Hyun Neutral Newbie July 30, 2006 Share July 30, 2006 hi, what's the usual procedure when u buy rims and want it spray-painted? u pay up, bring them to spray-painting shop to be done, then bring back to rim shop to fit tyres ... or just let them handle everything also can hor. any1 knows the usual charges per rim or set for spraying, and any particular disadvantages of a sprayed rim? i suppose upon rubbing, the paint comes off and underneath colour can be seen. so best is to start with a similar-toned colour before spraying? ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 30, 2006 Share July 30, 2006 powder coat instead. much better (against chemicals that get on the rims) and longer lasting that painting. Link to post Share on other sites More sharing options...
Hyun Neutral Newbie July 30, 2006 Author Share July 30, 2006 oh ok, i donno about that one. so, same questions: any ballpark price? and the rim shop can handle everything or better i bring directly? thanks! Link to post Share on other sites More sharing options...
Sony 1st Gear July 30, 2006 Share July 30, 2006 Erm, is there any special reason why you want to spray paint? maybe you can get rim that have the colour you want. At least it's original. I have not spray paint my rim before I hear say, the price can range from $50 to $100 per rim. maybe you can try calling Yew Lip to check on the price since they are quite well-known but I heard that there's a long waiting period. Oh, a good paintjob will be in layers, so it's not so easy to get to the base... Link to post Share on other sites More sharing options...
Sony 1st Gear July 30, 2006 Share July 30, 2006 Bro, What is powder coat? can enlighten further? Thanks Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 30, 2006 Share July 30, 2006 sorry lazy to type http://en.wikipedia.org/wiki/Powder_coating Link to post Share on other sites More sharing options...
Sony 1st Gear July 30, 2006 Share July 30, 2006 (edited) Thanks.. Actually I'm the lazy one.. shd have just googled for it. Seems to be a much better method of coating the rim but I think the process will be costly. And if they heat up the rim, will it lead to other problem? Will the rim be weaken? Cheers Edited July 30, 2006 by Sony Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear July 30, 2006 Share July 30, 2006 nope, not hot enough for the metal to get soft. anyway thats the way non-cheapo rim manufacturers "colour" their rims. i bet you the taiwan/malaysian/korean/(slot your cheapo rim country of manufacture here) ones are painted Link to post Share on other sites More sharing options...
Sony 1st Gear July 30, 2006 Share July 30, 2006 Then better get those chrome type.. or those forged rim.. quality is there.. Link to post Share on other sites More sharing options...
Saggi 1st Gear August 1, 2006 Share August 1, 2006 contact Nelson at yong thye Seng at Sin Ming blk 18,unit 47.. i use to see them work on it. Tel 64532067.. of cse.. if you want all installation it can be done as neighour is tyres shop behind.. but they will recommend you to do it elsewhere is you dun mind a bit trouble to save $$ as the tyres shop charges is high Link to post Share on other sites More sharing options...
Str2 Neutral Newbie August 3, 2006 Share August 3, 2006 Hi All, I'm also thinking of changing my rim colour to Gun Metal/Titanium look. Any Bros who hv done before can help advise: a) what are the cons (does it chip-off easily?) b) will the heat (fm the brakes) cause the paint to crack/peel ? b) which spray paint shop with this experience? c) what are ball-park charges for 4 rims? I assume there will be minimum two coats of paint+ laquer/varnish to protect the paint. I think the normal spray paint shop don't do powder coating. Rgds/Str2 Link to post Share on other sites More sharing options...
Saggi 1st Gear August 4, 2006 Share August 4, 2006 wah... above question i cant reply you..must leave to the spray painting expert..sorry leh so for QUESTION AND B IS OKAY..NO AN ISSUE IF YOU DUN KNOCK YOUR RIM AGAINST THE KERB.. Link to post Share on other sites More sharing options...
Porker Turbocharged August 10, 2006 Share August 10, 2006 Powder coating is the best. You can choose the exact colour you want and also the tone and etc. Price? Not too sure but I can do it for free cos I know someone in the industry. Hehe Link to post Share on other sites More sharing options...
Yongwd 1st Gear April 20, 2007 Share April 20, 2007 hi, sorry to dig out this old thread. Do you have any recommendation to do powder coating for aluminium sports rims? Link to post Share on other sites More sharing options...
San_e_fen_ming Neutral Newbie April 22, 2007 Share April 22, 2007 So, may I know if spray paint rims or original colour rims better in value? Link to post Share on other sites More sharing options...
Ls430 Clutched April 22, 2007 Share April 22, 2007 hi, what's the usual procedure when u buy rims and want it spray-painted? u pay up, bring them to spray-painting shop to be done, then bring back to rim shop to fit tyres ... or just let them handle everything also can hor. any1 knows the usual charges per rim or set for spraying, and any particular disadvantages of a sprayed rim? i suppose upon rubbing, the paint comes off and underneath colour can be seen. so best is to start with a similar-toned colour before spraying? spray may peel ...look real ugly when that happens Link to post Share on other sites More sharing options...
Mercuri Neutral Newbie April 22, 2007 Share April 22, 2007 colours will be limited to the company's stock colour doing the powder coating. if you want some colour that they don't have, then you need to buy that colour for them to do the coating for you. usually the coating powder is only available in kilograms. And the supplier of the powder usually sell by minimium amount. so all in, it may be quite expensive to do powder coat unless they have the colour you want. price wise... i would think each rims will be at least $60-$80(estimate) cos have done some project on large scale. Link to post Share on other sites More sharing options...
Yongwd 1st Gear April 22, 2007 Share April 22, 2007 hi, do you have the contacts of the workshop / company that does powder coating? PM me if convenient. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
House painting
House painting
Shipping USA Rims
Shipping USA Rims
Please advise bodywork repair, spray painting workshop
Singapore Brand Rims VS China Brand Rims
