Accent01leo Neutral Newbie November 8, 2005 Share November 8, 2005 What is the cause of noisy wheels? Could it be not balanced properly? I just changed to a pair of wheels on the rear, and they are making "hoe..hoe...hoe..." sounds. ' Any idea whats wrong with it? ↡ Advertisement Link to post Share on other sites More sharing options...
Sosaria Turbocharged November 8, 2005 Share November 8, 2005 Because the wheels know Christmas is around the corner?? Sorry... couldn't resist. Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 (edited) it is kinda of irritating... Edited November 8, 2005 by Accent01leo Link to post Share on other sites More sharing options...
Essentiale Neutral Newbie November 8, 2005 Share November 8, 2005 never do wheel alignment ah? Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 no, just did the balancing... never align will cause the noise? Link to post Share on other sites More sharing options...
Fitvip Supersonic November 8, 2005 Share November 8, 2005 (edited) Are your wheel bearings OK? Edited November 8, 2005 by Fitvip Link to post Share on other sites More sharing options...
Darth_mel 1st Gear November 8, 2005 Share November 8, 2005 What is the cause of noisy wheels? Could it be not balanced properly? I just changed to a pair of wheels on the rear, and they are making "hoe..hoe...hoe..." sounds. ' Any idea whats wrong with it? Could be wheel bearings worn out liao. I kenna before. Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 How to know whether the wheel bearings is ok? Link to post Share on other sites More sharing options...
Darth_mel 1st Gear November 8, 2005 Share November 8, 2005 If bearings are OK, there will be no whining/whirring sound. At least it was for my case. Link to post Share on other sites More sharing options...
Tyreboy Neutral Newbie November 8, 2005 Share November 8, 2005 err....what tyres you are using???? some tyres do create noise like helicopter flying around in the car cabin... Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 it doesn't have these sounds before the change of wheels. immediately after changing got these noise now...sigh. must go and ask them to check on my wheels... Link to post Share on other sites More sharing options...
Hazmano Neutral Newbie November 8, 2005 Share November 8, 2005 Are you using the same type of tires as previously used? Does the sound comes from both sides of the rear wheels? Well if the sound comes from only one of the wheels than it is likely a bearing problem. If you can jack up the car with gear in neutral and hand brake down, turn the wheel manually, it should rotate freely. Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 (edited) thanks.. will try to jack up and try whether is the bearing problem or not. I am not using back the same brand of tyres as previous, does it matter? Edited November 8, 2005 by Accent01leo Link to post Share on other sites More sharing options...
Hazmano Neutral Newbie November 8, 2005 Share November 8, 2005 Well logically if you are using the same brand or model of tyre as you used to, you would know what to expect of. Certain model of tyres are pretty noisy, even when they are new, especially sports tyres. My guess for your noise problem should be from the tyres itself. Link to post Share on other sites More sharing options...
Essentiale Neutral Newbie November 8, 2005 Share November 8, 2005 Yup if i aint wrong. Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 8, 2005 Author Share November 8, 2005 ok.. just came back from test the rear wheels. have resistance while turning to a certain degree on one of the wheel. :( guess the ball bearings is gone. any idea how much it would cost for the replacement? Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear November 8, 2005 Share November 8, 2005 Because the wheels know Christmas is around the corner?? Sorry... couldn't resist. Hoe hoe hoe Link to post Share on other sites More sharing options...
Accent01leo Neutral Newbie November 9, 2005 Author Share November 9, 2005 How much is the repair for bearings huh? Need a rough guide before being con... ↡ Advertisement Link to post Share on other sites More sharing options...
Formula 1 Wheels Look Way Different for 2022. Here's Why. . .
DIY Curbed Wheel Fix - Was It Worth It?
How to deal with noisy neighbour who play stupid drum
BBS wheels reportedly files for bankruptcy in Germany
The optional wheels for the Mac Pro cost almost S$600
New Mid Size Sedan All Comes with Bigger Rims/Wheels?
BBS....RI-A Rims.
BBS....RI-A Rims.
Forged brand rims... anyone know where this brand is from?
