Powerkeong Neutral Newbie November 9, 2008 Share November 9, 2008 Yesterday night while i was driving home from my girlfriend place, the ABS light of my Hyundai Verna comes on. I try tested it yesterday night after a heavy rain whether my ABS is still there and it GONE!!! Ima going for my 20K servicing this coming monday. Anyone know what had cause this to happen??? ↡ Advertisement Link to post Share on other sites More sharing options...
Atrecord Supersonic January 2, 2014 Share January 2, 2014 Yesterday night while i was driving home from my girlfriend place, the ABS light of my Hyundai Verna comes on. I try tested it yesterday night after a heavy rain whether my ABS is still there and it GONE!!! Ima going for my 20K servicing this coming monday. Anyone know what had cause this to happen??? Hi. Did a search and found this old thread. My verna's ABS light just came on today. Changed my brake pads and skimmed the rear brake disc last Fri. Is there any likely connection? How did this thing get resolved? Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 2, 2014 Share January 2, 2014 the abs sensor may be faulty or not properly replaced back when rotor was taken out for skimming. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 6, 2014 Share January 6, 2014 the abs sensor may be faulty or not properly replaced back when rotor was taken out for skimming. tks... been back to the ws and they used a tablet sensor to check and found fault on 3 wheels... reset it and asked me to monitor... and the light came on one journey, then off... sigh... just sent back again. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 6, 2014 Share January 6, 2014 ws just called me, now say use the tablet scan found fault with front wheels instead. asked me to change the sensors, will cost about $400+... am i being ko'tok'ed? Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 6, 2014 Share January 6, 2014 did this happened only after the skimming?? There may be a possibility that they damaged it but no way now you can justified that. Best option now is ask from stockist and inquire how much it cost. Link to post Share on other sites More sharing options...
Atrecord Supersonic January 6, 2014 Share January 6, 2014 did this happened only after the skimming?? There may be a possibility that they damaged it but no way now you can justified that. Best option now is ask from stockist and inquire how much it cost. yes, only after skimming. car is 7.5 yr now and for the last 2.5 yr i drove, it had never had problem. just after the change of the brake pads and skimming ($440), this ABS light came on intermittently... Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 6, 2014 Share January 6, 2014 yes, only after skimming. car is 7.5 yr now and for the last 2.5 yr i drove, it had never had problem. just after the change of the brake pads and skimming ($440), this ABS light came on intermittently... hate to say this, but at $440 you are being carroted. If its a new disc rotor and pad, its still considered hardly acceptable. Do us a favour, warn us where is this WS. Link to post Share on other sites More sharing options...
Ahgong Supercharged January 6, 2014 Share January 6, 2014 did this happened only after the skimming?? There may be a possibility that they damaged it but no way now you can justified that. Best option now is ask from stockist and inquire how much it cost. you have any contacts for verna stockist? or at least go where to find these contacts? Link to post Share on other sites More sharing options...
Lazy_chai Clutched January 6, 2014 Share January 6, 2014 you have any contacts for verna stockist? or at least go where to find these contacts? There are a few Hyundai stockists around. Min Ghee, Song Yi and Aik Hoe. Normally I buy from Aik Hoe at Race Course Road. Address : Blk 681 Race Course Road #01-307 S(210681) (map) Phone : 62982929 Fax : 62930430 Category : Car Parts Stockists Specialises in : Hyundai, Daewoo, Chevrolet, Kia, Ssangyong 1 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear January 6, 2014 Share January 6, 2014 Hi. Did a search and found this old thread. My verna's ABS light just came on today. Changed my brake pads and skimmed the rear brake disc last Fri. Is there any likely connection? How did this thing get resolved? Likely to be the ABS sensor. My hyundai ABS sensors failed at round 6.5yrs. All four sensors have been changed. Can purchase at Song Yi at about $120+ per piece. Link to post Share on other sites More sharing options...
Contipro 5th Gear January 6, 2014 Share January 6, 2014 Touch woods, if the ABS sensor spoilt can we disable it and drive without abs assistance? Any issue that it will cause the car not running properly, or any issue with insurance in case accident? In old days where got abs, during e-brake will "pumping" the brake pedal when there is wheel lock.. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 6, 2014 Share January 6, 2014 Touch woods, if the ABS sensor spoilt can we disable it and drive without abs assistance? Any issue that it will cause the car not running properly, or any issue with insurance in case accident? In old days where got abs, during e-brake will "pumping" the brake pedal when there is wheel lock.. i drove for a couple of weeks without abs and its all normal when you drive sedately. But on rainy days, wheels may tend to lock up quite easily if driven not so sedately. Quite scary for new drivers. Link to post Share on other sites More sharing options...
Friendstar Supercharged January 6, 2014 Share January 6, 2014 Bro. I have the same problem as u. Just ignore the abs la. u won't die without using the system. Normal day to day driving no problem at all. I'm speaking from experience. But if u paranoid kind, by all means. Sincerely I rather u change tires regularly at proper intervals than worry over abs Link to post Share on other sites More sharing options...
Contipro 5th Gear January 6, 2014 Share January 6, 2014 i drove for a couple of weeks without abs and its all normal when you drive sedately. But on rainy days, wheels may tend to lock up quite easily if driven not so sedately. Quite scary for new drivers. Not really understand. During raining day wheel tend to lock up? You always do ebraking while driving normally/daily..? Without ABS on raining days when I travel NS highspeed and braking due to traffic ahead don't seem to have this problem.. Link to post Share on other sites More sharing options...
Yewheng Twincharged January 6, 2014 Share January 6, 2014 i drove for a couple of weeks without abs and its all normal when you drive sedately. But on rainy days, wheels may tend to lock up quite easily if driven not so sedately. Quite scary for new drivers. That means your braking could be quite hard, or tyres going botak soon Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 6, 2014 Share January 6, 2014 Not really understand. During raining day wheel tend to lock up? You always do ebraking while driving normally/daily..? Without ABS on raining days when I travel NS highspeed and braking due to traffic ahead don't seem to have this problem.. like i say, when driven a bit insanely. but that again, abs sensor is very sensitive. Once it sense a slight lock up of the wheel, it will be activated. That means your braking could be quite hard, or tyres going botak soon i change my tyres every year which clock around 40k. Hardly any chance for them to be hardened... Link to post Share on other sites More sharing options...
Atrecord Supersonic January 7, 2014 Share January 7, 2014 Likely to be the ABS sensor. My hyundai ABS sensors failed at round 6.5yrs. All four sensors have been changed. Can purchase at Song Yi at about $120+ per piece. I was billed $175 per piece, 2 pcs $370, plus labour $90 = $440... so that's quite steep... and to think it was ok all along... i just paid almost the same amt less than a week ago to change brake pads and skim brake rotor, so was suspicious that this was caused by that... but maybe i shouldn't be so skeptical... but it's really painful... ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
2024 6th Generation Hyundai Accent / Verna
Mazda 5 ABS error
Mazda 5 ABS error
P2096 Check engine light
