  • Search this thread
  • Reply to this topic
38 replies to this topic | 32 praises
#1
Posted 25 March 2008 - 10:10 PM
F1fan
  • THREAD STARTER
  • F1fan
    3rd Gear
    Author Image
    264
hey guys, any recommendation of places to do tyre rotation and balancing? Normally how much will it cost?
#2
Posted 31 March 2008 - 03:06 PM
Owen_fan
  • Premium member
    Owen_fan
    5th Gear
    Author Image
    1,516
Just did my rotation & balancing at stamfort tyre last Friday, demage $16 wink.gif
#3
Posted 31 March 2008 - 03:08 PM
Damienic
  • Premium member
    Damienic
    NOS-ed
    Author Image
    10,316
I went 555 Upper Thomson Rd (inside Caltex station) to do. Cost $15.
#4
Posted 02 May 2014 - 07:41 PM
Divers
  • Premium member
    Divers
    3rd Gear
    Author Image
    355
Hi bros,
When I go for rotation and balancing, is it a must-do for shops to replace the old metal strips and replaced new ones.
Or is it depending on the balancing test?
I have done twice but the shops does change the metal strips? They just say still good. I am wondering if is it true?
Anyway my friend went to JB to do rotation and balancing. The shop will scraped off the old strips and replaced with new ones.
Edited by Divers, 02 May 2014 - 07:43 PM.
#5
Posted 05 May 2014 - 09:54 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
Hi bros,
frankly speaking the END result is the same , is the process is diff.
BUT the bottom line is result must be good first.
The process is the + point
just like heard some even wash your wheel before balance it and shining the tyre wall before mount on your car. [thumbsup]
#6
Posted 05 May 2014 - 10:16 AM
Beregond
  • Beregond
    NOS-ed
    Author Image
    17,370
Hi bros,
if u want to be fast, normally they dun balance first before scraping off the weight, first thing scrape off and balance, and stick.
but end result u see alot of leftover gum stuff on your rim, some time the weight is stick over the same area,
i doubt they will take their time slowly scrape off every bit of gum before sticking over.
some work shop, the first thing the do is balance first see result, if u have done your previous balanceing properly , this time round might still be 0,0. or maybe add or remove 1-2 weight.
#7
drivinghazard
  • Premium member
    drivinghazard
    3rd Gear
    Author Image
    344
Hi bros,
Usually the one that I go to will take cloth clean, then depend what is required, either remove the whole metal strip, leave it alone or add some more.
#8
Posted 05 May 2014 - 08:42 PM
Divers
  • Premium member
    Divers
    3rd Gear
    Author Image
    355
I have done the balancing plus rotation.
This shop I went to is indeed professional and good.
First he balance the tyre with the old weight on. Measure, scrap off old weights, put on new weights and balance again.
He did the same for all tyres. He also rotate the tyres for me and mentioned my rear tyres thicker, so he changed it to the front. He used a device to measure. As you mentioned 0,0 now then I understand what you are talking about.
Seriously, this is the first time I have done a "REAL" balancing. Good job. All 4 tyres S$20/-.
My ride really improved.
The previous shop I went to, just used his hand and turned the tyre on the machine. Saying, very good. nothing. Cheated my S$20/-
Edited by Divers, 05 May 2014 - 08:44 PM.
Tanyachua88 praised this
#9
Posted 05 May 2014 - 08:52 PM
Janling3
  • Premium member
    Janling3
    6th Gear
    Author Image
    3,604
I thought the exercise include alignment? Any general guide how often we do rotate, balance and/or alignment? Thank you
#10
Posted 05 May 2014 - 09:58 PM
Yhn
  • Premium member
    Yhn
    4th Gear
    Author Image
    964
Generally 8k to 10k km will do balancing and rotate tyres. This way tyre wears will be even.
As for wheel alignment, I will do it if I had drove over uneven road at higher speed, or knocked into curb, or if the tyres has uneven wear ( after checking under carriage for worn arm bushes etc )
Bicycle
Bike
Bus
Boat
Batmobile hopeful
#11
Posted 06 May 2014 - 09:46 AM
Johnnylim
  • Premium member
    Johnnylim
    5th Gear
    Author Image
    2,119
May I know where is the workshop? Thks!
#12
Posted 06 May 2014 - 11:14 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
wow TOP service
I wonder will the shop increase the service charges after the demand shoot up
#13
Posted 06 May 2014 - 11:25 AM
Janling3
  • Premium member
    Janling3
    6th Gear
    Author Image
    3,604
Thank you for the info bro Yhn. So is there any sign or symptom that the alignment is required, besides our ride driven over uneven road at higher speed, knock a curb, etc. ?
wow TOP service
This solely depends on the boss' business acumen.... [lipsrsealed]
#14
Posted 06 May 2014 - 11:33 AM
Tonydeath
  • Premium member
    Tonydeath
    4th Gear
    Author Image
    639
please share w us where is the workshop. tks u
I am a Fishmonger.
#15
Posted 06 May 2014 - 12:18 PM
Yhn
  • Premium member
    Yhn
    4th Gear
    Author Image
    964
Tyre Makan on its side is the most obvious sign, in my experiences.
Unknowningly going over pot holes esp in rural areas up country, I'll have the alignment checked. If tyres are due to change soon, then will do so after new set of tyres are replaced.
Usually alignment wouldn't go off if travel in our local roads.
Bicycle
Bike
Bus
Boat
Batmobile hopeful
#16
Posted 06 May 2014 - 07:14 PM
Divers
  • Premium member
    Divers
    3rd Gear
    Author Image
    355
http://www.sgcarmart...s.php?MID=14181
For sharing. FYI he is OMO.
#17
Posted 06 May 2014 - 08:18 PM
Divers
  • Premium member
    Divers
    3rd Gear
    Author Image
    355
To add on, this workshop is doing car servicing as well.
To be honest, his servicing price slightly a bit higher. maybe 10 to 20 dollars more.
He has package for servicing which includes tyre rotation and balancing.
But I guess he will be doing a real thorough checks.
#18
Posted 07 May 2014 - 10:56 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
Dear Divers
don't said ppl cheated you.
you requested for the balancing and did it before you?
at least service carried out and he said ok may be his machine show no out of balance and you hope that he remove old on and reattach the new one on the same spot?(funny right?)
any service rendered is subject to charges unless service provider offer FOC voluntarily
NO free lunch
#19
Posted 15 May 2014 - 10:48 PM
Tyrequeen
  • Premium member
    Tyrequeen
    1st Gear
    Author Image
    94
Hi Guys, we have made a rather long FAQ about-Tyres here at TyreQueen-How-To-Choose-Tyres (main guide) and we have included 6 sections at MyCarForum : We hope that you like them and found them useful, if there's any part that needs to be edited, I will truly appreciate if you could PM me and let me know :) - Eric C
When To Rotate My-Tyres & Rotation Patterns #5
http://www.TyreQueen.com <-- HOTLINE 63777777
http://www.Facebook.com/TyreQueen <-- LATEST TYRES PROMOTIONS
Over 20+ Brands of Tyres, Thousands of Tyres in stock, Sole distributor of Apollo & Vredestein Tyres
Tyres at discounted prices & get Amazing FREE Gifts!
#20
Posted 16 May 2014 - 10:38 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,749
Miss TQ, I think you may have missed out
correct me if I am wrong thankyou
tire puncture repair  and wheel alignment?
also kepo a bit check a few local tire distributors website
seems they may have also show your Company is not in their participation list
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Quick Reply
