Mooscenic 1st Gear July 13, 2006 Share July 13, 2006 Hi all, I need some input on the following sound insulation for my 4 doors: 1. Anyone tried Silent sound proofing? How the review for their Silent mat? 2. Anyone tried or had done sound proofing at Car Beauty? They're using "Smart Mat". Any reviews on this as well? I just need to know how effective it is and also which is better? Your kind inputs are really appreciated! Mooooooooooooo ↡ Advertisement Link to post Share on other sites More sharing options...
Bobcatsysop Neutral Newbie July 14, 2006 Share July 14, 2006 Hi Bro, I'm using Silent SP Spec1 and Spec2 materials when they first launch their SP products to Nissan Club and also promoted by Stamford Tyres during that time. I'm one of those first few that installed it. Dunno if the same materials are currently being used and if they are the same materials, then those are good ones imported from Japan previously. Later I heard they have materials from Korea also. If you want to know the effectiveness of the Silent SP, you can sit in my car during the weekly Wed ICE meetup to listen. I did the full car SP except the firewall. Link to post Share on other sites More sharing options...
Mooscenic 1st Gear July 14, 2006 Author Share July 14, 2006 Hi there, Thank you so much for the great info!!! Well not too sure here the sheet Silent takes from. Also can't seem to find anyone carrying Dynamat Extreme... Moooooooooooo Link to post Share on other sites More sharing options...
Bobcatsysop Neutral Newbie July 14, 2006 Share July 14, 2006 Hi Bro, There is another thread on the subject that you are asking. Please check it out there or click here. Link to post Share on other sites More sharing options...
Wankie Clutched July 14, 2006 Share July 14, 2006 Dynamat Extreme? Try Aeon Customs at 494 Changi Rd, look for Eddie. Link to post Share on other sites More sharing options...
Mooscenic 1st Gear July 14, 2006 Author Share July 14, 2006 Ya i know.. I'm in the other thread, after starting this thread.. Oops! However the contacts in the other thread is no longer around (Close shop already). Moooooooo Link to post Share on other sites More sharing options...
Mooscenic 1st Gear July 14, 2006 Author Share July 14, 2006 Oh Wankie, Thanks! Do you happen to have the contacts as well??? Mooooooooo Link to post Share on other sites More sharing options...
Wankie Clutched July 15, 2006 Share July 15, 2006 Moo, 6242 0970. Link to post Share on other sites More sharing options...
Loaded Neutral Newbie August 21, 2006 Share August 21, 2006 Hi Moo I am a new comer to ICE, looking for Sound Insulation for my whole car too. Have you done up your car? How was it, any recommendation for me? Regards Link to post Share on other sites More sharing options...
User12343 Clutched August 21, 2006 Share August 21, 2006 (edited) first and foremost, SPing the entire car requires the interior of the car to be stripped to the bare metal, which to some might feel heartpain.... SPing the entire car can easily run into the thousand-dollar mark for quality materials.... Edited August 21, 2006 by User12343 Link to post Share on other sites More sharing options...
Loaded Neutral Newbie August 22, 2006 Share August 22, 2006 Any recommendation you have, I could hear Engine and Wind noises coming from the front. Thank you and look forward to hearing from you soon. Link to post Share on other sites More sharing options...
User12343 Clutched August 22, 2006 Share August 22, 2006 (edited) if it's wind noise u hearing, then no amount of SP of the car can help reduce tat. windnoise is caused by those rubber linings that interface with the glass. and tink there's nothing u can do. if it's road noise, standard SP'ing still can. if it's engine noise, unless u get the installer to entirely strip off the dash board (steering wheel, glove box, aircon all removed) until u see the bare metal and SP, else it also wont help. somemore such extensive stripping down is a big project and risk the installer has to take. also dun forget that SP material works by mass-loading the panels of the floor board and doorskins. and hence makes ur car heavier => higher FC. Edited August 22, 2006 by User12343 Link to post Share on other sites More sharing options...
Spec131 Neutral Newbie September 17, 2006 Share September 17, 2006 hi bro check us out at www.silent.com.sg cheers Link to post Share on other sites More sharing options...
Turtleswift Neutral Newbie September 18, 2006 Share September 18, 2006 If u really 1 2 sound proof ur 4 door, u might 1 2 try tis way cause it helps n lots of different for my car(swift PI) 1)Most outer layer 1 coat. Middle of door divider,1 coat. Then d inside of d door panel itsef try 2 fix 1 coat of sound proof bitumen material follwed by black thin layer of sound insulator then another 1 coat of hot drying type sound proof(accumat) over lap d black sound insulator sponge. Link to post Share on other sites More sharing options...
Room430 Neutral Newbie September 20, 2006 Share September 20, 2006 Does anyone know any reliable free lance guy who can do a good job in sound proofing works? I'm looking for someone who is willing to use the materials I buy. Most I know insist of using theirs. Link to post Share on other sites More sharing options...
Turtleswift Neutral Newbie September 22, 2006 Share September 22, 2006 Bro room430, U might 1 2 check ur p msg. Thanks.... Link to post Share on other sites More sharing options...
Boring Neutral Newbie September 22, 2006 Share September 22, 2006 You can check with sin kit whether they want to do SP with your material. If you want to get SP material you can approach maverick713. Link to post Share on other sites More sharing options...
Room430 Neutral Newbie September 22, 2006 Share September 22, 2006 Thanks bro, someone did recommend them to me before, but didn't know they accept customer's material instead of theirs. Ok, will call them to explore. ↡ Advertisement Link to post Share on other sites More sharing options...
Ho Hup Seng......Some good info for our Brudders
Whole car sound proof
Sound Proofing the car
Right side speakers no sound
Metal grinding sound on civic
Light clattering clicking sound when accelerating
