Ken1898 1st Gear June 16, 2008 Share June 16, 2008 Hi, how much is the repair cost for shock absorbers? Currently oil leak.. Any lobang? Asking behalf for a friend on his Altis. ↡ Advertisement Link to post Share on other sites More sharing options...
Vtim 3rd Gear June 16, 2008 Share June 16, 2008 replaced them with Koni Red or if he wanted to lower his Altis, get the Koni Yellow Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 17, 2008 Share June 17, 2008 ur friend chiong and attack humps ah? rarely hear of ppl kena suspension liquid leaks... Link to post Share on other sites More sharing options...
Mustank Hypersonic June 17, 2008 Share June 17, 2008 i brake for no hump, how long do i have before the oil leak? Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 17, 2008 Share June 17, 2008 should be able to last for at least 4~5 years from how you drive. Actually for cars with high body roll and inadequate roll bar, the suspension system also undergo alot of stress esp if you keep pushing your ride very hard and fast at the corner. Wear and tear, sooner or later, the suspension liquid will slip past the inner ring of the suspension canister instead of the vents. Link to post Share on other sites More sharing options...
Mustank Hypersonic June 17, 2008 Share June 17, 2008 chiong hump only, no cornering at all balls shrink at corner good, i have another 4-5 years Link to post Share on other sites More sharing options...
Happily1986 5th Gear June 17, 2008 Share June 17, 2008 actually advise not to chiong hump too much also. Listen next time you see some car approach hump too quickly. you will hear some gushing noise. That's the sound made by the suspension liquid being compressed under force. Also, your CV joints plus the rack and pinion gearset kena abused also. Especially those humps with very short and sharp curvature like zebra raised crossings. ↡ Advertisement Link to post Share on other sites More sharing options...
Need advice for Axio repair cost
Time to Change Shock Absorbers?
Need help - Shock Absorbers
Lifespan of Shock Absorbers and Mounting
Expat Kids Open Up About the Culture Shock When Doing NS
