Bryaan 3rd Gear August 3, 2016 Share August 3, 2016 These rims suitable for honda civic FD? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Dfx16 6th Gear August 5, 2016 Share August 5, 2016 These rims suitable for honda civic FD? IMHO 1 Link to post Share on other sites More sharing options...
carcrazy888 Neutral Newbie August 6, 2016 Share August 6, 2016 Hi Guys, need advise from anyone that have changed to lighter rims and whether the effect can be felt? both handling and fuel economy? I am currently driving a Honda Stream RSZ which is on 17inch stock rims. i understand the stock 17inch rims is about 10kg per rim and mid range lightweight rims of the same size in the market is 7kg. 3kg off each rim is about 30% off weight. I tried to hold on to a 3kg dumbbell and heavy say heavy, light say not light also. Hence like to check with members here (those who have changed to lightweight rims) if the effect from the lightweight rims can be felt? So as to justify the high cost of the rims. the rims i set my eyes on is OZ racing (not forged but cast flow technology something like that) $450 per rim (total $1,800). Thanks in advance. Link to post Share on other sites More sharing options...
flashbang Turbocharged August 6, 2016 Share August 6, 2016 Hi Guys, need advise from anyone that have changed to lighter rims and whether the effect can be felt? both handling and fuel economy? I am currently driving a Honda Stream RSZ which is on 17inch stock rims. i understand the stock 17inch rims is about 10kg per rim and mid range lightweight rims of the same size in the market is 7kg. 3kg off each rim is about 30% off weight. I tried to hold on to a 3kg dumbbell and heavy say heavy, light say not light also. Hence like to check with members here (those who have changed to lightweight rims) if the effect from the lightweight rims can be felt? So as to justify the high cost of the rims. the rims i set my eyes on is OZ racing (not forged but cast flow technology something like that) $450 per rim (total $1,800). Thanks in advance. Skeptical. 3kg x 4 rims = 12kg savings which is almost negligible... Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 8, 2016 Share August 8, 2016 Hi Guys, need advise from anyone that have changed to lighter rims and whether the effect can be felt? both handling and fuel economy? I am currently driving a Honda Stream RSZ which is on 17inch stock rims. i understand the stock 17inch rims is about 10kg per rim and mid range lightweight rims of the same size in the market is 7kg. 3kg off each rim is about 30% off weight. I tried to hold on to a 3kg dumbbell and heavy say heavy, light say not light also. Hence like to check with members here (those who have changed to lightweight rims) if the effect from the lightweight rims can be felt? So as to justify the high cost of the rims. the rims i set my eyes on is OZ racing (not forged but cast flow technology something like that) $450 per rim (total $1,800). Thanks in advance. let me share MHO if you run same tire and change the lighter rim (same specification) you feel will be lighter and acceleration improved little 2 Link to post Share on other sites More sharing options...
carcrazy888 Neutral Newbie August 8, 2016 Share August 8, 2016 Thanks Robert.you speaking from ur own experience? Link to post Share on other sites More sharing options...
Deckbuild 6th Gear August 8, 2016 Share August 8, 2016 Hi Guys, need advise from anyone that have changed to lighter rims and whether the effect can be felt? both handling and fuel economy? I am currently driving a Honda Stream RSZ which is on 17inch stock rims. i understand the stock 17inch rims is about 10kg per rim and mid range lightweight rims of the same size in the market is 7kg. 3kg off each rim is about 30% off weight. I tried to hold on to a 3kg dumbbell and heavy say heavy, light say not light also. Hence like to check with members here (those who have changed to lightweight rims) if the effect from the lightweight rims can be felt? So as to justify the high cost of the rims. the rims i set my eyes on is OZ racing (not forged but cast flow technology something like that) $450 per rim (total $1,800). Thanks in advance. 3kg off per rim is quite significant in terms of sudden acceleration, braking as well as changing of direction. Remember to look out for lighter weight tires too. Link to post Share on other sites More sharing options...
Yeobt Supercharged August 8, 2016 Share August 8, 2016 Hi Guys, need advise from anyone that have changed to lighter rims and whether the effect can be felt? both handling and fuel economy? I am currently driving a Honda Stream RSZ which is on 17inch stock rims. i understand the stock 17inch rims is about 10kg per rim and mid range lightweight rims of the same size in the market is 7kg. 3kg off each rim is about 30% off weight. I tried to hold on to a 3kg dumbbell and heavy say heavy, light say not light also. Hence like to check with members here (those who have changed to lightweight rims) if the effect from the lightweight rims can be felt? So as to justify the high cost of the rims. the rims i set my eyes on is OZ racing (not forged but cast flow technology something like that) $450 per rim (total $1,800). Thanks in advance. 1kg on a rim does made a diff. personal experience i'm not a power hungry person, but i do find the diff. another example is, 205 and 225, the width of a tyre. 20mm also made a diff. personal experience too. Link to post Share on other sites More sharing options...
High_octane 1st Gear August 8, 2016 Share August 8, 2016 http://hpwizard.com/rotational-inertia.html Lighter wheels does make a difference. Link to post Share on other sites More sharing options...
Columbian78 6th Gear August 9, 2016 Share August 9, 2016 I did that recently. Changed from stock rim 10kg to forged rim 7kg. Both 17 inch but the new rims width abit wider. Retained the same tyre for comparison. There is noticeable differences in many aspects especially over bumps and humps. The suspension seems to work faster due to less unsprung weight to manage. Link to post Share on other sites More sharing options...
carcrazy888 Neutral Newbie August 10, 2016 Share August 10, 2016 Work faster better? Or ride more jerky? Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 11, 2016 Share August 11, 2016 Thanks Robert.you speaking from ur own experience? yes my personal experience plus short listed write up plus open big big listen to others (it had to be making sense too) do remember sometime Theory not = Practical Link to post Share on other sites More sharing options...
Kurty Supercharged August 11, 2016 Share August 11, 2016 an old school - super advan rim.. 3 Link to post Share on other sites More sharing options...
Berzunger Neutral Newbie August 12, 2016 Share August 12, 2016 Great to see a decent wheel for Xbone, but here is my question for Thomas. When I bought my CSWB V2 I bought the universal hub and GT AU wheel rim. So is there a way to just upgrade my universal hub to suit the xbone rather than ending up with 2 universal hubs. If I had known that this was the way it would come around I would have bought a Formula wheel when I bought the CSWB V2 instead of the universal hub. Link to post Share on other sites More sharing options...
Buadongdong Twincharged August 13, 2016 Share August 13, 2016 Any bros here familiar with Chrome rims? I just got mine but am wondering if those PPS like blacknano, CS-II, etc. will cause the chrome finish to peel/damage?? AM planning to have PPS done to my car and most PPS detailers does 2 layer coatings to the rims. Any Bro can advise? Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 19, 2016 Share August 19, 2016 Thanks Robert.you speaking from ur own experience? yes Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 19, 2016 Share August 19, 2016 (edited) Any bros here familiar with Chrome rims? I just got mine but am wondering if those PPS like blacknano, CS-II, etc. will cause the chrome finish to peel/damage?? AM planning to have PPS done to my car and most PPS detailers does 2 layer coatings to the rims. Any Bro can advise? most Chrome rims cant survive here for long time A good Quality may last longer like 5 years with minimum corrosion some can start to corrode within just few weeks I wont just simply blame the Quality , is probably our humidity and rains and shine some could be due to mech job which could cause Chrome to crack accidentally or not carefully(seriously speaking no mechanic can guaranty you this but can do their best to lower the risk just my personal point of views Edited August 19, 2016 by Roberttan Link to post Share on other sites More sharing options...
SiLangKia Supersonic August 25, 2016 Share August 25, 2016 (edited) Changed from stock FD rims to replica Rays Volk Racing TE37SL concave rims, slightly lighter than stock (carried both to compare ). Was torn between buying original Jap Rays rims and Replicas (read alot about them) but decided to go for the savings and get a taiwan (not china) rep, shld be ok *cross fingers* Wanted to go big on size but fuel consumption is a concern so stuck to 16', went for the gunmetal or dark chrome look hahaha Edited August 25, 2016 by SiLangKia ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Any Hokkien Song Lovers here?
Newbies, post ur questions/request here
Does rims change shape/warp over time?
Minimum Post Limit Before New Thread Creation
Who's your favorite lau-chiobu actress ?
Arsenal Fans Fall in here... SEDIA..
