Tas0577 1st Gear August 17, 2008 Share August 17, 2008 Like to check check with brothers here whether you encounter any air-con icing smell during raining seasons. The smell emits from the air-con when the thermostat did not cut out the compressor in time when it reaches the lowest cooling point? It does not happen very frequently and is this normal? ↡ Advertisement Link to post Share on other sites More sharing options...
Modykoh 1st Gear August 17, 2008 Share August 17, 2008 this could be due to ice buil up in the evaporator. this may be due to dusty evapourator or gas presure is low... Link to post Share on other sites More sharing options...
Vtim 3rd Gear August 17, 2008 Share August 17, 2008 what you should do is not to set the temp to the coldest during raining or highway driving (ex. N/S HW), just set to 3/4 will do. Also if you have driven in the rain for a while, especially at night, about 3 to 5mins before you park and off the engine, turn the temp to the hottest (heater), this is to heat up and dry up any moisture in the coil so that there woundn't be any chance for mold to form ↡ Advertisement Link to post Share on other sites More sharing options...
Yes, ‘old person smell’ is a thing – but what causes it and can you neutralise it?
Smell of Singapore's Rich
Best Air Refreshener To Put In Your Car.
Remove Bad Smell In The Car
Help to get rid of 3-days Fishy Smell
[Help Please] Strong smell of previous owner's car perfume does not go away
Possible to get rid of cigarette smell in old cars?
Removing smell lying beneath leather car seat
