  • Search this thread
  • Reply to this topic
84 replies to this topic | 54 praises
#1
Posted 13 April 2006 - 01:07 AM
Hlkh
  • THREAD STARTER
  • Hlkh
    3rd Gear
    Author Image
    358
Hi any one here change your own spark plugs??
how to judge to tighnest of the spark plugs??
#2
Posted 13 April 2006 - 11:06 AM
Genie47
  • Genie47
    2Fast2Furious
    Author Image
    26,167
With torque wrench. Anywhere from 30-35Nm.
Without torque wrench, Agar agar 1/2 -3/4 more after it is tight. Confirm not accurate. 30Nm is tighter than the 3/4 more after it is tight.
Men are like oysters, closed to suffering.
http://www.spritmoni...ail/264162.html
#3
Posted 14 April 2006 - 01:34 AM
Hlkh
  • THREAD STARTER
  • Hlkh
    3rd Gear
    Author Image
    358
ok ... i just change plug myself after hand tight then spanner 1/2 round ok?
#4
Posted 14 April 2006 - 02:25 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
If this is yr first try then chance you just don't have the feeling. If the plug is brand new,first try to thread in as much as you can freely with the spark plug socket & T bar. Once you feel the resistance keep going until the washer is compressed. Now try to wrench the T bar probably another 1/4 turns , you should have manually torque the spark plug.
PS photo shows socket( thin wall type) with correctly designed T bar handle to provide the manual wrenching and the plug is finally tighten with a torque wrench
Edited by Yeobh, 14 April 2006 - 02:32 AM.
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#5
Posted 15 April 2006 - 12:42 AM
Hlkh
  • THREAD STARTER
  • Hlkh
    3rd Gear
    Author Image
    358
ok ... i will look for the T bar socket to reconfirm.
but if not tighten enough or over tighten what will happen?
#6
Posted 15 April 2006 - 05:25 PM
Cordia_gsr
  • Cordia_gsr
    4th Gear
    Author Image
    811
Over tighten, you will snap the plug's thread into the cylinder top block. And in the worst scenerio, you got to take the top block apart to remove that snapped portion. No joke.
#7
Posted 15 April 2006 - 11:46 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
Never try to replace spark plugs when the engine is till hot - let it cool down. Cylinder head now a days are mainly make of cast alumiumin and if you try to tigthen the spark plugs when the cyl head is hot chances hairline cracks will develop overtime due to the material stress taking place when it cool down to ambient temp.
Compression leakage will happen if the plugs are not properly torque down - this will have an effect on the engine performance and fuel comsumption. Over tightening will creat problem when you want to replace the plugs.
Edited by Yeobh, 15 April 2006 - 11:47 PM.
#8
Posted 16 April 2006 - 12:34 AM
Hlkh
  • THREAD STARTER
  • Hlkh
    3rd Gear
    Author Image
    358
I just check the recommended turn after hand cant be tighten.
i found out that it is recommended at about 2/3turn but i only turn about 1/2 turn only.
should i take out and reinstall? or it about 1/2 also can?
but now i feel my car got power only fuel consumption drop by around 1km/l like that before i change to irdium
Edited by Hlkh, 16 April 2006 - 12:37 AM.
#9
Posted 16 April 2006 - 12:38 AM
Genie47
  • Genie47
    2Fast2Furious
    Author Image
    26,167
Grease your plug threads before you screw them in with high temperature grease.
#10
Posted 16 April 2006 - 12:58 AM
Hlkh
  • THREAD STARTER
  • Hlkh
    3rd Gear
    Author Image
    358
where can get the grease?
#11
Posted 16 April 2006 - 01:01 AM
Cbx750p
  • Premium member
    Cbx750p
    5th Gear
    Author Image
    1,155
Yo ! That is a No No to grease your plugs ! High temperature grease or not, nothing can withstand the kind of heat that would be put up from the combustion chambers ! In my many years of automotive working, never heard of putting high temperature grease onto the plugs ! The grease would eventually burn and freeze the plugs if you don't remove them on time.
Just use a new set of plugs or make sure the old one is very clean....use a wire brush to get rid of all the carbon build up on the thread.
CBX
CßX
Visit my VW Blog
http://jimmy-cbx.blogspot.sg/
#12
Posted 16 April 2006 - 01:12 AM
Genie47
  • Genie47
    2Fast2Furious
    Author Image
    26,167
I've used grease no problems. I got problems with anti-sieze. Actually plug installers have two camps just like oil filter intallers.
Oil filter installers:
Camp 1: Use engine oil to lube gasket.
Camp 2: Use grease to lube gasket.
Spark plug installers:
Camp 1: Use anti-sieze on threads.
Camp 2: Use high temperature grease on threads.
Which camp you belong to actually depends on how much bad luck you have with the method at first!
#13
Posted 16 April 2006 - 04:41 PM
Trex101
  • Trex101
    6th Gear
    Author Image
    2,746
Grease will work just fine, too much anti-seize will actually seize the plugs.
<b>My Orange Ford Territory Ghia - Philips Xtreme Vision 130+, NGK ZFR6FIX-11 Iridium, Redline 0w30, Redline Racing ATF, Redline Heavy Weight Shockproof </b>
#14
Posted 17 April 2006 - 04:39 PM
Eyebm
  • Eyebm
    Clutched
    Author Image
    27
heh...I didn't know that we can use grease on the spark plugs?
Thanks.
For NGK Iridium IX Spark Plugs visit my homepage
http://sg.geocities.com/henry_toh/ --- My NGK homepage
http://sg.auctions.y...booth/henry_toh --- View My Auctions
#15
Posted 17 April 2006 - 04:50 PM
Genie47
  • Genie47
    2Fast2Furious
    Author Image
    26,167
Can use. No problem but depends on your luck. Like I've said, if you got bad luck using HT grease, you most likely have better luck using antisieze and vice versa.
Anything to remove it easier next time.
#16
Posted 02 May 2006 - 08:40 PM
Wyx03_2002
  • Wyx03_2002
    Author Image
    17
any lobang to get a torque wrench? What's the estimated cost?
thanks.
#17
Posted 02 May 2006 - 11:13 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,009
Hard to find torque wrench for DIY in our market.Check with Genie47 he may have the info or try ebay.com
#18
Posted 03 May 2006 - 08:23 AM
Wyx03_2002
  • Wyx03_2002
    Author Image
    17
I searched around in Msia and P'pines hardware shops for a month liao, couldn't find one. Mayb hv to try my luck in ebay then, thanks.
#19
Posted 03 May 2006 - 08:42 AM
Wallaw819
  • Premium member
    Wallaw819
    4th Gear
    Author Image
    546
There are lots of hardware stores that sell torque wrench. Just tell them what you need and they can order for you. Or you can go direct to the agents. Just do a google search in singapore. But one thing they are not cheap.
#20
Posted 03 May 2006 - 09:34 AM
Genie47
  • Genie47
    2Fast2Furious
    Author Image
    26,167
For spark plugs. Use those selling in eBay USA for them. Some going as low as US12.99 but that is w/o shipping yet. Make sure you get the right torque range. Don't get the spring type with that funny dial. The clicker type is what you want.
If not, go to 2nd level Tekka market. There is a hardware store that sells them.
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Replace, spark, plugs
