  • 1
  • Search this thread
  • Reply to this topic
17 replies to this topic | 0 praises
#1
Posted 29 November 2008 - 04:43 PM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
Hi guys,
need your expertise advise on my lancer aircon.
recently, for no reason, my car aircon not cold anymore. the first time this sympton occurs, the rpm shoot up to around 1.5k rpm while the car is idling. it stay at 1.5k rpm for a while and it drop to the normal rpm of 0.8k rpm. the next thing is the aircon not cold anymore.
when this sympton occurs, i switch off my car and switch on again and it go back to normal.
this sympton occurs quite often now. 3 times already. any advise or any shop which can repair aircon?
thanks!
#2
Posted 29 November 2008 - 06:49 PM
Route88
  • Premium member
    Route88
    Author Image
    7,886
Need to diagnose,see reputable a/c mechanic...can be faulty compressor,leak in system or condensor goes bonker. Mark Cool Wooldlands
What is the most effective way to control the world?
"MIND CONTROL"
We are being hypnotised and brainwashed !!!
#3
Posted 29 November 2008 - 08:44 PM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
u have any reputable a/c mechanic to recommend? thanks
#4
Posted 29 November 2008 - 10:28 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    48,544
He mentioned Mark Cool at Woodlands mah.
#5
Posted 29 November 2008 - 10:51 PM
Blue850r
  • Blue850r
    4th Gear
    Author Image
    613
Your aircon compressor clutch did not engage when it should. So the compressor is not working hence no cold air. The rpm goes higher because the FICD, Fast Idle control device increase the throttle in anticipation of compressor coming ON. Since no load from compressor, the increase in throttle makes the rpm higher.
#6
Posted 29 November 2008 - 11:29 PM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
thanks. manage to google and found the address
Mark-Cool Auto Air-Conditioning Service
106 Woodlands Industrial Park E 3, 757840, Singapore
Edited by Surferguy1978, 29 November 2008 - 11:30 PM.
#7
Posted 29 November 2008 - 11:35 PM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
okok. quite technical to me. so u suspect it the aircon compressor clutch spolit?
#8
Posted 30 November 2008 - 12:24 AM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    48,544
I went there once. Look for Ah Huat.
#9
Hermit
  • Premium member
    Hermit
    4th Gear
    Author Image
    559
This is something Ah Huat and I encountered before, but the change in rpm for my case was not as apparent as yours.
Another possible reason: The relay for the compressor did not change over, to turn it on..
身体发肤,受之父母.
#10
Posted 30 November 2008 - 12:37 AM
Espire
  • Espire
    5th Gear
    Author Image
    1,029
Hi guys,
thanks!
#11
Posted 30 November 2008 - 07:06 AM
Modykoh
  • Premium member
    Modykoh
    5th Gear
    Author Image
    1,365
your is auto or manual?
is the rpm shoot up when engage gear, 1st gear, neutral, shoot up..?(manual)
i used to drive lancer and got this prob b4.
#12
Posted 30 November 2008 - 11:32 AM
Blue850r
  • Blue850r
    4th Gear
    Author Image
    613
There could be a couple of cause that makes the clutch not to engaged. The clutch itself can spoil but unlikely unless your mileage is very high, above 160,000kms on the odometer.
There is a sensor on the drier/receiver to ensure there is enough aircon gas in the system, then it will trigger the clutch. So either this sensor is spoilt or there is really not enough aircon gas. The Aircon gas also carries along the oil to circulates to the compressor for lubrication. So if there is a lack of aircon gas, the sensor detects it and prevent the compressor fromm running without lubrication.
Do you have a situation where the aircon becomes very cold and white smoke blows out of the aircon vent in your dialy driving?
#13
Posted 01 December 2008 - 01:05 AM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
mine is manual. my car about 4yr + old liao.
today, the aircon is working fine. i'm gonna wait for it to really become spolit and then i will check out the cost to repair.
#14
Posted 01 December 2008 - 01:07 AM
Surferguy1978
  • THREAD STARTER
  • Surferguy1978
    3rd Gear
    Author Image
    374
ya... my mileage is consider high.. about 126k now for 4yr + old car.
my aircon never blow out white smoke and the temperature is always acceptable for me.
#15
Posted 01 December 2008 - 11:02 AM
Blue850r
  • Blue850r
    4th Gear
    Author Image
    613
I will suggest that you top up the Aircon gas. May cost you $20 or so. Then you see if this problem goes away. If problem goes away and after 4 to 5 months it come back, means there is a leak.
This is the cheapest first step for your problem.
#16
Posted 01 December 2008 - 05:45 PM
Modykoh
  • Premium member
    Modykoh
    5th Gear
    Author Image
    1,365
if not wrong,,is your ECU...
last time they re programme mine...after that no problems liao..
at first even changed compresser, trottle etc etc...all also can not correct,,somer more funny thing is that off ac, no probelms only when on..so C&C at first suspect is ac..l
later got a eng from japan and they got a clinic ,,,from there e jap find the fault,,,
#17
Posted 07 December 2008 - 12:02 AM
Shull
  • Premium member
    Shull
    2Fast2Furious
    Author Image
    28,832
Hi bro,
don't mind i 'hijack' your thread abit..since i am also facing similar problems as you..
Recently, after heavy jam(1hr+ those SG-Msia causeway type), my air con become not cold. Only after i cleared the jam and travelled about 2-3km then the aircom start becoming cold.
I suspected that the compressor refuse to start during jam because usually when the compressor kicks in, i can feel and hear it starting up..but during these type of long jam, the compressor didn't even start..
Is this normal? do i need to bring it for a check?
2002 Honda Civic ES8 (2003-2013) | 2009 Honda Civic FD2 (2009 - present) | 2007 Mitsubishi Lancer CS3 (2013 - 2012) | 2012 Ford Focus Ti (2017 - 2018) | 2016 Honda Civic FC1 (2018 - present)
#18
Posted 07 December 2008 - 12:18 AM
Sw20
  • Sw20
    5th Gear
    Author Image
    1,117
GO have it checked, is your a/c sensor and gas that is gone... same case as mine.
  • 1
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: Aircon, Problem
