Dennisk Clutched March 13, 2006 Share March 13, 2006 my stock tyres & rims are 185/65/14, now i change to 205/55/16 can i change my tyres to 195/55/16? ↡ Advertisement Link to post Share on other sites More sharing options...
Orpheus Neutral Newbie March 14, 2006 Share March 14, 2006 (edited) Not advisible. 195/50/16 is closer to 185/65/14. 195/55/16 is way out (+4%). But wait! your 205/55/16 is even more way out (+6%)? Is it OK? Edited March 14, 2006 by Orpheus Link to post Share on other sites More sharing options...
Apollo 1st Gear March 14, 2006 Share March 14, 2006 195/50/16 will probably b clearing the bananaleaf and not scratch the tyre when u turn, but check that your rim offset is correct type. Link to post Share on other sites More sharing options...
Dennisk Clutched March 15, 2006 Author Share March 15, 2006 what i did is actually +2, 185 to 205, 65 to 55 , 14 to 16 , i thought this is the right way of doing for +2 Link to post Share on other sites More sharing options...
mihainiculae92 Neutral Newbie October 23, 2017 Share October 23, 2017 Hi, Since I don't have the permission to post a new topic I will write here, I hope the topic owner will not mind. I bought a new set of alloy rims for my car for the winter season, yesterday I fitted them and I observed a small gap between the rim and brake disc ( see the pictures attached). Will this gap cause any problems? It is normal? The rims are similar from the point of E.T PCD, HUB diameter etc. What I thinks is that the bore (brown part) is a little bit too long and hits the green part (green part on the diagram) I took the car for a spin and i didin't feel any strange behavior (vibrations or oscilations) I fear not the shear the bolts... Link to post Share on other sites More sharing options...
HW1973 3rd Gear October 23, 2017 Share October 23, 2017 what i did is actually +2, 185 to 205, 65 to 55 , 14 to 16 , i thought this is the right way of doing for +2 Hi, +2 upsize should be - 185 to 195 to 205 (tyre width) - 65 to 55 to 45 (profile) - 14 to 15 to 16 (rim size) So technically, at 16-inch, your profile should be 205/45R16. Link to post Share on other sites More sharing options...
Roberttan 5th Gear October 24, 2017 Share October 24, 2017 Dear 92, it is alright to have those gap there it is probably caused by your wheel hub(back) had little chamfered edged should you have any doubt I am sure you can go back to the shop seller for clarification Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear October 24, 2017 Share October 24, 2017 Follow the manual Link to post Share on other sites More sharing options...
Bebzz Neutral Newbie October 30, 2017 Share October 30, 2017 Hi peeps!Anyone here can advise whats the correct max tyre size if lets say I want to upsize my rims to 17 inch?Currently driving civic fd 1.6 with 16 inch stock rims and tyres.Thanks! Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 1, 2017 Share November 1, 2017 Hi peeps! Anyone here can advise whats the correct max tyre size if lets say I want to upsize my rims to 17 inch? Currently driving civic fd 1.6 with 16 inch stock rims and tyres. Thanks! can share whats your Drive tire size ? (Civic FD?) ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Is there a cure/remedy for Diabetes?
COVID-19: Retrenchments
Will u buy Diesel or Petrol Cars in SG
