Mits_jc 5th Gear August 1, 2006 Share August 1, 2006 Fluids Fuel pump assembly removed completely Original fuel filter P/N. Comparison between new brake fluid and one that is 3 years old Breakdown of costs: Self Supplied Engine Oil CLTR 5W40 - $29.90 Oil Filter - $6.00 Brake Fluid (1L) - $7.35 Fuel Strainer - $39.90 Red Line MTL (2 quarts) - $46.00 From Riverview Labour - $100.00 Surcharge for Self Supplied items - $30.00 Total: $259.15 Time taken was approx. 3 hours. [/color] Comments: Could save more if I didn't change the manual transmission fluid. Changed it because KM used a wrong spec for it when they changed mine at 20k (wth they do that, I do not know.) Did not change coolant as well, which costs $20 for 4L at Riverview. During the servicing the mechanic, Ah Chin, went through with me the parts that he replaced and in some instances explaining in detail, especially the part on the fuel strainer. Upon re-assembly of the fuel pump back into the rear, a pressure gauge was used to test for the presence of any leakage (if there was, the fuel pump assembly was not tightened properly and cranking would take a longer time, or even be not possible.) Brake pads were also not required to be changed (still using day one originals) OEM Nissin ones cost $50.40, which I brought along just in case. After completion of servicing, the boss, Vincent took the car together with me for a drive to check for any anomalies. Finally, after everything was done, a car wash, including the engine bay, which left the insides spick and span. ↡ Advertisement Link to post Share on other sites More sharing options...
Long18 August 1, 2006 Share August 1, 2006 wow bro u gd... still take pic... Link to post Share on other sites More sharing options...
Cracker 1st Gear August 1, 2006 Share August 1, 2006 What will be the cost at Kah Motor ? Years ago for the same mileage done on my EK3, it was abt 350 dollars due to changing of brake pad which is abt 100 dollars ? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 2, 2006 Share August 2, 2006 p.s. pathetic lookin tyres and yea..time to change them Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 2, 2006 Author Share August 2, 2006 According to a guy from SHC who serviced his car at KM at 40k They replaced 1. Engine Oil 2. Oil Filter 3. Fuel Filter 4. check air con gas He didn't bring his own stuff, total added up to $355.00. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 2, 2006 Author Share August 2, 2006 yeah, still on stock ones from day 1..any recommendations? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear August 2, 2006 Share August 2, 2006 aspec db Link to post Share on other sites More sharing options...
Cracker 1st Gear August 2, 2006 Share August 2, 2006 those multiple of 20k servicing are considered "major" job by most car agents.. they will definitely have changed sth big in order to charge that price. Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 2, 2006 Author Share August 2, 2006 if you do not bring your own stuff that needs to be replaced, you are using what they give you at cut throat prices. Link to post Share on other sites More sharing options...
Teddi Neutral Newbie August 2, 2006 Share August 2, 2006 I did these too at 60K on my old Jap car Ford Laser change - engine oil - own supply - oil filter - own supply - fuel filter (below rear seat, coupled with fuel pump) - owm supply - change brake fluid & power steering fluid - mechanic supply - manual gear box oil about 3 ltrs (caltex) - mechanic supply - 4 wheel balancing & alignment - mechanic supply Total bill was also RM100 Link to post Share on other sites More sharing options...
Silverycivic Neutral Newbie August 2, 2006 Share August 2, 2006 Saw the screw that secure the rear seat remind me it had since missing during my 40k servicing at Kah motor, only discover at 67K km when removing the seat while doing soundproofing. Just wonder, how many owner do check the present of this screw after fuel filter replacement. Haiz Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 2, 2006 Author Share August 2, 2006 (edited) i think that's the problem of going back to the dealer for servicing. sometimes, they are not transparent enough to tell you what they are doing. you go away wondering if those ticked items in the checklist have been done or whether it's juz "for show". and to think you are paying that kind of steep prices. anyway the missing screw isn't really a safety issue, makes things easier if you need to remove your passenger seats for whatever reason since you do not need to find a tool to remove them, juz yank it out can already. Edited August 2, 2006 by Mits_jc Link to post Share on other sites More sharing options...
Mits_jc 5th Gear August 2, 2006 Author Share August 2, 2006 Price Guide for Honda Civic 2003 Servicing Parts [/color] Prices from Min Ghee: OEM Oil Filter P/N. 15400-PLC-004 - $6.50 OEM Fuel Strainer P/N. 16010-S5A-932 - $38.00 OEM Front Brake Pads (Nissin) P/N. 45022-S04-V10A - $48.00 OEM Airbox Filter Element - $28 OEM Aircon Filter (2) - $25 NGK Spark Plugs (Copper) ZFR6F-11 - $2.50/pc OEM Power Steering Fluid (1L) - $8.50 Fuchs Brake Fluid (Dot 4) (1L) - $7.00 Price listed excludes 5% GST Link to post Share on other sites More sharing options...
Daytona34 Neutral Newbie September 9, 2006 Share September 9, 2006 good info man Link to post Share on other sites More sharing options...
Weixiang_06 Clutched March 10, 2007 Share March 10, 2007 any more people with experience with riverview? mind chipping in? Link to post Share on other sites More sharing options...
Weixiang_06 Clutched March 13, 2007 Share March 13, 2007 anyone? Link to post Share on other sites More sharing options...
Hogster Neutral Newbie March 13, 2007 Share March 13, 2007 Did before as well, brought my own parts. Also spend about 200 over bucks for 40k servicing. They do a lot of Toyota cars so I guess it's not much an issue for them since yours is a Vios. No complains lah. Link to post Share on other sites More sharing options...
Trent892 Neutral Newbie March 13, 2007 Share March 13, 2007 A little off topic but the guy who used to do wheel alignment at Riverview (his name is Kenny, and he's not got his own place on the 4th floor now) is really quite excellent. a lot of trackies driving EVOs and WRXs go to him for our camber adjustment for track and street. hope this helps... cheers! ↡ Advertisement Link to post Share on other sites More sharing options...
Volvo Servicing
Volvo Servicing
RE :Jaguar Owners Servicing
