Dwoon 1st Gear April 8, 2008 Share April 8, 2008 Did anyone notice that the the T-IV ATF is thicker than the Dexron III? I just did my full change of ATF and that is what I noticed. Hmmm.... or it is my eyes playing tricks... Its good though.... somehow, the engine sounds a tad quieter. Is there any reason why an ATF change might affect engine sound??? ↡ Advertisement Link to post Share on other sites More sharing options...
Copen 1st Gear October 22, 2010 Share October 22, 2010 Dug out an old thread regarding this ATF. Anyone know where can I get them from? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 22, 2010 Share October 22, 2010 almost every toyota parts dealer autobacs also Link to post Share on other sites More sharing options...
Mcf777 Turbocharged October 22, 2010 Share October 22, 2010 get from RIC TAT. I think per tin (4L) is S$32. Link to post Share on other sites More sharing options...
Copen 1st Gear October 22, 2010 Share October 22, 2010 Alright thanks guys! Link to post Share on other sites More sharing options...
Hamtaroo Neutral Newbie November 14, 2010 Share November 14, 2010 can toyota t-iv atf be used on my nissan latio 4 a/t ? latio service manual says dexron iii or mercon equivalent for atf change. fong tat sells for $30sgd/4litre any other cheaper place pls recommend ? Link to post Share on other sites More sharing options...
ER-3682 Twincharged November 14, 2010 Share November 14, 2010 can toyota t-iv atf be used on my nissan latio 4 a/t ? latio service manual says dexron iii or mercon equivalent for atf change. fong tat sells for $30sgd/4litre any other cheaper place pls recommend ? i don't think so,Latio is gearbox is CVT,it need a CVT oil. Link to post Share on other sites More sharing options...
Hamtaroo Neutral Newbie November 15, 2010 Share November 15, 2010 no i meant the latio auto 4 gear model 4 a/t , mine is not the cvt model, is the old auto transmission model. can latio 4 a/t use toyota t-iv atf oil ? Link to post Share on other sites More sharing options...
Marcostan 4th Gear November 15, 2010 Share November 15, 2010 If Toyota use Toyota, if Nissan then use Nissan. Do not try to mix and march by yourself. Transmission is sensitive to what oil you are using, use back the original one is the best and most safe. Why use others than the Original one, is it because of the price are cheaper? Be aware to save now and cause problem in the gearbox and it will burn a big big hole in your pocket. Link to post Share on other sites More sharing options...
Contax 1st Gear November 15, 2010 Share November 15, 2010 no i meant the latio auto 4 gear model 4 a/t , mine is not the cvt model, is the old auto transmission model. can latio 4 a/t use toyota t-iv atf oil ? as long as the spec confer with your manual . Link to post Share on other sites More sharing options...
Crazecow Neutral Newbie November 15, 2010 Share November 15, 2010 can toyota t-iv atf be used on my nissan latio 4 a/t ? latio service manual says dexron iii or mercon equivalent for atf change. fong tat sells for $30sgd/4litre any other cheaper place pls recommend ? You have to check if the Toyota ATF is also Dexron III. If so, can use no problem. Dexron III ATF is widely available. If you want you can use more premium ATF like Redlind or Amsoil. But its expensive. $20 for 1 quart. Btw, you can also use Dexron VI if you can't find Dexron III. VI is backware compatible with III. Link to post Share on other sites More sharing options...
Piggy83sg Clutched November 15, 2010 Share November 15, 2010 try use amsoil ATF if u wan. im using it now. only need 2.5L for my swift. but of cos, the price is $18/L. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 15, 2010 Share November 15, 2010 no i meant the latio auto 4 gear model 4 a/t , mine is not the cvt model, is the old auto transmission model. can latio 4 a/t use toyota t-iv atf oil ? Sud b fine lah. Toyota type iv is dexron iii so no prob. My optra auto use e Aisin wagner autobox which is what most Toyotas use n my manual say need dexron IIe minimum so i use type iv without any problems. In fact it is very smooth. Its cheap n good. Last time i use synthetic atf Royal Purple Max Atf but its quite ex at $14/qt but very smooth n good protection. If i feel rich, maybe i use that next change. Just remember not to over or underfill yr autobox as it wil damage it in e long run. Check level after its hot fr a more accurate reading. Link to post Share on other sites More sharing options...
Saxgoh Clutched December 11, 2013 Share December 11, 2013 Hi, sorry to dig up an old thread. Wanna check with the experts here whether 2008 altis is using the ATF as attached... Thanks in advance! Link to post Share on other sites More sharing options...
Simpleonly 5th Gear December 11, 2013 Share December 11, 2013 Yes... Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear December 11, 2013 Share December 11, 2013 Hi, sorry to dig up an old thread. Wanna check with the experts here whether 2008 altis is using the ATF as attached... Thanks in advance! To confirm what Automatic Transmisson Fluid your 2008 Altis is using, there is a white sticker with blue wordings in 'english' and "thai" sticked around at the top of the gearbox dip stick. The blue wordings will state whether it's using Toyota Automatic Transmission Fluid Type T-IV or Toyota Automatic Transmission Fluid WS. My previous car is a 2006 Facelift Altis, current car is a 2011 Facelift Altis. Although both is using 4 speed AT gearbox but they are using different Automatic Transmission Fluid. 2 Link to post Share on other sites More sharing options...
Saxgoh Clutched December 12, 2013 Share December 12, 2013 To confirm what Automatic Transmisson Fluid your 2008 Altis is using, there is a white sticker with blue wordings in 'english' and "thai" sticked around at the top of the gearbox dip stick. The blue wordings will state whether it's using Toyota Automatic Transmission Fluid Type T-IV or Toyota Automatic Transmission Fluid WS. My previous car is a 2006 Facelift Altis, current car is a 2011 Facelift Altis. Although both is using 4 speed AT gearbox but they are using different Automatic Transmission Fluid. Thanks for this useful piece of information! Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear December 12, 2013 Share December 12, 2013 Thanks for this useful piece of information! You're welcome! ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
