  • Search this thread
  • Reply to this topic
69 replies to this topic | 0 praises
#1
Posted 24 May 2009 - 01:49 AM
Stash
  • THREAD STARTER
  • Premium member
    Stash
    2nd Gear
    Author Image
    168
hi is there any site i can check the best tyre pressure for my tyre?
my current specs are 195/ 55 R 15
#2
Posted 24 May 2009 - 02:00 AM
Nohnemwan
  • Nohnemwan
    4th Gear
    Author Image
    627
How old is your car?
Have you looked inside your door sill?
Have you looked inside your owners' manual?
If so, it would be extremely unusual that these 2 locations not have tyre pressure info specific to your car.
#3
Posted 24 May 2009 - 02:16 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    47,960
Best for FC? Best for grip? Best for floating?(Mas used a tire to float across to M'sia)
#4
Posted 24 May 2009 - 03:10 AM
Iziz
  • Iziz
    6th Gear
    Author Image
    2,611
We r all using flotation devices for our cars. Can go on land, can go on water also! idea.gif
#5
Posted 24 May 2009 - 03:25 AM
Nolicense
  • Premium member
    Nolicense
    Supercharged
    Author Image
    6,389
optimum is 20% below tire max pressure. buy tire based on the manufacturer recommended load and speed rating. size based on your rims and overall tire size the car can take. highway driving can up the pressure to 15% below max pressure.
Edited by Nolicense, 24 May 2009 - 03:27 AM.
________________________________
KNN!!!! Kenna f*ck spider again!
#6
Posted 24 May 2009 - 08:37 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
20% below recommended max tyre pressure, sound too low for full load of 4 adult passegers. Continue use at such pressure the tyres will overtime suffer wear along the central surfaces. For low profile tyre, the rolling stress and temp built up on the tyre side walls will be very high and may cause the tyre to burst if it hit any roadsides objects.
Visit My Facebook for the latest automotive breaking news & innovative specialty tools.
#7
Posted 24 May 2009 - 08:59 AM
Amortifiedpenguin
  • Amortifiedpenguin
    5th Gear
    Author Image
    1,260
Is it wrong or bad to use the pressure recommended by the manual? im driving a 1.3L hatch on 155/65/14 weighing 0.995 tons usually alone or with one pax driven only in sg. Max traveled speed 110km/h (iknowiknow). Recommended is 280psi which is quite high i recon. Priorities- safety, performance, tire wear, fc, road noise. Any advice would be received with a hug!
Need cheap cable TV? Need broadband? Need 7pm-10pm job? Find me!
#8
Posted 24 May 2009 - 09:26 AM
Nolicense
  • Premium member
    Nolicense
    Supercharged
    Author Image
    6,389
Sorry, I wrote for highway 15% less than max tyre pressure, but left out for full load also. Thanks to help clarify.
I read it somewhere but cannot find the info now, I reproduce in table for you to see if its too low and for everyone to judge for themselves.
Max Less ~15% Less ~20%
38psi 33psi 30psi
44psi 38psi 36psi
50psi 43psi 40psi
for me i use 44psi max and inflate to 36psi as per my car manual. Since the table corresponds quite well to my car manual, I wonder if it is also a rough guide for other cars. FYI my Load Index correspond to 600kg.
#9
Posted 24 May 2009 - 09:44 AM
Babyt
  • Babyt
    Author Image
    8,297
i realised TC service centre pumped my car front tyres at 38 instead of recommended 32 stated on the sticker....no wonder after getting back the car, whenever i brake the car, it feels so abrutly.
#10
Posted 24 May 2009 - 09:58 AM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
You may have get it wrong - it maybe 280Kpa and NOT 280psi. All common air compressors in singapore by safety regulations must be set with max air pressure of not more than 150psi.
#11
Posted 24 May 2009 - 10:50 AM
Maffie
  • Maffie
    1st Gear
    Author Image
    75
A good way is to take your max load rating on your tire's sidewall and minus about 20%, which was what some post-ers has already mentioned.
Also, to penguin, it's impossible to be 280psi. No road legal car tire I know can take that kind of pressure.
#12
Posted 24 May 2009 - 05:04 PM
Amortifiedpenguin
  • Amortifiedpenguin
    5th Gear
    Author Image
    1,260
oh crap. blush.gif pai say sia.
280Kpa. If i really pump 280psi i think you'll see me in the news- "penguin killed by flying rim and tire fragments"
280Kpa/40psi (i got it right this time, i think) 155/65/14 on a 0.995ton hatchback for singapore roads. is it ok or good or bad to inflate to that pressure?
#13
Posted 24 May 2009 - 06:16 PM
Stash
  • THREAD STARTER
  • Premium member
    Stash
    2nd Gear
    Author Image
    168
well my original tire size is 185, 55 r15
now its 195 55 r15.
its there any site i can confirm.
how do we know we pump the correct pressure???
#14
Posted 25 June 2009 - 08:36 PM
Nom107
  • Nom107
    2nd Gear
    Author Image
    186
is "soft" or "hard" tire still pump the same pressure ???
#15
Posted 25 June 2009 - 08:50 PM
Yeobh
  • Yeobh
    Supercharged
    Author Image
    6,008
For the start you need to purchase a reliable tyre gauge
#16
Posted 25 June 2009 - 09:01 PM
Karebu
  • Karebu
    5th Gear
    Author Image
    2,430
eh.. mines 83W on the side
-20% gives me 66.4. what does that mean? 66.4kpa? cannot be right. confused.gif
83 supposed to be 1074pounds or 487kg. either way the numbers are too big.
#17
Posted 25 June 2009 - 10:06 PM
JonEthan
  • JonEthan
    Clutched
    Author Image
    31
ey, 83W is not the tyre pressure. 83 is the load rating and W is the speed rating.
definitely not refer to pressure
#18
Posted 28 June 2009 - 01:40 PM
Skilled
  • Skilled
    1st Gear
    Author Image
    96
front: 220, back 230.
..Enjoy the equipment..Enjoy the tuning..Enjoy the music..Enjoy Carolyn Hall Young Art pieces..
#19
Skilled
  • Skilled
    1st Gear
    Author Image
    96
#20
Posted 28 June 2009 - 02:01 PM
Kotila
  • Kotila
    2nd Gear
    Author Image
    242
I think should be front 230 and back 220 as the engin is in front and heavy.
Edited by Kotila, 28 June 2009 - 02:01 PM.
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Quick Reply
