Ixat 1st Gear May 9, 2006 Share May 9, 2006 Hi Vtim, Driving a FL Getz. Using orginanl Hyundai NGK spark plugs. Thanks for advising! ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 9, 2006 Share May 9, 2006 Getz 1.1, 1.3 & 1.6 are using BKR5E-11, which is a 16mm hex size nut Link to post Share on other sites More sharing options...
Ixat 1st Gear May 24, 2006 Share May 24, 2006 Thanks Vtim! Finally got my wrench and a set of plugs. Got the plugs changed myself. Feels good after change Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 24, 2006 Share May 24, 2006 Link to post Share on other sites More sharing options...
Kawan 1st Gear May 24, 2006 Share May 24, 2006 When would i know if the spark plugs need to be replaced? Normally after how many km? What are the symtoms? Link to post Share on other sites More sharing options...
Vtim 3rd Gear May 26, 2006 Share May 26, 2006 engine may be a bit rough and pickup is sluggish as compare to when the plugs are new Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 Or you be garang and don't change, take them out and gap them to the correct gap size and continue driving for another 10k. Rinse repeat until there is almost no more head left on the spark plug. You need a spark plug gapping tool for this. Hmmm....more tools to make a man feel like man..... Link to post Share on other sites More sharing options...
Petrolhd Neutral Newbie May 26, 2006 Share May 26, 2006 Yo ! That is a No No to grease your plugs ! High temperature grease or not, nothing can withstand the kind of heat that would be put up from the combustion chambers ! In my many years of automotive working, never heard of putting high temperature grease onto the plugs ! The grease would eventually burn and freeze the plugs if you don't remove them on time. Just use a new set of plugs or make sure the old one is very clean....use a wire brush to get rid of all the carbon build up on the thread. CBX The grease to use is comma copper ease, a very high temperature grease you smear sparingly on the thread of the plug to prevent seizure the next time u remove the plug. BTW, this stuff is also good for applying on the backside of brake pads to prevent squeals. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 26, 2006 Share May 26, 2006 after i see the tons of spark plugs in the bin today.. feel so tempted to get a gapping tool, free plugs for life any lobang? Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 Yeobh lor! Bid for his gapping tool from eBay.sg Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 26, 2006 Share May 26, 2006 wah, lots of interesting stuffs.. brake bleeder Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 Got the Eezibleed from him. I bleed my brakes myself. Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 26, 2006 Share May 26, 2006 (edited) brake fluid tester, torque wrench.. doh, so many things, so little money http://auctions.yahoo.com/sg/i:Spark%20Plu...roduct:94958720 does this measure plus adjust at the same time? hmm.. eezibleed should i get? hmm... Edited May 26, 2006 by Cyberet Link to post Share on other sites More sharing options...
Genie47 1st Gear May 26, 2006 Share May 26, 2006 You can measure and adjust the ground. There is a recess for it. You can make your coppers last maybe 40k? Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 26, 2006 Share May 26, 2006 great a definate must get still considering should i get eezibleed.. hmm.. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 27, 2006 Share May 27, 2006 (edited) To destress the copper washer ( to make it soft) just heat up with a butane torch or do it at your gas cooker - then let is cool down. This way you need not have to replace the copper washer for a long time. Appreciate very much for your support - Thank You !! Edited May 27, 2006 by Yeobh Link to post Share on other sites More sharing options...
Hondacivices1 Neutral Newbie June 5, 2006 Share June 5, 2006 dun la pay some money get better professionals Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 6, 2006 Share June 6, 2006 dun la pay some money get better professionals IMHO, I don't think that these "professionals", that you are referring to, are following the recommended Torque when they tighten the plugs ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Replacing fuel filter
Spark Car Care
Spark Car Care
Aftermarket vs. OEM Spark Plug Wires
Replace washing machine door seal/gasket
