Yewhiong Neutral Newbie October 27, 2008 Share October 27, 2008 Dear Bros, for your votes. ↡ Advertisement Link to post Share on other sites More sharing options...
Perrier 1st Gear October 27, 2008 Share October 27, 2008 Nope. Stock is good enough for me. Link to post Share on other sites More sharing options...
So_nice 6th Gear October 27, 2008 Share October 27, 2008 bigger rotors is like lppl if u are using stock calipers. i think the stock ones are good enough. just upgrade to better brake pads. Link to post Share on other sites More sharing options...
Dj_spike 2nd Gear October 27, 2008 Share October 27, 2008 I am newbie in brakes... all i know that i'm on drum brakes... they are fine so far... as for drum, what would be the next level? Change to disc brakes? Need ur help bros Link to post Share on other sites More sharing options...
Jellyfish 1st Gear November 3, 2008 Share November 3, 2008 ditch the stock pad, get better ones, current rotor is good for sprited driving even, unless you track then big brake kit like those 285mm ones will do wonders, rear forget abt it, just change to performance drum brake shoe will do, or else the brake pressure distribution will cxxk up Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged November 8, 2008 Share November 8, 2008 Rear drums are ok because most of the braking power comes from the front, that is where the focus should be. Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 9, 2008 Share November 9, 2008 since its a lightweight car, the stock brakes are already very good. by the way, brake upgrades cost roughly how much? Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 9, 2008 Share November 9, 2008 Rear drums are ok because most of the braking power comes from the front, that is where the focus should be. that said, you cannot just upgrade front without adjusting the bias for the rear. it's scary how many big brake kit users get the largest front rotors/calipers but use the stock rears! it's recipe for disaster, especially since they think they can stop better... Link to post Share on other sites More sharing options...
Andyngps 5th Gear November 15, 2008 Share November 15, 2008 (edited) Is it really light weight? If i'm not wrong it weighs more slightly more than 1 ton for the new fit/jazz. Anyway the stock brakes sucks. Edited November 15, 2008 by Andyngps Link to post Share on other sites More sharing options...
Boyboy 1st Gear November 15, 2008 Share November 15, 2008 bigger rotors is like lppl if u are using stock calipers. i think the stock ones are good enough. just upgrade to better brake pads. if the stock calipers fit, it will increase the leverage and also have bigger surface area for cooling. for the same force applied by the caliper, there will be more braking force overall but that's if they fit Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 15, 2008 Share November 15, 2008 wow, more than 1 ton and the FC is still so good. no wonder so many jazz/fit on the roads nowadays. Link to post Share on other sites More sharing options...
Yewhiong Neutral Newbie November 15, 2008 Author Share November 15, 2008 A more economical way to save cost... Wait till stock brake pad is finished. Changed to performance brake pad (You must tahan the brake dust)... Still not happy, also changed the brake shoe.... Wait till brake line have to change - > Change to SSBH. Then braking power Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie November 15, 2008 Share November 15, 2008 bigger rotors is like lppl if u are using stock calipers. i think the stock ones are good enough. just upgrade to better brake pads. I will whack your lan with a baseball bat. Who told you larger rotors is LPPL ? Larger rotors has larger contact surface. This increase friction coefficient which equates to larger contact surface. Heat dissipation also improved has you don't overheat the brakes as quick as compared to stock. You think wrong. The better the brakes the better it is. Cars with half the horsepower can close the gap with braking. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie November 15, 2008 Share November 15, 2008 Rear drums are ok because most of the braking power comes from the front, that is where the focus should be. that said, you cannot just upgrade front without adjusting the bias for the rear. it's scary how many big brake kit users get the largest front rotors/calipers but use the stock rears! it's recipe for disaster, especially since they think they can stop better... What you said is only right to certain extend. With some of the big brake kits, they are capable of running with stock master cylinder. The use of which is able to regulate brake bias evenly even if the front has more brake bias in percentage terms as compared to the rear. With the Tarmac Rally Evos, they upgrade the front calipers, rotors and pads but keep stock rear. This is because (without mentioning any names) some of the brake companies have 4 pistons rear calipers which most would find, distort the brake balance of the entire car. Most of the race cars you see today that actually upgrade both front and rears have a brake bias proportion valve which enable drivers to adjust brake bias according to their driving styles. I see alot of cars in Singapore upgrading to 6pot front and 4pot rear. Looks good. Problem is do they know how to use it ? No point upgrading to big brake kits if the driver does not use the right braking technique. In the end the big brake kit will only increase their braking distance rather than shorten it. Link to post Share on other sites More sharing options...
Malcolmc Neutral Newbie November 15, 2008 Share November 15, 2008 stock calipers still bite the same size outta the larger rotors isn't? Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie November 15, 2008 Share November 15, 2008 Not necessary. Some stock brakes, including brembos that come stock are capable of running larger size rotors. Link to post Share on other sites More sharing options...
Malcolmc Neutral Newbie November 15, 2008 Share November 15, 2008 agreed, but what i meant was the brake surface still dependent on the size of the calipers, regardless the rotor size? as in the calipers can only bite so much outta the rotors no matter how big they are Link to post Share on other sites More sharing options...
Malcolmc Neutral Newbie November 15, 2008 Share November 15, 2008 an example would be a small mouth would take only small bites outta piece of pie, no matter how big it is, but a bigger mouth would be able to bite a bigger piece off the same or bigger size pie? does it work that way? ↡ Advertisement Link to post Share on other sites More sharing options...
The waiting time in calling in to UOB bank
2025 Mitsuoka M55
2025 Mitsuoka M55
