Mandrew 1st Gear October 5, 2012 Share October 5, 2012 (edited) Pls find herewith the address: 2020 Accessories Shop 17,19, Jalan Permas 10/10, Bandar Baru Permas Jaya, JB - 81750 From Checkpoint you can take the new road towards Permas Jaya. Edited October 5, 2012 by Mandrew ↡ Advertisement Link to post Share on other sites More sharing options...
Mandrew 1st Gear October 10, 2012 Share October 10, 2012 A DIY sharing: Since there is no light inside the Dashboard Compartments for Exora I just added a simple one. You just need a Universal Door Switch and a Bulb with case or a LED strip light(which I'm using) Attached a Universal Switch behind the Compartment so that the Button will be pressed down when you close the Box. Just ensure that you have connected the Universal Switch to the Earth only. Added in both the compartments, but control with only one switch. I took the power supply from the Sill plate (you can take it from any live wire which is a direct supply). There you go..... Sharing just for info only.... Link to post Share on other sites More sharing options...
Nasiroo25 Neutral Newbie October 13, 2012 Share October 13, 2012 Ho everyone... Coming back here after very long... Happy to see its still active down here. been exora exactly for 6 mths... Encountered minor problems but its a fantastic car I must say Link to post Share on other sites More sharing options...
1258 Clutched October 16, 2012 Share October 16, 2012 Hi there Bros & sis can some one tell more about this car, I went down to ubi last sunday try to test drive but the sales tell me that they don't have the normal test drive unit. He also don't bother to arrange for the tubro unit for my friend & me to try it out, it was very very disappointed..... Link to post Share on other sites More sharing options...
TVT Supercharged October 16, 2012 Share October 16, 2012 Ho everyone... Coming back here after very long... Happy to see its still active down here. been exora exactly for 6 mths... Encountered minor problems but its a fantastic car I must say Do you mind tell us what minor problems you had encounter? Link to post Share on other sites More sharing options...
TVT Supercharged October 16, 2012 Share October 16, 2012 Hi there Bros & sis can some one tell more about this car, I went down to ubi last sunday try to test drive but the sales tell me that they don't have the normal test drive unit. He also don't bother to arrange for the tubro unit for my friend & me to try it out, it was very very disappointed..... So funny one! Like they not bothered to do business.... Then what test drive vehicles they have there to try? Try another Proton dealer lah...there's one at Sin Ming right? Link to post Share on other sites More sharing options...
Nasiroo25 Neutral Newbie October 16, 2012 Share October 16, 2012 My car alarm a bit funny. Does not activate to lock the car via car remote at times. Highlighted to the workshop in sin ming. Asked me to bring back to reset. After switching on the car for quite sometime switch off and wen try to on again, the engine takes longer to respondto the startup up. Shared this with another customer at the workshop. Told me its unique to exora as hence the delay in staying the caronce you shennmediately the injection of fuel is slow or something hence the delay Link to post Share on other sites More sharing options...
1258 Clutched October 17, 2012 Share October 17, 2012 Thanks, may I know which part of sim min pls? Btw my friend have confirmed to sign Honda stream & he is not interested to know more abt this model too bad... Link to post Share on other sites More sharing options...
Mandrew 1st Gear October 18, 2012 Share October 18, 2012 Pls find herewith the address - TTS Motor Group Showroom 383, Sin Ming Drive (TTS Centre) Link to post Share on other sites More sharing options...
Panhard 1st Gear October 19, 2012 Share October 19, 2012 (edited) bro, to avoid this difficulty in starting.....do the following steps. 1. insert key into switch slot. 2. turn it one step to right--lights on dash appear. 3. hold it for about 05 seconds. 4. then proceed to turn key a further step to crank it 5. will usually start without any problem. Reason: when switch is turned 1st step, it works the fuel pump to supply fuel to engine. thus making it easy to crank up the engine otherwise if you do not do this, you will need to crank a bit longer to get the engine running... you are welcome! Edited October 19, 2012 by Panhard Link to post Share on other sites More sharing options...
Doosan 1st Gear October 19, 2012 Share October 19, 2012 新山19日訊)泊在住家庭院、車齡僅一年半的國產普騰Exora休旅車,深夜突從內部起火燃燒,火勢波及住家,直至斷電;事主一家四口因悶熱被驚醒,紛紛緊急逃生。 事發于凌晨3時許,鄰居發現休旅車起火燃燒後,急忙呼叫,但車主一家四口一直熟睡。著火休旅車的火焰因燒斷天花板電線,導致停電,冷氣停止操作,車主被熱氣弄醒后發現事態不妙,喚醒一家人從屋后逃出。 在新山茂奧斯汀花園經營熟食餐館的車主邱勇霏(55歲,住新山御景園)及妻子陳鸞(51歲),不滿仍在保用期內休旅車無故起火,甚至險些奪走一家性命,今早透過人民公正黨柔佛再也支部主席潘偉斯召開記者會。 Link to post Share on other sites More sharing options...
Noirmubin Clutched October 19, 2012 Share October 19, 2012 Very informative...thanks for the info Link to post Share on other sites More sharing options...
Noirmubin Clutched October 19, 2012 Share October 19, 2012 Thanks for the add...saw a couple of Exora with the door liner...looks cool Link to post Share on other sites More sharing options...
Nasiroo25 Neutral Newbie October 24, 2012 Share October 24, 2012 Txs lanyard... Now got new problem. My aircon id not working. Got a funny noise from the engine then lots of misty smoke coming out from my aircon ventilator with a funny smell Link to post Share on other sites More sharing options...
TVT Supercharged October 24, 2012 Share October 24, 2012 新山19日訊)泊在住家庭院、車齡僅一年半的國產普騰Exora休旅車,深夜突從內部起火燃燒,火勢波及住家,直至斷電;事主一家四口因悶熱被驚醒,紛紛緊急逃生。 事發于凌晨3時許,鄰居發現休旅車起火燃燒後,急忙呼叫,但車主一家四口一直熟睡。著火休旅車的火焰因燒斷天花板電線,導致停電,冷氣停止操作,車主被熱氣弄醒后發現事態不妙,喚醒一家人從屋后逃出。 在新山茂奧斯汀花園經營熟食餐館的車主邱勇霏(55歲,住新山御景園)及妻子陳鸞(51歲),不滿仍在保用期內休旅車無故起火,甚至險些奪走一家性命,今早透過人民公正黨柔佛再也支部主席潘偉斯召開記者會。 Can translate??? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 25, 2012 Share October 25, 2012 (edited) Exora caught fire at home and whole family escaped unscathed. Short and sharp....sweet bo? Edited October 25, 2012 by Hamburger Link to post Share on other sites More sharing options...
TVT Supercharged October 25, 2012 Share October 25, 2012 Exora caught fire at home and whole family escaped unscathed. Short and sharp....sweet bo? Sweet lah. Whatever ah Ham does, sure sweet one!!! Thanks! Link to post Share on other sites More sharing options...
Iz_Exora Clutched October 25, 2012 Share October 25, 2012 Pls find herewith the address: 2020 Accessories Shop 17,19, Jalan Permas 10/10, Bandar Baru Permas Jaya, JB - 81750 From Checkpoint you can take the new road towards Permas Jaya. Thanks bro, Wah you also got the door sill fixed. Is it the LED one? Where did you fix it? 2020 also? ↡ Advertisement Link to post Share on other sites More sharing options...
New Proton Perdona.
New Proton Perdona.
Proton overseas
Proton overseas
Proton To Introduce smart Electric Vehicles In Malaysia
2022 Proton Persona 1.6 Premium
2022 Persona & Iriz facelift
27 year old Malaysian save money driving a 21-year-old Proton Saga
Proton Exora#2
Proton Exora#2
Proton X50
Proton X50
