  • Search this thread
  • Reply to this topic
58 replies to this topic | 25 praises
#1
Posted 17 May 2007 - 07:14 PM
Limlien
  • THREAD STARTER
  • Limlien
    4th Gear
    Author Image
    899
Hi All,
I did like to find out if anyone have used before cxxxxxe engine oil.
I know it is lowly price and as the saying goes good things not cheap and cheap things not good.
However i believe there are quite a number of people using them and if it's really lousy i think carefour wont want to bring in to tanish their name.
Just like to know if anyone have any experience with the oil on a turbo engine?? I am thinking of using it for say another 7,500 km only after which i will need to do a oil change.
Any opinions or feedbacks?
#2
Posted 17 May 2007 - 07:21 PM
Porche
  • Premium member
    Porche
    Supercharged
    Author Image
    5,564
juz normal oil...works! i'm on this oil since my 4th car, nw currently using it on my current car. i won't say its good, but its normal and works. But i drained at 5K, normal can tahan abt 6-7K.
#3
Posted 17 May 2007 - 07:36 PM
Ccssgm
  • Ccssgm
    NOS-ed
    Author Image
    11,844
做人要讲道德,做事要讲效率。
讲道德是为了对的起自己的良心,讲效率是为了对的起自己的生命。
无论那一方面都充分体现尊重二字。
#4
Posted 17 May 2007 - 09:48 PM
Slowpoke156
  • Slowpoke156
    3rd Gear
    Author Image
    362
What car are you driving? If it's turbo, you're asking for it. Do you know that your turbo uses both engine oil and water to cool itself? Cheap oils break down so fast under extreme temperatures, your turbo will just cook itself to death. Not to mention when the oil starts choking up at the oil pipes leading away from the turbo when you turn off the engine. Slowly you will get no oil and before you know it, bye bye turbo. it can happen as fast as 3000km. Try it! laugh.gif
If NA, I would still use a premium brand. Carrefour is a retail center, not a car workshop. They will sell whatever makes money, as long as it's a product.
#5
Posted 17 May 2007 - 10:07 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
Did you get the fully synthetic version? If so it should be MB229.3 compliant which means its long drain interval. Think its 15k or maybe 20k???
But anyway its cheap, so i think its affordable to give it some discount on its claim. And so I'm still changing at 10k. But I see no wrong at all for those who change at 5 or 6k.
I think of it like changing underwear hehee laugh.gif Some thinks 1 day 3 piece ok cos they don't mind paying more for washing and nothing wrong to be cleaner / safer if its cheap to do so.
Btw somtimes those branded companies may also have hao2 siao2 claims. ie Laibena blackcurrent drink in NZland was found to have almost no vitamin C. Last time the expensive Abortt baby milk drink was also found to have misleading claims. So now I also give some discounts to big brands.
#6
Posted 17 May 2007 - 10:12 PM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,514
I've read some UOA for the 5w40 in NA engines.... it shears from w40 to become a w30. FYI.
#7
Posted 17 May 2007 - 10:14 PM
Furrynadz
  • Premium member
    Furrynadz
    Author Image
    8,363
u got balls
#8
Posted 17 May 2007 - 10:23 PM
Law_ong
  • Law_ong
    NOS-ed
    Author Image
    12,474
its a normal oil that serve its purpose. affordability that you can change it at very close intervals. not recommendable for super cars. do a search and check on what the results the bros have got from using this brand comparing to the others..
Ai Hwa Chia Dio Ai Hwa Song Song if Ai Hwa Chia yet gonna shrimp & save might as well go and buy Kar Chia
#9
Posted 17 May 2007 - 11:00 PM
Slowpoke156
  • Slowpoke156
    3rd Gear
    Author Image
    362
Wrong. At elevated temperatures, lower grade oils offer zero protection, they are almost like water. You don't have to wait for oil to break down for damage to be done.
#10
Posted 17 May 2007 - 11:04 PM
Limlien
  • THREAD STARTER
  • Limlien
    4th Gear
    Author Image
    899
Thanks for all the informations..
I gather that i shouldnt save any money for the engine oil.. hiaz..
#11
Posted 17 May 2007 - 11:09 PM
Porche
  • Premium member
    Porche
    Supercharged
    Author Image
    5,564
i'm using 5W40 synthetic, thin quite fast after 5k...that's y i drain at 5K....anyway cheap, use it as tonic lor laugh.gif
#12
Posted 17 May 2007 - 11:50 PM
Lokech34
  • Premium member
    Lokech34
    3rd Gear
    Author Image
    458
hi there,
the oil cannot last until 10K? even if it is a fully syn type?
#13
Posted 18 May 2007 - 12:29 AM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
What was wrong? What do you mean by lower grade? Or do you mean lower viscosity? I think they got a few fully synthethics and the one I used is also the 5w-40.
I doubt a 5w-40 oil will thin until 20 instantaneously. Thinning is common and gradual for all oil. Anyway I'm no oilxpert. Also there was some discussion by our oil guru about some testing of the oil grade after every K or something? If tests really show that this oil thins very quickly, I doubt it can retain the MB229.3 specs. Or maybe it's the same case with the laibena or abortt baby formula milk?
I'm not saying that it's a better oil than any laibena oil. But I think it's cheap given the specs. It just makes economical sense even if you discount the oil change interval.
Anyway, MB229.3 is a standard by MB. Not sure whats the conditions they used. Maybe they only tested it based on MB NA engines. wink.gif
#14
Posted 18 May 2007 - 12:35 AM
Slowpoke156
  • Slowpoke156
    3rd Gear
    Author Image
    362
I will not go into a detailed explanation of oil properties. But to answer your question, yes, oil WILL thin to almost water like viscosity instantaneously if it hits elevated temperatures. This is a very real problem in performance and turbo/supercharged cars.
And for goodness sake, specs are to be used a a general guide, not a definitive formula. Oils can be engineered to pass lab tests but not real world use. Likewise for ENCAP safety ratings. Cars can be engineered to pass exams but perform bloody poorly in real life accidents. This is called exam smart.
Edited by Slowpoke156, 18 May 2007 - 12:38 AM.
#15
Posted 18 May 2007 - 12:59 AM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
Maybe it's true.
I might have been a victim myself unwittingly. I've always drank alot of laibena myself and always gave them to my kids too. They always claim they have this and that vitamins. Maybe it's all boosheet. Now I'm in a dilemma. Which other famous brand is not snake oil?
Back to the car topic. I believe you totally. My friend who works in sumitomo once told me that those tyres used in races are expended in minutes. Can use for few minutes and throw away. Extreme high performance races. So it could be the same with oil when you are talking about the extreme. Shell Helix Ultra is good for 1 time use only if you are talking about F1 races. It's used like disposable underwear.
I drove a cheap E15ET last time. I joined a E15ET community last time and some of them are very hard core and crazy. But many also used recycled oil such as Mobil 1. But no one give a damn coz recycled oil can be very high quality.
All depends on the context. If you drive your car like F1 or F1.5 then even Shell Helix Ultra will not last 5K.
#16
Posted 18 May 2007 - 05:06 AM
PointyEwe
  • PointyEwe
    3rd Gear
    Author Image
    400
All newtonian fluids will drop in viscosities at higher temperature, including water.
I've used cxxxxxe on my Octavia for more than 5 years, drain at 15k, fc > 15km/l, absolutely no engine problem.
Those who drive like a track driver would anyway have to drain at shorter interval, be it cheap oil or expensive oil.
Edited by PointyEwe, 18 May 2007 - 05:07 AM.
God gives us alcohol as a social lubricant.
Makes Men brave, Makes Women loose
#17
Posted 18 May 2007 - 05:48 PM
Fluffy
  • Fluffy
    5th Gear
    Author Image
    1,802
Hi All,
you can use this oil. it meets VW 502 requirements.
i don't know what the other guys are saying....
Edited by Fluffy, 18 May 2007 - 05:48 PM.
#18
Posted 18 May 2007 - 08:16 PM
Darth_mel
  • Darth_mel
    Supercharged
    Author Image
    5,961
I use this oil on my car a couple of times with no problems at all. I drive heavily as well.
Even the semi-synth 5w30 is just as good.
_________________________________________
Make : Kia Magentis (Silver)
男人有钱会变坏,女人变坏会有钱。
http://darthmel.blogspot.com/
#19
Posted 18 May 2007 - 09:36 PM
Kianbeng
  • Premium member
    Kianbeng
    6th Gear
    Author Image
    4,029
#20
Posted 18 May 2007 - 09:58 PM
Eavr4
  • Eavr4
    3rd Gear
    Author Image
    412
Hello ALL
To be fair, the oil is really cheap.
Personally dun feel or see much problem with this oil as I'd been using the fully synthetic 5w-40 for over 3 yrs oredi (Turbo and NA applications)
Turbo Applications (4000km service interval)
1) Galant VR4 - 2.5L Twin turbo
2) Legacy GT - 2.0L Turbo
NA Applications (6000km Service interval)
1) Odyssey - 3.0L V6
2) Stream - 1.8L
Usage/Driving behaviour/Performance of my cars, dun think those who know me would need further explainations.
EA
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Carlube, engine
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
