Danel Neutral Newbie March 14, 2016 Share March 14, 2016 the car unable to change gear properly. the engine indicator light will be ON and I can only move at gear 1 or 2. it will go on neutral on its own and the car will be really jerky when gear change. RPM will also revv during gear change. ↡ Advertisement Link to post Share on other sites More sharing options...
Friendstar Supercharged March 14, 2016 Share March 14, 2016 Just wondering. What made u choose a qq? Link to post Share on other sites More sharing options...
Epr0mlse 2nd Gear March 14, 2016 Share March 14, 2016 the car unable to change gear properly. the engine indicator light will be ON and I can only move at gear 1 or 2. it will go on neutral on its own and the car will be really jerky when gear change. RPM will also revv during gear change. "the engine indicator light will be ON and I can only move at gear 1 or 2." not forgetting that dreadful beep... I think the problem is the same as mine but mine only became obvious after 1.5 years of driving. In the end, I scrapped the car 1 year before the COE due as the cost to replace outweighs the bank settlement (it's actually cheaper to pay the bank than to replace). You can check with your dealer if they will replace it for you under the warranty but the selespeed is more like an electronic component rather than the physical gearbox. It controls the gear change. When it goes bonkers, it really goes.. You might be able to stretch and classify it together with the gearbox since the replacement is for the gearbox as well. That's why so expensive.. How long more for your QQ? Worth to go through the hassle for the replacement? Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 14, 2016 Share March 14, 2016 yes what i heard is the selespeed is not part of the gearbox. so im not sure if they able to cover under the warranty. another issue i'm facing is to proof to the dealer mechanic when i'm actually facing this gear shifting problem. because the problem comes every 1 week or 2. then i will try to drive it around to so called stabilise the RPM and gear movement till the engine indicator light goes off on its own. usually may take about 30mins or more to drive around at gear 1 or 2 till it goes back to normal again. Because the first time i faced this issue, i send for towing to the dealer workshop, the next day they told me there is nothing wrong with the car. So its not easy for me to explain the stressful condition when the car is having a problem. My QQ COE expires in Oct 2019. so it still has quite some time to go before scrapping :( Link to post Share on other sites More sharing options...
Epr0mlse 2nd Gear March 14, 2016 Share March 14, 2016 yes what i heard is the selespeed is not part of the gearbox. so im not sure if they able to cover under the warranty. another issue i'm facing is to proof to the dealer mechanic when i'm actually facing this gear shifting problem. because the problem comes every 1 week or 2. then i will try to drive it around to so called stabilise the RPM and gear movement till the engine indicator light goes off on its own. usually may take about 30mins or more to drive around at gear 1 or 2 till it goes back to normal again. Because the first time i faced this issue, i send for towing to the dealer workshop, the next day they told me there is nothing wrong with the car. So its not easy for me to explain the stressful condition when the car is having a problem. My QQ COE expires in Oct 2019. so it still has quite some time to go before scrapping :( It starts off like this, then the occurrences will be more frequent as time goes by. Your condition is not the worst yet but sadly that day will come eventually.. I didn't have warranty to fall back on so it was easier for me to make a decision. It will not be easy to prove the problem to your dealer since you can't tell when it will happen, and when it becomes too often, chances are the warranty would have lapsed.. Is your car on hire purchase or paid in full? Do some calculations and see how much is your paper value now. Did the mechanic also tell you that the replacement will not have warranty from their supplier? Not sure about now but that was one of the main factors that made me decide not to get the replacement. What if the replacement fails before your COE expires? Replace again? Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 14, 2016 Share March 14, 2016 oh yes you're right. I didn't ask about whether if there is any warranty from the supplier if i were to get a replacement for the selespeed. my car is on higher purchase. still servicing the bank loan currently. And my car is only driven for 3 mths or so. I actually changed quite a fair bit of components in the car actually. Timing belt, water pump, coolant hose, Throttle, new tyres and 14" rims. so i'm in a point of no return. If I were to consider selling back now after just 3mths, its gonna be a complete loss for me :( Link to post Share on other sites More sharing options...
Epr0mlse 2nd Gear March 14, 2016 Share March 14, 2016 oh yes you're right. I didn't ask about whether if there is any warranty from the supplier if i were to get a replacement for the selespeed. my car is on higher purchase. still servicing the bank loan currently. And my car is only driven for 3 mths or so. I actually changed quite a fair bit of components in the car actually. Timing belt, water pump, coolant hose, Throttle, new tyres and 14" rims. so i'm in a point of no return. If I were to consider selling back now after just 3mths, its gonna be a complete loss for me :( throttle? FYI, the brake fluid pump and valve are also likely to fail due to their strange designs.. I changed them one after another and only realise they were leaking when I couldn't feel my brakes biting.. 2 options I think: 1. Continue to drive and hope you are able to proof the fault to your dealer (and hope they will accept that is gearbox fault). 2. "Long pain might as well make it short pain"... I hope you don't have to take this option but from what I experienced, AMT is prone to suffer from this fate.. You mentioned 3 months, but I have came across a young man who was trying to sell his QQ after driving for only a month! His QQ has more owners than the car's age.. Somehow he managed to sell but that car was again up for sale within the same year.. Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 18, 2016 Share March 18, 2016 Thanks for the advice bro. But I think I will still continue to drive my QQ for some time. Planning to change the selespeed and hope the issue will resolve then :) Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 18, 2016 Share March 18, 2016 Anyone here can recommmend any reliable service/repair workshops in JB? Link to post Share on other sites More sharing options...
Forte3737 5th Gear March 18, 2016 Share March 18, 2016 Anyone here can recommmend any reliable service/repair workshops in JB?Hawk tayer Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 18, 2016 Share March 18, 2016 they do china car like Chery QQ? Link to post Share on other sites More sharing options...
Forte3737 5th Gear March 18, 2016 Share March 18, 2016 they do china car like Chery QQ?Of course Link to post Share on other sites More sharing options...
Danel Neutral Newbie March 18, 2016 Share March 18, 2016 u have the JB workshop address which you frequent? Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear March 22, 2016 Share March 22, 2016 Try : Century Auto Express & Trading 25E, Ground Floor, Jalan Dato Abdullah Tahir, 80300, Johor Bahru, Johor 80300 Malaysia Near York Hotel. For General Svc, Aircon Repair, Engine Mount, Suspension, O2sensor replacement, coolant pump replacement. You can bring your own parts. u have the JB workshop address which you frequent? Link to post Share on other sites More sharing options...
Shouyi 3rd Gear April 13, 2016 Share April 13, 2016 Hi guys, Would like to know your feedback on Vertex Automobile after sales service. Thanks! Link to post Share on other sites More sharing options...
Forte3737 5th Gear April 13, 2016 Share April 13, 2016 You own a QQ? Hi guys, Would like to know your feedback on Vertex Automobile after sales service. Thanks! Link to post Share on other sites More sharing options...
Shouyi 3rd Gear April 13, 2016 Share April 13, 2016 No, I don't. Just wanted some feedback on Vertex automobile as I am keen in a SEAT model which they intend to bring in. Link to post Share on other sites More sharing options...
Munch003 2nd Gear April 26, 2016 Share April 26, 2016 vertex bringing in SEAT? I noticed their showroom is undergoing renovation. Suspect they bringing in a new brand of car and dropping off Chery since it's not selling. They did bring in the old SEAT Toledo in the form of the Chery A168. My experience with them is horrible. A lot of customers bang table to get warranty claim. Gave up on their warranty and went JB for servicing. ↡ Advertisement Link to post Share on other sites More sharing options...
How to migrate aust , nz with only engineering deg ?
Any reviews on Brila or sierra glow?
Internet Trolls Bully Business Owners. Investigations Led To Disturbing Findings.
Anyone has reviews on Mercedes-Benz V-Class V250d Avantgarde
Car reviews by SGCM
Car reviews by SGCM
Chery A168, not too bad!
Can buy? Cheapest QQ?
Honda Crossroad - Reviews plse
