Tanly Neutral Newbie February 22, 2007 Share February 22, 2007 Can I use ATF on my manual car?Wat oil should I use?Driving Lancer ↡ Advertisement Link to post Share on other sites More sharing options...
Enotsol Neutral Newbie February 22, 2007 Share February 22, 2007 Automatic Transmission Fluid(ATF) is meant for auto cars. For manual transmission cars, stick to your engine oil. Link to post Share on other sites More sharing options...
Tanly Neutral Newbie February 22, 2007 Author Share February 22, 2007 Err u sure manual gearbox use engine oil,thought transmission oil supposed to be thicker W60-75 instead of Engine oil W30-50? Link to post Share on other sites More sharing options...
Enotsol Neutral Newbie February 22, 2007 Share February 22, 2007 Yes sorry it's my mistake. You can read here under the section Maintenance. http://en.wikipedia.org/wiki/Manual_transmission Link to post Share on other sites More sharing options...
Ccssgm 1st Gear February 23, 2007 Share February 23, 2007 Use Gear Oil.......Workshop will hav it..... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear February 23, 2007 Share February 23, 2007 I know Honda cars can use normal engine oil as gearbox oil. The required viscosity is very thin. Use to use Mobil 1 for my Honda Link to post Share on other sites More sharing options...
Acaj Neutral Newbie February 23, 2007 Share February 23, 2007 Manual transmission oil can use up to 10 years. so normally No change oil.... Link to post Share on other sites More sharing options...
Apollo 1st Gear February 23, 2007 Share February 23, 2007 ya right... last time i drive until dry. all leak out. the feller take out nut and show me. gasket leaked. no oil also no problem... FC a bit higher only. Link to post Share on other sites More sharing options...
Tanly Neutral Newbie February 23, 2007 Author Share February 23, 2007 err we toking abt gearbox oil here,not engine oil :-) Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 23, 2007 Share February 23, 2007 Can I use ATF on my manual car?Wat oil should I use?Driving Lancer It actually feels better using ATF, but you'll kill the syncros. Theres MTF for manual cars. Link to post Share on other sites More sharing options...
Trex101 3rd Gear February 24, 2007 Share February 24, 2007 Yes, most car need delicated MTF (GL-4 or GL-5) for their manual gear box but some GM car actually recommend ATF fluid for their manual gearbox. There's only one type of ATF that so strong that it actually meets GL-4 manual gearbox spec, RL D4 ATF & RL HT ATF. Link to post Share on other sites More sharing options...
Nothingtodo 1st Gear February 24, 2007 Share February 24, 2007 Hv nvr change my Manual Gearbox oil before (5yrs liao). No need to change if not necessary. Use MTF instead of ATF. they don't separate the 2 types for no reason. Link to post Share on other sites More sharing options...
Apollo 1st Gear February 24, 2007 Share February 24, 2007 ya... gearbox oil lor. Link to post Share on other sites More sharing options...
Tanly Neutral Newbie February 24, 2007 Author Share February 24, 2007 But u toking abt gasket leak rite?Gearbox has gasket? Link to post Share on other sites More sharing options...
Decibel Neutral Newbie February 24, 2007 Share February 24, 2007 Of course! Link to post Share on other sites More sharing options...
Apollo 1st Gear February 24, 2007 Share February 24, 2007 not gasket arh? oh........... then must be casket.... Link to post Share on other sites More sharing options...
Memel Neutral Newbie February 24, 2007 Share February 24, 2007 Go jaybee change manual gear oil so cheap cost u only RM15 only any workshop.. Link to post Share on other sites More sharing options...
Lengendcf 1st Gear February 24, 2007 Share February 24, 2007 I know Honda cars can use normal engine oil as gearbox oil. The required viscosity is very thin. Use to use Mobil 1 for my Honda Correct last time driving EK Series civic. Backside itchy, go and change the transmission oil. Workshop use gear oil. Suddenly the changing of gear became very rough. Drive back to workshop, drain out the oil and top up with brake oil. Yes brake oil, think the vis grade is just nice for the transmission. ↡ Advertisement Link to post Share on other sites More sharing options...
BMW M Cars Are Done With DCTs, and Soon, Manuals Too
Looking for a manual car because real men use three pedals!
Mother of all Avian Influenza * (H*N*)
Acceleration -- CVT vs auto
Clutch for Volvo V40 T4 2013 Price?
Volkswagen Announces Recall for DSG Transmission
To those driving manual cars
