Matoonia 6th Gear April 17, 2015 Share April 17, 2015 Hi, With these comfort coils, my car will still have the lowered (2 fingers ) look and less stiff? I wonder how they make it less stiff since the suspension travel is still restricted. Does anyone know the prices of these comfort coils? I have used the KW streetcomfort, lowered about 2 fingers. It's not very stiff, but at the same time gives me good confidence on the roads. The bad is that coilovers dun last that long, mine lasted me around 40k, before the absorbers start giving way. I'm back to stock now, and now my car drives like SUV ↡ Advertisement 1 Link to post Share on other sites More sharing options...
simons May 27, 2015 Share May 27, 2015 U r so crazy. Link to post Share on other sites More sharing options...
flashbang Turbocharged May 27, 2015 Share May 27, 2015 Are shock absorbers universal and fit all cars? Eg if a car has MacPherson struts, any shock absorber that is MacPherson type will fit? Or certain cars can only be fitted with certain shocks? Link to post Share on other sites More sharing options...
max15 June 1, 2015 Share June 1, 2015 gud info Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 2, 2015 Share June 2, 2015 I have used the KW streetcomfort, lowered about 2 fingers. It's not very stiff, but at the same time gives me good confidence on the roads. The bad is that coilovers dun last that long, mine lasted me around 40k, before the absorbers start giving way. I'm back to stock now, and now my car drives like SUV get a set of the passat sport (2.0T) or passat cc absorber, those 15mm lower one good enuff Link to post Share on other sites More sharing options...
Matoonia 6th Gear June 2, 2015 Share June 2, 2015 get a set of the passat sport (2.0T) or passat cc absorber, those 15mm lower one good enuff I was thinking of using lowered springs, but now grown used to it. Haha can save some $ Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 2, 2015 Share June 2, 2015 I was thinking of using lowered springs, but now grown used to it. Haha can save some $ the 15mm lower one is not bad good balance, but very butt pain on rough uneven road though Link to post Share on other sites More sharing options...
Gteokh Clutched June 15, 2015 Share June 15, 2015 Hi all, I am looking for RS-R coil over. Do anyone know who is the authorised dealer in Singapore? Thanks Link to post Share on other sites More sharing options...
Sufy1979 Neutral Newbie September 8, 2015 Share September 8, 2015 I am looking for shock absorber for my Stream'08 model at an affordable price. Any recommendations? Link to post Share on other sites More sharing options...
RaceLover 1st Gear September 9, 2015 Share September 9, 2015 Great Article. Very informative. Thanks! Link to post Share on other sites More sharing options...
ken4228 Neutral Newbie December 10, 2015 Share December 10, 2015 nice info. thanks! Link to post Share on other sites More sharing options...
Kurty Supercharged December 10, 2015 Share December 10, 2015 Anyone tried modifying their adjustable for comfort? Getting the best of 2 world.. I know there's such shop in kl but any in johor? Link to post Share on other sites More sharing options...
Deckbuild 6th Gear December 25, 2015 Share December 25, 2015 (edited) Just changed my coilover from Tanabe sustec pro s0c to Tein Street Flex Z. A HELL to HEAVEN experience... The tanabe have preload and shock travel tie together, the lower you go, the lesser travel it gets, to make matter worst, the spring rate for the car is too low, the damper doesn't have any adjustment and is way too soft which cost the shock to hit bump stop at almost every imperfection on the road. For Tein street flex z, the price is very reasonable to start with, shock is of a good quality. Way better than the tanabe that i have own. Shock travel is independent of the ride height and preload, you can really slam your ride. 28 level of setting for damping. Much stiffer than the tanabes if goes to hard setting, ride like a lexus if really go into soft setting. Never experienced a single bump stop hit on those road that I usually travel. Thumbs up for Tein Street Flex z! Edited December 25, 2015 by Deckbuild 1 Link to post Share on other sites More sharing options...
Terri 1st Gear February 13, 2016 Share February 13, 2016 Best to get shocks that can adjust bound and rebound separately. If you use stiffer springs.. you should set your rebound to be higher number so that the springs ( which is harder than org ) wont push the car up so fast when its compressed. Usually you see track cars adjust rebound harder to prevent car from flying up in the air LOL. 1 Link to post Share on other sites More sharing options...
Fran Neutral Newbie January 5, 2017 Share January 5, 2017 Hi everyone! bought my ride with coilover, as it is leaking I am thinking of switching back to stock suspension. What are three things I need to get to change back to stock? Just the spring and absorber? Link to post Share on other sites More sharing options...
Photo5star Neutral Newbie March 20, 2017 Share March 20, 2017 Hello good day. Do you guys know what type of lowering springs fit the toyota corolla axio luxel 2008 Model- DBA-ZRE142? I would like to know some different type of lowering springs that can just replace the original springs Link to post Share on other sites More sharing options...
DC1977 3rd Gear March 20, 2017 Share March 20, 2017 Just changed my coilover from Tanabe sustec pro s0c to Tein Street Flex Z. A HELL to HEAVEN experience... The tanabe have preload and shock travel tie together, the lower you go, the lesser travel it gets, to make matter worst, the spring rate for the car is too low, the damper doesn't have any adjustment and is way too soft which cost the shock to hit bump stop at almost every imperfection on the road. For Tein street flex z, the price is very reasonable to start with, shock is of a good quality. Way better than the tanabe that i have own. Shock travel is independent of the ride height and preload, you can really slam your ride. 28 level of setting for damping. Much stiffer than the tanabes if goes to hard setting, ride like a lexus if really go into soft setting. Never experienced a single bump stop hit on those road that I usually travel. Thumbs up for Tein Street Flex z! how much the Tein street flex z? whr did u install them? any warranty period? Link to post Share on other sites More sharing options...
flashbang Turbocharged March 20, 2017 Share March 20, 2017 Got a question, will coilovers offer a more comfortable ride as compared to stock springs and dampers? ↡ Advertisement Link to post Share on other sites More sharing options...
All about smoking
All about smoking
Questions about Gearbox overhaul
Let's talk about NS... good memories or nightmares?
All about air filters...
About Adult Toys
About Adult Toys
Questions about house moving.
