Sturtles 6th Gear February 13, 2006 Share February 13, 2006 (edited) http://www.kleemann.dk/site/Main/tuningpro...performancekits KLEEMANN Engine Performance Kits Low cost - effective tuning KLEEMANN has developed an array of power enhancing Engine Performance Kits for Mercedes-Benz cars fitted with a standard OE Kompressor including AMG models. The simple yet effective design ensures years of reliable performance. Specific to each Mercedes-Benz model, the KLEEMANN Engine Performance Kit contains a custom-made pulley set, high airflow filters and a K-Box. The pulley is CNC machined and the diameter is increased and precision balanced to ensure a long service life and full vibration dampening. A new belt idler and serpentine belt is also fitted to maintain OE specifications for belt tension and high-flow air filters reduce pressure drops inside the air box to maximize airflow. The result is greatly improved power and torque throughout the entire engine operating range with crisp throttle response and perfect drivability. Power gains are as much as 20 percent both in horsepower and torque. The KLEEMANN engine performance kit is available for the following engines: 1.8 (M271), 2.0 (M111K), 2.3 (M111K), 3.2 (M112K) and 5.5 (M113K). ------------------------------------------------- I've got a question... The kleeman's kits should be giving the c180K the same performance as a kleemen's kitted c230K.. but this is not the case... does anyone know why? Edited February 13, 2006 by Sturtles ↡ Advertisement Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie February 13, 2006 Share February 13, 2006 different tunning? Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear February 13, 2006 Share February 13, 2006 C&C said the C180 and C200 had same kompressor engines, but the C200 is a supercharged one givng greater power. Thats what the sales executive said when I was there last w/e. did know of kleeman as I thot good tuning only from AMG. side track a bit sorry, does BMW has similar tuning stuffs[good ones] as done by AC Sh??? Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie February 13, 2006 Share February 13, 2006 (edited) C180 is also supercharged i believe maybe different supercharger size? http://www.acschnitzer.com/ i think u have to ask performance motors. 159944, SGP, Singapore Performance Motors Limited 315 Alexandra Road #01-01 Performance Centre 6319 0828 Edited February 13, 2006 by Cyberet Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Author Share February 13, 2006 hmm.. i see... could be the case.. although the engines are the same, the supercharger is differently sized. But from the specs of the kleemen, it seems the c200K and the c230K uses about the same supercharger only 5 hp difference Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie February 13, 2006 Share February 13, 2006 hehehe.. so get the c200, and lup a Kleemann performance kit Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie February 13, 2006 Share February 13, 2006 they're using a technology called TwinPulse...where the engine cc is the same...but the power output is different. i remember that it should be C180 and C200 which has the same CC...but different cam profile and ECU program. Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Author Share February 13, 2006 i see... its very plausible too But with the less agressive cam profile of the c180, does it mean it saves even more fuel? The 200K is already quite a sipper liao, matching even some 1.6L cars like sunny and lancers.. The 180K, hmm.... maybe sip like a vios? hahaha Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Author Share February 13, 2006 No lah.. i was thinking if i tio toto, then maybe get a 180K, then lup he kleeman kit, can get equivalent power as a 230K... but it seems max is about 193hp, which is not too bad for a 1.8L already... Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie February 13, 2006 Share February 13, 2006 the twinpulse tech is suppose to be fuel efficient as well. benz has a pretty good gearbox and engine management program. when on cruise control on expressways, even the S-class can match 1.6l jap cars for fuel efficiencies. here's an article on twinpulse http://uk.cars.yahoo.com/car-reviews/car-a...0k-1003060.html Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie February 13, 2006 Share February 13, 2006 (edited) the c200 if driven with a light foot for the whole journey, can get 10km/l on local expressways with speed limiter, its about 12km/l but average records since day1 till now is about 9km/l not bad for a heavy 1.8L car recently went for a gearbox overhaul & engine had some carbon buildup problem though Edited February 13, 2006 by Cyberet Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear February 13, 2006 Share February 13, 2006 I get 8L/100km on the E200K M271 on 70% highway, 30% normal urban. That's 12.5km per L! On night cruising from work to home on highway, I've even hit 7.6L/100km, or 13km/L. The E200K and C200K uses the same M271 tuned to 163bhp and 240Nm. The C180K uses the same M271 engine, but the Kompressor is less aggressive with a different ECU map, hence the lower bhp and torque. Hence the Kleemann kit is pulley + K-Box (air fuel ratio piggy back) for E200K and C200K, and only K-Box for C180K. The M271 engine is great stuff, giving very good FC and overall performance for a 1.8L SC engine. It's a bonus too given our crazy road tax system that taxes according to cc! Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie February 13, 2006 Share February 13, 2006 yeah, in the wee hours with empty roads and highway travel, 13km/L has been achieved before but rare nowadays la Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Author Share February 13, 2006 Hmm.. if the 180K is only different from the 200k and 230k, do you know why the hp figures produced after the k-kit is different for all the 3 models? Also, the ecu map could already be affected by the k-box to achieve the same actual mapping as the 200 and 230k... otherwise, a simple ecu change could help too :) i realy think there are different models of supercharger mounted on the m271 hence the difference in performance after kitting Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Author Share February 13, 2006 In addition to the Kleemann pulley cum piggyback kit, all m271 owners can get this, for another 25+- horses to pull the car... so a c200k will become 210hp+25 with 300Nm+some.. Not bad for a run-of-the-mill car http://www.kleemann.dk/site/015A80FE-E6D3-...D0E690CBCD6.htm ore power - Better sound The KLEEMANN tubular exhaust headers remove exhaust backpressure allowing the engine to breathe freely and thereby produce more power. Supercharged as well as normally aspirated engines will benefit from the use of KLEEMANN Stainless Steel Headers. A normally aspirated engine will typically gain 7 to 10 percent in horsepower and torque, while a supercharged engine will gain as much as 15 percent in horsepower and torque. KLEEMANN headers are made of high quality stainless steel and feature mandrel bends, precision water-jet cut flanges, larger primary pipe diameters, and larger collectors and down-pipes. KLEEMANN headers integrate with the stock engine management flawlessly with no need for further modification. V6 and V8 The KLEEMANN Tubular Exhaust Headers fit all V6 and V8 engines, and combined with a KLEEMANN exhaust system the sound is just phenomenal - something you have to experience. More power for 4 cyl. models New for 2006 is the tubular header for the four cylinder M271-engine mounted in all newer 180, 200 and 230-models. Fitted with the new high flow header and down pipe power output is increased with up to 25 Hp on the 1.8 litre Kompressor engine. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear February 13, 2006 Share February 13, 2006 Yes, the Kompressors are different on the C180 and C200/E200. Link to post Share on other sites More sharing options...
Evow123 Neutral Newbie February 14, 2006 Share February 14, 2006 Bro, want to meet up this Sat @ 2pm Kallang Mac?? SGMercedes Meetup! Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear February 14, 2006 Share February 14, 2006 OK! Will keep it in mind and try to make it. The Mercedes delphi forum has a really unfriendly interface. Wish we could have a proper forum for sg Mercedes like IntegraSG or the BMW club. Oh well... ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes C class W204 (Facelift) Reliability
Thinking of buying MErc C180
Scientists find rich and poor are 'biologically different'
Is Engine Oil the same for Petrol & Diesel engines ?
C180 owners! how's the reliability of your car?
Different front and rear tires
Different version of 3M Clay Bar
Front and rear different tire size
