Fitzy Neutral Newbie March 14, 2008 Share March 14, 2008 Hi bros, just a question, what solvent could be use safety to clean TB? Is carb cleaner safe? ↡ Advertisement Link to post Share on other sites More sharing options...
Adawang 1st Gear March 14, 2008 Share March 14, 2008 (edited) had bad exp with carb cleaner mech used it to clean TB after some months, opened to check and found TB all black with soot best is to dismantle and wipe clean. Edited March 14, 2008 by Adawang Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 14, 2008 Share March 14, 2008 Carb cleaner is good enough Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 14, 2008 Share March 14, 2008 after some months sure got soot one, it's due to the blow-by of the PCV system lah! That's the reason you need to clean the TB after sometime Link to post Share on other sites More sharing options...
Adawang 1st Gear March 14, 2008 Share March 14, 2008 but i ever dismantle before, on previous car, no soot leh puzzled Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 14, 2008 Share March 14, 2008 depends where the blow-by is connected, some is between TB and air fliter box, some is inside the air filter box and very close to the air filter with another sponge to catch the oil Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie March 14, 2008 Author Share March 14, 2008 Read on some website that carb cleaner are to strong but majority of people in sg does use carb cleaner to clean TB. Are the specific cleaner for throttle body or other mild solvent that could be use? Link to post Share on other sites More sharing options...
Adawang 1st Gear March 14, 2008 Share March 14, 2008 oic, thnks Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 15, 2008 Share March 15, 2008 As long as you don't soak the TB in a pail of Carb Cleaner can liao, just spray and wipe off the carbon/soot/oil deposit Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 15, 2008 Share March 15, 2008 no prob Link to post Share on other sites More sharing options...
Upguy1 Clutched March 15, 2008 Share March 15, 2008 TB must clean one meh?? i thought do not touch TB unless you want to zhng Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 15, 2008 Share March 15, 2008 Yes some Carb cleaner solution will damage the hot wire and coating on the throttle bore.Try using electronic contact cleaner Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 15, 2008 Share March 15, 2008 most of the engine nowadays have blow-by from the PCV, this normally will blow off oil fumes from the cam cover during high load (rpm) and will get coated onto the TB. Link to post Share on other sites More sharing options...
Linus Clutched March 15, 2008 Share March 15, 2008 yes ah kor, i use carb cleaner. works for my 323. after cleaning, the throttle is very responsive. Link to post Share on other sites More sharing options...
Vtim 3rd Gear March 15, 2008 Share March 15, 2008 (edited) of course, all the soot and dirt remove, flow is better. It'll be good if you enlarge the bore and smooth it out just like what I've done my ride now still N.A. but have already done IHE liao, just added MSD CDI last week have you read my thread http://www.mycarforum.com/forum/gforum.cgi...2268673#2268673 Edited March 15, 2008 by Vtim Link to post Share on other sites More sharing options...
Linus Clutched March 15, 2008 Share March 15, 2008 can polish with autosol ? poison poison... Link to post Share on other sites More sharing options...
Relagsingh 4th Gear March 15, 2008 Share March 15, 2008 Hi bros, just a question, what solvent could be use safety to clean TB? Is carb cleaner safe? juz use good ol' petrol... best liao. but dun smoke and clean at the same time! Link to post Share on other sites More sharing options...
Gunsnroses Neutral Newbie March 15, 2008 Share March 15, 2008 Can we dun remove whole TB to clean? Just remove front portion and spray spray inside. Of course all the dirt, oil,etc will go in but shd not be that harmful rite? ↡ Advertisement Link to post Share on other sites More sharing options...
Car carpet cleaning
Car carpet cleaning
Police investigating after body retrieved in waters off Merlion Park
Body Odour
Body Odour
😥Woman, in her 80s, keeps body of son, 54, in HDB flat for over a week after he passed away😥
Roomba - Vacuum Cleaning Robot (VCR)
Interior Cleaning
Interior Cleaning
What's Your Come Home SOP during COVID?
DIY cleaning throttle body
