Kieran1975 1st Gear April 25, 2007 Share April 25, 2007 Hi guys, do you change your tyres by mileage or years? My shoes almost going to be 2 years old and has already clocked 40K. Still look new and has about at least 60% of the thread left. Do you think it is necessary to change? ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 25, 2007 Share April 25, 2007 (edited) Generally is like 2 years or 40K whichever comes first However, some Bros here judge based on the thread marking indicator on the tyre Edited April 25, 2007 by Mzrmazda3 Link to post Share on other sites More sharing options...
Toyo 1st Gear April 25, 2007 Share April 25, 2007 yr tire compound may have been hardened by now. better to change ASAP, no point saving money on tires Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 25, 2007 Share April 25, 2007 It may be the inside that is worn out. That was what happened to mine. I tot still new but still decided to change then when change tyre that time inside botak Link to post Share on other sites More sharing options...
Route88 2nd Gear April 25, 2007 Share April 25, 2007 You better change,rubber compound can hardened,thus loosing its grip Link to post Share on other sites More sharing options...
Silver_blade Turbocharged April 25, 2007 Share April 25, 2007 Agree with you. It's either 40,000km or 2yrs. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear April 25, 2007 Share April 25, 2007 2 Years....Change Better.....Rubber Harden...... Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 25, 2007 Share April 25, 2007 [reply] That was what happened to mine. I tot still new but still decided to change then when change tyre that time inside botak Bro, care to elaborate that you meant inside botak? Do you mean the thread pattern inner side worn out, or after removing the tyre internal something worn out? If it is thread pattern inner side worn out likely its the wheel alignment need to adjust.... Link to post Share on other sites More sharing options...
Octopus 3rd Gear April 25, 2007 Share April 25, 2007 Hi guys, do you change your tyres by mileage or years? My shoes almost going to be 2 years old and has already clocked 40K. Still look new and has about at least 60% of the thread left. Do you think it is necessary to change? I think general guideline is around 2 years or 40k km..... Or alternative you can try a few hard braking in wet and dry road to confirm the grip, but do the hard braking safely, watch out for other fellow drivers.... Link to post Share on other sites More sharing options...
Kieran1975 1st Gear April 25, 2007 Author Share April 25, 2007 Any bro's can recommend a good set of comfort and quiet 205/55/R16 tyre? My budget is not more than $500. Around $125 per pcs. Link to post Share on other sites More sharing options...
Chemz Clutched April 25, 2007 Share April 25, 2007 no worries mate, my tires have been on for 2yrs too, 41k km and going strong, still got plenty of thread left. usually i run till it goes bald totally, slightly more than than the wear indicator. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear April 26, 2007 Share April 26, 2007 Agree with you. It's either 40,000km or 2yrs. Yeah Bro Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 26, 2007 Share April 26, 2007 thread pattern worn out. cuz i 1yr+ never rotate tyres Link to post Share on other sites More sharing options...
RadX Moderator April 26, 2007 Share April 26, 2007 Hi guys, do you change your tyres by mileage or years? My shoes almost going to be 2 years old and has already clocked 40K. Still look new and has about at least 60% of the thread left. Do you think it is necessary to change? advisable to go by years as by 2 yrs, ur rubber hardeneed.....braking would be affected Link to post Share on other sites More sharing options...
Elantrahatch Neutral Newbie April 28, 2007 Share April 28, 2007 Yup, same goes for me. My BFG just passed 2 years in Feb 07 but still got a lot of thread left. Think at least use until a bit botak then change. otherwise, very siong... ↡ Advertisement Link to post Share on other sites More sharing options...
My huat ah mileage....
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
