To share driving experience and advise)
