Trex101 3rd Gear August 12, 2007 Share August 12, 2007 Yes, it does even though it didn't state on the bottle. Check out the product data sheet. http://www.schaefferoil.com/datapdf/204SAT.pdf ↡ Advertisement Link to post Share on other sites More sharing options...
EventH 1st Gear August 12, 2007 Share August 12, 2007 some say that using the drain method, half of the ATF stays in the torque convertor. Did you measure the amount that comes out before pouring the new atf inside? I think my mech might have over filled abit the last time round. He always pour in the 4L of T-IV. What is the best(most accurate) way to check ATF level? Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 12, 2007 Share August 12, 2007 Check you ATF when it's hot and keep the engine on too. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear August 12, 2007 Share August 12, 2007 (edited) Check your car manual. Mine is 2.8L for ATF, hence 3 quarts. Some car design is when you refill the ATF, it'll continue to fill till it's full then it'll overflow as the opening is sideways at max level (hence not possible to overfill), not top as per engine oil (not the diptick check as per engine oil). Drain is similar to engine oil, it'll more or less be drained. Edited August 12, 2007 by Vblaster_w211 Link to post Share on other sites More sharing options...
Upguy1 Clutched August 12, 2007 Author Share August 12, 2007 the bottle label warned that it is not to be used in vehicles where toyota type IV required Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 12, 2007 Share August 12, 2007 I ask before already, they (Schaeffer) still use the old "Synthetic blend label" in their 204SAT till now because they have alot of old label stocks printed. They have to used up the old label first before using the new fully syn label. This is the stupidest reason i ever heard Link to post Share on other sites More sharing options...
Upguy1 Clutched August 12, 2007 Author Share August 12, 2007 ok thats good to hear....so u mean its fully synthetic ??? i always thought its a blend Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 12, 2007 Share August 12, 2007 I just cannot buy their explanation. Link to post Share on other sites More sharing options...
Trex101 3rd Gear August 13, 2007 Share August 13, 2007 (edited) Yah, me too. Edited August 13, 2007 by Trex101 Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 13, 2007 Share August 13, 2007 I wonder if in reality, they have not excess labels but excess stock of the old blended oil which they must clear b4 they bring out the newer fully syn oil? Link to post Share on other sites More sharing options...
Samwng 1st Gear November 22, 2010 Share November 22, 2010 Hi all, Where can I get the Toyota ATF Type T-IV for $32 dollars ? Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 22, 2010 Share November 22, 2010 Hi all, Where can I get the Toyota ATF Type T-IV for $32 dollars ? You can check with toyota stockists, Fong Tat, Ric Tat and Min Ghee etc. Google for their contact numbers and call them for pricing. Standard cash terms on the spot. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
