Leo72 6th Gear April 7, 2017 Share April 7, 2017 This looks like an EZ-Stab. Used it many many years ago. EZ-Stab, I used it for more than 13 years. Used on Mit Lancer for 3 years and transfer to Nissan Sunny for 10 years. The Nissan Sunny factory fitted battery rock with this. Changed the Battery after 4.5 years due to the Plate in the Battery crack and broken into half. Didn't used it on the current car I'm driving as the car got start/stop function. Using a Japanese brand battery stabiliser. Stock battery with Dash Cam on Motion detection, battery still good after 1 year 4 months. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 11, 2017 Share April 11, 2017 Yes, EZ-Stab was pretty popular more than 10 years ago. Remembered the mass install at Kallang carpark at that time. Started by a IT guy (Jonathan) but product was short lived after 2~3 years release in the market. Nanopulser is being deployed on Start/Stop vehicles with Q series batteries (Jap/Conti makes). Kah Motor has promoted its use to their customer base Unfortunately, Start/Stop batteries suffer from dendrite growth and crystal sulphation issues. This has been highlighted in a white paper by a leading Japanese battery manufacturer (xxxxSA) and independently Nanopulser has been tested to prevent its formation without harming the active plates. This is how Nanopulser aims to optimize batteries' longevity and delivery performance. 1 Link to post Share on other sites More sharing options...
flashbang Turbocharged April 12, 2017 Share April 12, 2017 Hi fellow MCFer, Thank you for your support over the years and we are delighted to see this thread kept alive after almost 9 years since the original posting. We would like to thank all our customers for your support of the product. We wouldn't be here if not for you as adopters. We have since graduated to be manufacturer status since our humble days of being a country dealer. In 2013, Taurus Industries has bought over the intellectual rights of the trademark and know-how of Nanopulser. In 2014, we launched the 2nd generation model Nanopulser+ with an additional new range for MARINE applications. We are certain from the constant feedback from the thousands of Nanopulser users it has helped them lower the odds of mobility issue relating to in-car battery problem. The new model tackles even the most demanding vehicle power demand needs without sacrificing battery battery longevity and performance. In recognition of its effectiveness as a long term battery solution, Kah Motor Sdn Bhd (local distributor for HONDA) has been promoting Nanopulser to their own customers since 2016 with zero complaints so far. The islandwide retail price for Nanopulser (12v model) is at SGD 160.00 and comes standard with a 5 year local warranty for defects and Battery Xchange program. If battery failure within 24 months, can get a replacement for $60 labour charge? Any battery replacement if above 24 months? 1 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 12, 2017 Share April 12, 2017 If battery failure within 24 months, can get a replacement for $60 labour charge? Any battery replacement if above 24 months? Hi flashbang, Yes and as stated in our website, regardless of your battery age at the time of Nanopulser install, your current battery will be under warranty coverage by us for 24 months. In event your battery fails within the covered period, a brand new MF battery specced to your car's requirement will be changed out FOC. You only pay S$60 for the labour service rendered. After the 24 months coverage is over (regardless of any prior claims), you will be given a goodwill extension of another 36 months coverage. Cost of battery replacement will remain the same (based on make category - Asian/Conti). This is one way in which we give back to our customers who has supported us The other way we are giving back to our customers is via our driving event - NWSC ASIA http://www.nwsc.asia 1 Link to post Share on other sites More sharing options...
Kippei 3rd Gear April 19, 2017 Share April 19, 2017 This have a voltage cut off? 2 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 19, 2017 Share April 19, 2017 This have a voltage cut off? Hi Kippei, Yes, Nanopulser has a automatic system cut-off function which will trigger when 12.0v (+/- 0.1v buffer) is detected. Function will reactivate once it detects a 5.0v jump from the preset lower limits ie. upon crank starting the engine & voltage surpasses 12.5v. Link to post Share on other sites More sharing options...
Ryo69 Clutched April 21, 2017 Share April 21, 2017 What is the difference between Nanopulser and Pivot Mega Raizin? In terms of its usage and functions 1 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 22, 2017 Share April 22, 2017 What is the difference between Nanopulser and Pivot Mega Raizin? In terms of its usage and functions Hi Ryo69, Pivot Mega Raizin is a voltage stabilizer product containing small sized capacitors connected in series and typically housed within a plastic/metal box. Such capacitors store minute amounts of energy. The concept of such products seems to suggest that while running in parallel with you main 12v battery, it is suppose to generate multiple benefits to a car's operation. We do not agree with the above general concept and offer our comments : 1) Your car battery is the biggest capacitor onboard with very high energy content ; running 6~12 small AA sized capacitors in parallel isn't going to help much. 2) Capacitors due to quality or aging, may cause short circuiting and chemical fires ; they do have a finite operational lifespan (contingent on operating environment as well). 3) Capacitors used to absorb transient current / prevent current fluctuation are usually located near power-demand source ; connected inline close to sound system amps or head unit. It does nothing at battery side since it goes to a main distribution junction before branching off. 4) Capacitors does nothing to desulphate or condition your battery lead plates ; Their primary role is to absorb/store energy. 5) The concept of using Voltage Stabilizers to help improve grounding effects no longer apply to newer production cars ; current production cars have more than 200 grounding points with better core wound wires. Only pre-2000 production cars seems to have grounding issues. 6) Voltage Stabilizers as a class concept have yet to be filed in any known patent relating to power storage mediums (ie. battery) Voltage Stabilizers do not contribute any benefit to your in-car battery in any way. It is recommended to remove such devices from your lead acid battery lest through old age or leakage it may actually cause drainage to your 12v battery and accelerate its internal sulphation process. We have not even touched on the possibility of such capacitors causing engine fires due to leakage/corrosion/short-circuiting. To have a better understanding of Voltage Stabilizers if they possess any automotive merit, you can google such information in the net. For the usage and functions of Nanopulser as a battery solution, you may find more detailed information on our website www.nanopulserplus.com Currently our product is being deployed by SATS for airport terminal equipment applications. We thank you and hope to be of further help to you where necessary. 1 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 28, 2017 Share April 28, 2017 Hi Ryo69, The new model NP-12S has a higher frequency range compared with the older model PG-12S. The cut-off voltage has also been adjusted to suit local vehicle operations better. Battery coverage / service is still carried out for our customers under our Battery Xchange program. Please refer to our website http://www.nanopulserplus.com/battery-xchange/ Due to present day battery manufacturing process, the plates are produced with differing material content. To compensate against Start/Stop function and lead content differential, the new model has proven much more effective than the older model. We do have a special trade-in offer to existing Nanopulser users (PG-12S/N). Do enquire from us directly regarding the trade-in price. Thank you and hope to be of service to you soon. Good news for those with the first generation PG12-S (green LED). Taurus Industries would like to reward our early adopters by offering the trade in of PG12-S to the 2nd generation NP-12S. (the benefits of the new vs old model is explain above.) Just top up an additional SGD 80.00 to enjoy the new model benefits as well as qualify for the NSWC ASIA (Nanopulser World Series Challenge) http://www.nwsc.asia Benefits such as the battery exchange program will be provided as well. This is a limited time offer....don't hesitate to contact us if you have any further enquiries on the above trade in offer. #Series 1 (Driving Trip to Nurburgring Germany) is ending soon. Draw for #Series 1 is at the end of June 2017. Act now to qualify for all 5 series !! Link to post Share on other sites More sharing options...
Buadongdong Twincharged April 28, 2017 Share April 28, 2017 ....... Voltage Stabilizers do not contribute any benefit to your in-car battery in any way. It is recommended to remove such devices from your lead acid battery lest through old age or leakage it may actually cause drainage to your 12v battery and accelerate its internal sulphation process. We have not even touched on the possibility of such capacitors causing engine fires due to leakage/corrosion/short-circuiting. To have a better understanding of Voltage Stabilizers if they possess any automotive merit, you can google such information in the net. For the usage and functions of Nanopulser as a battery solution, you may find more detailed information on our website www.nanopulserplus.com Currently our product is being deployed by SATS for airport terminal equipment applications. We thank you and hope to be of further help to you where necessary. Hi Nanopulser, are you saying that the nanopulser installed has virtually zero (0) chance of causing engine fires due to its malfunction? And if it really does cause engine fire, what would be the course of action by Nanopulser in terms of vehicle warranty?? 1 Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 28, 2017 Share April 28, 2017 Hi Nanopulser, are you saying that the nanopulser installed has virtually zero (0) chance of causing engine fires due to its malfunction? And if it really does cause engine fire, what would be the course of action by Nanopulser in terms of vehicle warranty?? Hi Buadongdong, Your comments are much appreciated and we offer our response as appended : 1) Yes, there is virtually zero chance of causing engine fires due to any remote possibility of malfunction based on 4 main parameters : a) there are no capacitors housed within Nanopulser units. All are microchip components and main ECU chip. It is a passive unit, no stored energy is contained within, active or inactive. b) there is a two stage diode that disengages unit operations when it detects a safety preset voltage detection. This safety feature ensures current surge does not damage the unit. Hence from a logic standpoint, if the unit (had preempt) disengages, the current must be from another source of origin. c) the entire PCB platform is cocooned in silicone-PU and hermetically sealed and rated Ingress Protection 68. Should there be even a slightest chance of implosion the properties of silicone extinguishes it. There is no oxygen content within the sealed unit to stoke any electrical (current) rupture, if any. d) Nanopulser has passed all EMF and EMI regulatory tests + certified RoHs compliant. It is manufactured under strict quality control under Panasonic Group in Japan. 2) Under current Lemon Law governing consumer goods and services, we are happy to abide by the regulations under consumer protection. In your context question, most if not all aftermarket car accessories do not offer vehicle warranties covering the entire vehicle and its components, only for the affected component or connected article if (proven) damaged by use of the aftermarket accessories. As described in your particular instance, if it is presumed that the engine fire is thought to be caused by Nanopulser, all consumers possess legal rights to pursue legal remedies to recover their loss. We as manufacturer will be subjected under the microscope of the Consumer Courts. If found to be truly caused by the product, apportionment of liability will be awarded accordingly. There would be a slew of tests assessments and structured investigations to ensure fairness to all parties. ie. if after driving on a set of "good branded" tires and one tire exploded while driving on the expressway which results in a chain collision with other on-road vehicles, does the tire manufacturer cover vehicle warranty (as well as others) and what will be its liability extent? This area of liability coverage extends to all car and non-car related products and services. Koh Wee Meng vs Trans Eurokar is a recent legal case study. 3) There are more than 27,000 units of Nanopulsers in use locally from corporates to consumers for the last 9 years. We have yet to hear of an engine fire case relating to the use of Nanopulser in-vehicle till date. This thread was kept alive (thank you all customers) all these years to offer and provide historical data regarding its existence and also usage feedback from general public and paying customers. We as manufacturer take a very serious view in ensuring vehicle owners' safety in using our company products. Thank you for taking time to read our rather lengthy post and hope the above explanations has satisfied your queries. For more information in understanding our product, please log in to our website www.nanopulserplus.com 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged April 28, 2017 Share April 28, 2017 Hi Buadongdong, Your comments are much appreciated and we offer our response as appended : 1) Yes, there is virtually zero chance of causing engine fires due to any remote possibility of malfunction based on 4 main parameters : a) there are no capacitors housed within Nanopulser units. All are microchip components and main ECU chip. It is a passive unit, no stored energy is contained within, active or inactive. b) there is a two stage diode that disengages unit operations when it detects a safety preset voltage detection. This safety feature ensures current surge does not damage the unit. Hence from a logic standpoint, if the unit (had preempt) disengages, the current must be from another source of origin. c) the entire PCB platform is cocooned in silicone-PU and hermetically sealed and rated Ingress Protection 68. Should there be even a slightest chance of implosion the properties of silicone extinguishes it. There is no oxygen content within the sealed unit to stoke any electrical (current) rupture, if any. d) Nanopulser has passed all EMF and EMI regulatory tests + certified RoHs compliant. It is manufactured under strict quality control under Panasonic Group in Japan. 2) Under current Lemon Law governing consumer goods and services, we are happy to abide by the regulations under consumer protection. In your context question, most if not all aftermarket car accessories do not offer vehicle warranties covering the entire vehicle and its components, only for the affected component or connected article if (proven) damaged by use of the aftermarket accessories. As described in your particular instance, if it is presumed that the engine fire is thought to be caused by Nanopulser, all consumers possess legal rights to pursue legal remedies to recover their loss. We as manufacturer will be subjected under the microscope of the Consumer Courts. If found to be truly caused by the product, apportionment of liability will be awarded accordingly. There would be a slew of tests assessments and structured investigations to ensure fairness to all parties. ie. if after driving on a set of "good branded" tires and one tire exploded while driving on the expressway which results in a chain collision with other on-road vehicles, does the tire manufacturer cover vehicle warranty (as well as others) and what will be its liability extent? This area of liability coverage extends to all car and non-car related products and services. Koh Wee Meng vs Trans Eurokar is a recent legal case study. 3) There are more than 27,000 units of Nanopulsers in use locally from corporates to consumers for the last 9 years. We have yet to hear of an engine fire case relating to the use of Nanopulser in-vehicle till date. This thread was kept alive (thank you all customers) all these years to offer and provide historical data regarding its existence and also usage feedback from general public and paying customers. We as manufacturer take a very serious view in ensuring vehicle owners' safety in using our company products. Thank you for taking time to read our rather lengthy post and hope the above explanations has satisfied your queries. For more information in understanding our product, please log in to our website www.nanopulserplus.com Thanks for the detailed analysis of my query. I'm asking because Kah Motor(KM) is the authorised dealer for your product, and I'm a KM customer. So I'm actually wondering what will happen if it really catches fire, will KM deny responsibility both as an AD of Honda as well as nanopulser. Will there be any conflict of interest in this case? KM may or may not say that the fire might be due to nanopulser (an aftermarket product?) and then refuse warranty in this case? Anyway, I've noted what you have said and will keep an open mind to this matter. Guess its not so easy to pinpoint the responsibilities if a fire really broke out. Thanks. Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 28, 2017 Share April 28, 2017 Thanks for the detailed analysis of my query. I'm asking because Kah Motor(KM) is the authorised dealer for your product, and I'm a KM customer. So I'm actually wondering what will happen if it really catches fire, will KM deny responsibility both as an AD of Honda as well as nanopulser. Will there be any conflict of interest in this case? KM may or may not say that the fire might be due to nanopulser (an aftermarket product?) and then refuse warranty in this case? Anyway, I've noted what you have said and will keep an open mind to this matter. Guess its not so easy to pinpoint the responsibilities if a fire really broke out. Thanks. Hi Buadongdong, In all honesty, after getting acquainted with KM and their business culture, we are doubtful they would deny or play the blame game to absolve themselves of any (possible) liability towards customers' plights. It would be very detrimental to their painstakingly built-up market reputation over the last 60 years if customers' confidence is eroded. Most aftermarket products/services carried by any car distributor aim at enhancing a customer's vehicle ownership experience. There will not be any conflict of interest in any manner after assessing their nature and usage purpose on their vehicles. If there is, they will not be promoted or endorsed in the first place. That is why not all aftermarket products/services make it into their showrooms. There would always be product divide based on criterion evaluations. In the case which you have described, assuming there is an engine fire happening in a customer's vehicle, KM, us (Taurus), Honda Thailand/Japan (plant of origin) would be brought into the picture to sort out customer's problem. Customers should not be made to bear the brunt in any vehicle ownership incident loss (unless proven otherwise). This is the most fundamental of principle in proper customer management. The fact is milk has been spilled, somebody has to clean it up. It cannot be left unattended. We cannot speak for other accessories suppliers' position but as far as Nanopulser is concerned, KM and Taurus will attend to any incident involving customers' vehicle with the aim of resolution. We have seen firsthand KM's handling attitude towards their customers and you can be rest assured in that aspect as a paying customer. We appreciate your honest question and we hope the above can shed some light on your vehicle ownership concerns under KM. 1 Link to post Share on other sites More sharing options...
Teo1606 Clutched April 29, 2017 Share April 29, 2017 hi! this device can only install in KM? Link to post Share on other sites More sharing options...
dcb Turbocharged April 30, 2017 Share April 30, 2017 Can purchase and get it installed with Taurus @ Toh Guan. hi! this device can only install in KM? Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 30, 2017 Share April 30, 2017 hi! this device can only install in KM? Hi Teo1606, Thank you for your interest in Nanopulser. Besides KM which is for Honda owners, we do have other participating vendor partners. Please see the link under NWSC ASIA to locate the nearest vendor for your convenience http://nwsc.asia/to-qualify/ Or you can also come by our office at Old Toh Tuck Road (Toh Guan Area) to get your installation done. Depending on vehicle make/model, typically install time is around 15~30 mins. Do call our office +65 6268 5044 or Kelvin Lee (GM) +65 9639 8517 to make an appointment. Thank you for chiming in and happy May Day holidays to everyone in this thread Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 30, 2017 Share April 30, 2017 (edited) Tired of your powerful road bike’s erratic and unstable electrical supply flow? Can’t even start up your engine on the morning of a long-awaited road trip? Strong firing of your plugs and on-board electronics demand consistent power. It’s a bummer, we know.Forget the other gimmicks and get the real deal. Nanopulser+ is a simple but effective battery solution for all classes of bike batteries. It’ll help enhance your battery’s performance (and your bike’s of course!) with a consistent, stable electrical flow – guaranteed.Oh, and did we mention it comes with a 5 year warranty too? Get yourself a Nanopulser+ and brace yourself for some all-out riding pleasure! Link To Facebook Article : https://www.facebook.com/taurusindustries/photos/a.1896165767330137.1073741828.1841256462821068/1914329692180411/?type=3&theater Edited April 30, 2017 by Nanopulser Link to post Share on other sites More sharing options...
Nanopulser 1st Gear April 30, 2017 Share April 30, 2017 Frustrated by shorter-than-expected lifespan battery? Shocked by high battery prices when you need one replaced? Crippled by sudden immobility when you need your car and it doesn't start? Wondering why your car is not behaving the way it should?Well, we may have the solution you've been looking for!Introducing Nanopulser+, a real time solution aimed at solving your battery related woes. When paired with your battery, you are guaranteed increased battery life and consistent performance to meet your driving expectations. After all, the vehicle's battery is a critical component which starts/maintains your onboard functions. Without an optimal battery functioning, how do you expect your car to perform at its best and, more importantly, provide you with mobility on demand?Nanopulser+ - Why risk your mobility when you now can ensure it? Link to Facebook Article : https://www.facebook.com/taurusindustries/photos/a.1896165767330137.1073741828.1841256462821068/1912098962403484/?type=3&theater EXTEND YOUR CAR'S BATTERY LIFEWHAT IS NANOPULSER & HOW DOES IT WORK?By applying our technology to regular lead acid batteries, we have been successful in retarding aging and decay of the internal lead plates of ALL regular lead acid batteries. This results in:1) extended lifespan2) avoidance of premature failures3) optimized plate condition4) maximum current output5) long term solution and savingsFind out more at http://www.nanopulserplus.com/ Link To Facebook Article : https://www.facebook.com/taurusindustries/photos/a.1896165767330137.1073741828.1841256462821068/1898433593770021/?type=3&theater ↡ Advertisement Link to post Share on other sites More sharing options...
Nanopulser World Series Challenge Featuring Legendary Tracks
Nanopulser
Nanopulser
