Robo 2nd Gear April 1, 2008 Share April 1, 2008 Hi my Starlet Bros! I've been eyeing a set of Toyo T1R tyres for a long time liao. However after searching high and low calling like almost 20 shops enquiring for the specs im looking for I manage to get it from the distributor of toyo. (shopor warehouse is in paya ubi). anyways the spec im looking for quite odd lahz. its 195/55/14. the charbor told me the stock will be coming in coming monday from japan! but hor the price super pricey! its at $150 a pc. she told me to go down and find her she will be able to give a better price. ok.. i was wondering if any bros out there is interested in getting new legs for your ride. mayb u wont want the spec im looking for or even the same model but if we go down together we should be able to get a bulk discount. i will most probably only get it if the price is below $100 a pc. cuz $150 is a bit the crazy... i think i can get 16" with that price liao. so if ya all interested pls let me know den we can work it out. also pls reccommend me other brands that ya all think its good... a thousand thanks to ya all first!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Frost_s Neutral Newbie April 1, 2008 Share April 1, 2008 i got my T1Rs 195/55/15 for $105 bro. dun be a robert head!!! Link to post Share on other sites More sharing options...
Kingcopa 1st Gear April 1, 2008 Share April 1, 2008 too expensive for 14" Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie April 1, 2008 Share April 1, 2008 Dun get that tyre. It's way to expensive. Call me, I will advice u. Link to post Share on other sites More sharing options...
Gtturbo Neutral Newbie April 1, 2008 Share April 1, 2008 i got my 15" T1R at $100 from AMK industrial park 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged April 1, 2008 Share April 1, 2008 The dimension is not standard as compare to those 15 inches, which explain the higher price. Anyway I used this model before on my MX5, not bad! Link to post Share on other sites More sharing options...
Robo 2nd Gear April 1, 2008 Author Share April 1, 2008 wah bros. thanks for all the quick replies!!! appreciate it! anyways.. as wad Ody_2004 said... its not a standard size therefore explains the price. but cuz im using a 1E engine so i tot that its not advisable to change to a 15" and plus i also no budget for the rims. lol! plus heard alot of good reviews about this rubber. now slowly sourcing. was thinking of falken ZE326/512 or i might just get back the same model that im using now which is goodyear NCT5. most probably a lower profile one. cuz this tyre i would say not bad the grip on both wet and dry. starletgt bro i call in awhile.. just got back from lunch. Link to post Share on other sites More sharing options...
Kezg1 5th Gear April 1, 2008 Share April 1, 2008 It is too x....go and source around 1st Link to post Share on other sites More sharing options...
Robo 2nd Gear April 1, 2008 Author Share April 1, 2008 do u guys recommend any particular brands for 14"??? Link to post Share on other sites More sharing options...
Robo 2nd Gear April 1, 2008 Author Share April 1, 2008 am looking for good wet and dry. hopefully can last abt 50k Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged April 1, 2008 Share April 1, 2008 ZE326 cannot make it.. esp in the wet.. Link to post Share on other sites More sharing options...
Dionyeo Neutral Newbie April 1, 2008 Share April 1, 2008 Potenza RE-01R Falken RT215 Yokohama A048 all hvae 14inch =] Link to post Share on other sites More sharing options...
Kyojin 1st Gear April 1, 2008 Share April 1, 2008 odd size la dey! that's why so expensive... Original: 175/70-13 +1: 185/60-14 +2: 195/50-15 Perhaps you can try 185/60-14. 195/55-14 is almost 1% larger than original, but 185/60-14 is only 0.4% larger, which means it's a better fit and also means that it'll be easier to find/cheaper. food for thought. Link to post Share on other sites More sharing options...
Kyojin 1st Gear April 1, 2008 Share April 1, 2008 one word: ST115 i find that it's very well balanced tyre. excellent grip in both wet and dry conditions. it's comfortable and noise is acceptable. but do note that the road noise does get louder as the tyres wear out. it's price is also perhaps why it's such a popular tyre, the benefits i get is comparable to more expensive tyres (aka value for money). Link to post Share on other sites More sharing options...
Josephteo 1st Gear April 1, 2008 Share April 1, 2008 heard a lot of bad reviews of Falkens.... very slippery...so unless you want to be drift king...then maybe can get that... how abt GR80? Link to post Share on other sites More sharing options...
Kyojin 1st Gear April 1, 2008 Share April 1, 2008 that's utter rubbish. I swear by Falken ST115 (and ST512). grip is excellent in wet and dry. Link to post Share on other sites More sharing options...
Dynaway 1st Gear April 1, 2008 Share April 1, 2008 Hi my Starlet Bros! I've been eyeing a set of Toyo T1R tyres for a long time liao. However after searching high and low calling like almost 20 shops enquiring for the specs im looking for I manage to get it from the distributor of toyo. (shopor warehouse is in paya ubi). anyways the spec im looking for quite odd lahz. its 195/55/14. the charbor told me the stock will be coming in coming monday from japan! but hor the price super pricey! its at $150 a pc. she told me to go down and find her she will be able to give a better price. ok.. i was wondering if any bros out there is interested in getting new legs for your ride. mayb u wont want the spec im looking for or even the same model but if we go down together we should be able to get a bulk discount. i will most probably only get it if the price is below $100 a pc. cuz $150 is a bit the crazy... i think i can get 16" with that price liao. so if ya all interested pls let me know den we can work it out. also pls reccommend me other brands that ya all think its good... a thousand thanks to ya all first!!! if can bargain to abt $110 for the T1R i dun mind getting..... tats including i manage to find a set of Enkei RPF-01 rim for my car....... i'm currently on Federal 595 185/55R14 which i dun really recommend....but they are one bloody lasting tyre.... lol other 185/55R14 tyres in market to name a few, but may not be available in local stores Kumho KU31 - too bad i check with Binter, they dun bring in at all. asked the on placing special order, never reply me. Falken ZE512 - even got 195/45R14 Federal 595 Silverstone Type RR (semi-slick) - last time i ask is abt $150 each. may not be street legal n not safe for wet cond Continental ContiSportContact - 195/45R14, 185/50R14, 195/40R14 Continental ContiPremiumContact GT Radial Champiro BAX - i dare not use... http://www.stamfordtyres.com/tyres/falken/...alkenZE512.html http://www.stamfordtyres.com/tyres/contine...ortContact.html http://www.stamfordtyres.com/tyres/contine...iumContact.html http://www.globaltraco.com/product_detail....=18&subcatid=60 http://www.competitiontyres.com.sg/rt.php Link to post Share on other sites More sharing options...
Dynaway 1st Gear April 1, 2008 Share April 1, 2008 how fast have u travel in wet on the falkens???? 160km/h??? ↡ Advertisement Link to post Share on other sites More sharing options...
New Ford Mondeo
New Ford Mondeo
TOYO PROXES T1R
TOYO PROXES T1R
Parking against traffic flow...beware
Toyo tyres made in Japan
Toyo Proxes CF2
Toyo Proxes CF2
TOYO C1S
TOYO C1S
Facelift Mazda 6
Facelift Mazda 6
Which shop sells TOYO tyres and don't damage rims
