S390u Neutral Newbie November 2, 2007 Share November 2, 2007 (edited) Hi All, experience inside my head light there is some condensed water vapour after heavy rain ,,,any one expert here can help ,,,appreciate kind comments Edited November 2, 2007 by S390u ↡ Advertisement Link to post Share on other sites More sharing options...
Tanjkp Clutched November 2, 2007 Share November 2, 2007 (edited) Ride still under warranty ? Can ask to change mah. Else liao. Ever faced it just after warranty. So boh pian DIY dry it by blowing hot air to dry out and vaccum also to suck out vapour. After dried out use silicon to seal around where the front cover and back meet. Edited November 2, 2007 by Tanjkp Link to post Share on other sites More sharing options...
Ronnchee Clutched November 2, 2007 Share November 2, 2007 Time to change to HID or Angel eyes !! Link to post Share on other sites More sharing options...
S390u Neutral Newbie November 2, 2007 Author Share November 2, 2007 Thanks bro...my ride just after warranty..even DIY from where I can suckout the water ??? thinking to change the headlight.. Link to post Share on other sites More sharing options...
Sony 1st Gear November 2, 2007 Share November 2, 2007 (edited) what car is that? can try taking the headlamp light blub out and remove the water from that hole. or try pouring more water in there and you can have a fish tank. While you try to remove the water, trace the source of where the water enter. If it's serious, it will affect your car's electical system Edited November 2, 2007 by Sony Link to post Share on other sites More sharing options...
S390u Neutral Newbie November 3, 2007 Author Share November 3, 2007 ES5 honda. it is not that bad and i believe it is not crack of headlight. after rain, the headlight goes blur because of condense water vapour inside. Link to post Share on other sites More sharing options...
Sony 1st Gear November 3, 2007 Share November 3, 2007 if it's just vapour.. maybe you can just remove the light bulb and let it air out Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie November 3, 2007 Share November 3, 2007 HAve a close look at the rubber seals around it. Make sure they are still intact. Sometimes, it's just the rubber cover housing that is not fitted tightly. ↡ Advertisement Link to post Share on other sites More sharing options...
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
