Perrier 1st Gear April 3, 2008 Share April 3, 2008 Quote from PIVOT website, http://pivotjp.com/information/frame-earth-e.html "When wishing to add an earth connection for new type car models which in order to control battery recharging have a "electrical current sensor" connected to the Minus battery terminal do not take the earth directly from the Minus terminal but rather from the earth connection on the body which is taken from the sensor. If earth is taken directly from the Minus terminal recharging control may not work properly and there is a possibility that performance will be adversely effected." Please visit the link for more information!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear April 3, 2008 Share April 3, 2008 why ah? Link to post Share on other sites More sharing options...
Friendstar Supercharged April 3, 2008 Share April 3, 2008 What ?!?!?!!? Link to post Share on other sites More sharing options...
Perrier 1st Gear April 3, 2008 Author Share April 3, 2008 Dunno leh, but you dun usually see them post this kinda things. Link to post Share on other sites More sharing options...
Nirxe Clutched April 6, 2008 Share April 6, 2008 (edited) Only the following car manufacturers affected is it? Toyota/Nissan/Mazda/Daihatsu/Non-Jap Car. How about the other makes? Eg. Suzuki Edited April 6, 2008 by Nirxe Link to post Share on other sites More sharing options...
Perrier 1st Gear April 6, 2008 Author Share April 6, 2008 Did you both to click on the link I provided? If yes, you should find your answer. Regards, Link to post Share on other sites More sharing options...
Nirxe Clutched April 6, 2008 Share April 6, 2008 Thanks for clarifying. Link to post Share on other sites More sharing options...
Davidcks 1st Gear April 6, 2008 Share April 6, 2008 Wah, so cars that has the electrical current sensor linked through the negative points are to connect after that. Cool man!!! thanks for the information. Now to check my car liao, to make sure correctly connected. Link to post Share on other sites More sharing options...
Qaz20 3rd Gear April 14, 2008 Share April 14, 2008 Good info... Link to post Share on other sites More sharing options...
Reno Neutral Newbie April 30, 2008 Share April 30, 2008 tks for the information. Link to post Share on other sites More sharing options...
Watwheels Supersonic April 30, 2008 Share April 30, 2008 (edited) why ah? Most likely the current will by-pass the sensor through one of the earthing cables. Cos current always take the shortest route. So current will travel which ever cable that has a smaller loop to close the circuit. Edited April 30, 2008 by Watwheels ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda EZ-6
2025 Mazda EZ-6
MAZDA 6
MAZDA 6
[Official] 2024 Lexus LBX
Toyota Corolla Cross
