Minmax Neutral Newbie June 4, 2007 Share June 4, 2007 (edited) I was travelling around 90km/h, suddenly my meter show 0km/h. then from 0 went to 90 and back to 0 again. i slow down but still the same, show my speed for 1 sec and drop back to 0. please view this video. anyone can help me out by telling me wat happen? do i need to change the whole speedomter? thanks! speedometer.3gp Edited June 4, 2007 by Minmax ↡ Advertisement Link to post Share on other sites More sharing options...
Andrefoo Neutral Newbie June 4, 2007 Share June 4, 2007 Wiring probably. Just go to a workshop, tell them the problem and it should be quite simple to fix. ------------------------ Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 4, 2007 Author Share June 4, 2007 thanks for replying, but i didnt do anything. out of the blue like that. haiz. whats the cost like? Link to post Share on other sites More sharing options...
Beei 1st Gear June 4, 2007 Share June 4, 2007 Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 Dont know is my needle broken or wat. but looks like its not the needle problem, cos my mileage meter also not working liao. Link to post Share on other sites More sharing options...
Watwheels Supersonic June 5, 2007 Share June 5, 2007 Get the whole thing replaced. Your car still under warranty? Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 no, coe car. Link to post Share on other sites More sharing options...
Chisiang 2nd Gear June 5, 2007 Share June 5, 2007 common with older car. lucky if it is just the motor behind the dial that is faulty. Unlucky if it is the speed sensor which cost most. Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 any place that can recommend to do such stuff? wats the pricing like? Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie June 5, 2007 Share June 5, 2007 It would be interesting if this happened to the fuel gauge needle. Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 5, 2007 Share June 5, 2007 Looks like a intermintent problem - not sure what type of speedometer system you have. Suggest you check wheel speed sensor pick-up for dirts, grease etc. The other possiblity is loose fuse/poor wire connection / dry soldering at circuit board. Link to post Share on other sites More sharing options...
Jusnel 6th Gear June 5, 2007 Share June 5, 2007 COE car is like tat.... last time my COE car also got this problem.... only once in blue moon, it will happen... mine can be 0 in the whole journey. then next day, ok liao.... or travel halfway, the needle drop to 0 and stay there for 5-15mins, then it goes up to normal speed readings i just ignore it. as long the car can move on the road, engine no problem, i will be happy. to do this repair can be quite costly, because they have to take out the dashboard to check where is the faulty part... labour cost will kill you here. the spare part can be cheap. Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 where is the check wheel speed sensor??? my car long time nv wash liao. maybe its this problem.. if it going to be ex, possible to DIY? Link to post Share on other sites More sharing options...
Nothingtodo 1st Gear June 5, 2007 Share June 5, 2007 not possible to DIY. Better get it done by Mech. It could be due to wiring, or the linkage from your speedo to the engine block. Should not cost more than $150. So long your RPM meter working, no worries lah. Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 150 .... Link to post Share on other sites More sharing options...
Nothingtodo 1st Gear June 5, 2007 Share June 5, 2007 150 too Ex? anyway, I just guess the cost only. I face this problem with my 20yrs old car last time. Chked around to repair but end up buying a new car I can PM you my trusty old electrical guy if u like. Let him chk yr problem w/o obligation. Link to post Share on other sites More sharing options...
Minmax Neutral Newbie June 5, 2007 Author Share June 5, 2007 ok pm me pls ↡ Advertisement Link to post Share on other sites More sharing options...
Help with STA report remarks
HELP! Upstairs neighbour causing sleepness nights
Exporting Gmail Contacts (Pls help)
MOM help FTs look for jobs ?
MyResponder app to call SCDF
