Alveron2001 Neutral Newbie April 11, 2006 Share April 11, 2006 Hi all Noticed that our Octavia uses a Red/Pink colour coolent in the Radiator. How often do we need to top this ? Does it dry up often ? What do we top it up with ? Water can ? The user's manual mentions adding water for temp use is ok but remember to bring it back to proper coolent mix asap. But it doesn't say what is the proper coolent mix... If water is no good, does that mean I have to keep a can of pure coolant to top up whenever I detect that coolant level is low ? A friend of mine drives a 2 year old Bora... I noticed that he only need to top up with water. He poured it into a white plastic globe/ball like container on the upper left of the engine bay. I'm such a newbie... but the prev jap cars I drive only need to put good ol cheepo water... Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
XLR8 1st Gear April 11, 2006 Share April 11, 2006 Many ppl think that coolant is the one that brings down the temperature. Actually water alone is the cooling substance and the COOLANT is the one that prevents corrosion of the radiator. This is something I learnt from the VAG mechanics. If you not kiasu then water alone is good to go. Once awhile servicing just add coolant lar. Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie April 11, 2006 Share April 11, 2006 as long as it dont drop below the "min" lvl. mine is a nov 03 octavia amb.....nv top up be4. Link to post Share on other sites More sharing options...
Germar Neutral Newbie April 11, 2006 Share April 11, 2006 Water can do..no worries mate. Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie April 11, 2006 Share April 11, 2006 The Coolant VW used is G12 Plus. Normally, when after flushing the radiator, a bottle os these will be poured in and add water until the max level is reached ... Link to post Share on other sites More sharing options...
Alveron2001 Neutral Newbie April 12, 2006 Author Share April 12, 2006 Thanks V much to everyone for clearing that up.... This is my understanding from all teh advice.... For regular topping up, add water can liao. When it's time for annual servicing to clear the radiator then I will need to add a new can of coolant to mix in with regular tap water... Cheers ! Link to post Share on other sites More sharing options...
PointyEwe Clutched April 13, 2006 Share April 13, 2006 I've never top up my Octy coolant since I've got the car in year 2001!! Being a closed loop cycle, evaporation effect seemed to be quite minimal. Workshop say no need to top up unless drop to dangerously low level. Link to post Share on other sites More sharing options...
Fluffy Clutched April 13, 2006 Share April 13, 2006 don't need to top up, only did it once ......... only time when there was a leak from a cracked connector (probably accident related) Link to post Share on other sites More sharing options...
Fluffy Clutched April 13, 2006 Share April 13, 2006 (edited) Many ppl think that coolant is the one that brings down the temperature. Actually water alone is the cooling substance and the COOLANT is the one that prevents corrosion of the radiator. This is something I learnt from the VAG mechanics. If you not kiasu then water alone is good to go. Once awhile servicing just add coolant lar. water alone is not enough as water boils at 100 degree C, and turns to steam, which is useless as a cooling agent. Therefore Coolant (ethylene glycol ) is added to raise the boiling point of water and to lower the freezing point of water. There are additives in the coolant that prevent corrosion. therefore, the VAG mechanics ........sigh......... Edited April 13, 2006 by Fluffy Link to post Share on other sites More sharing options...
Gendut 2nd Gear April 13, 2006 Share April 13, 2006 It also increases the boiling point and (I might be wrong here) also increases the specific heat capacity. Maybe if can get a thermostat with higher coolant set temperature, can get more output from the engine. Link to post Share on other sites More sharing options...
Fortress Clutched April 13, 2006 Share April 13, 2006 (edited) believe my coolant is green, but the colour does not matter unless it is rust in the water. The coolant is to prevent rust. Water is to help bring down the temperature. As for topping up, generally water is good enough, for optimum result, use deminirise water will be ideal. Hardly top up, I have marked a line on it when it is cold, and observed it before I drive off, it helps to tell whether does it need to top up. If so, and a lot, means there is a leakage. Edited April 13, 2006 by Fortress Link to post Share on other sites More sharing options...
XLR8 1st Gear April 13, 2006 Share April 13, 2006 As for which workshop I'd rather not comment. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 17, 2006 Share April 17, 2006 (edited) Skodarr here is correct. VW uses BASF's Glysantin 12 often abbreviated as G-12. G-12 is silicate free antifreeze. This means that VW coolant systems DO NOT LIKE silicates from the traditional green antifreeze from yesteryears. To do so will result in the infamous "snot of death". It is a pure OAT antifreeze/coolant. No phosphates either unlike Toyota's LLC. No, you cannot get away with using MB or BMW coolants because those are G-05. G-05 has some silicates, has some phosphates, has some nitrites and some amines. Though all in reduced levels, they are not for VW engine cooling systems. If you get the original VW coolant, you might choke on the price. Might be made of liquid gold or something. A compatible no phosphate, silicate, amine or nitrite antifreeze easily available will be Prestone's 5/150 or Caltex (Chevron) LLC. These are pure OAT antifreezes. Finally, do not mix antifreezes. The color doesn't count. It is the chemistry. Pure OAT ones do not like other stuff with it. For more info, see this post in the Maintenance folder: http://www.mycarforum.com/forum/gforum.cgi...1304582#1304582 Edited April 17, 2006 by Genie47 Link to post Share on other sites More sharing options...
King 1st Gear April 17, 2006 Share April 17, 2006 thks, genie, will remember so... Link to post Share on other sites More sharing options...
Flight_skoda Neutral Newbie April 20, 2006 Share April 20, 2006 I just use water leh. Link to post Share on other sites More sharing options...
Beanoyip Turbocharged May 2, 2006 Share May 2, 2006 So can i top up the coolant just using distilled water? Somehow or rather today when i started up the car, an indicator light came on. It was the engine temp blinking.. whats the diagnoise for this? Link to post Share on other sites More sharing options...
Putter Neutral Newbie May 2, 2006 Share May 2, 2006 If your coolant still have colour (some pink, some blue, some green), top up with just water should be fine. If the colour turns very pale, it is time to change up the coolant. If you discover some vaporization residues around your coolant cap, and your coolant water keep often needs to top up, high chance there is an escape through the cap which may need to be replaced. ↡ Advertisement Link to post Share on other sites More sharing options...
Home fires more often now due to PMDs?
Radiator slight crack
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
Radiator tank leaks
Radiator tank leaks
Air-con condenser fan....how often should it run?
