Route88 2nd Gear July 17, 2009 Share July 17, 2009 Going for bleeding soon ~ any suggestion? ↡ Advertisement Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie July 17, 2009 Share July 17, 2009 hi this one is quite good http://www.amsoil.com/StoreFront/bf4.aspx the way the packed it is already quite Link to post Share on other sites More sharing options...
Jaguar Neutral Newbie July 17, 2009 Share July 17, 2009 Brake fluid of dot 3 & 4 cannot be mix and also need to see the spec that the brake system should be. But all new car should not be a problem and brake system should be able to take dot 4 brake fluid. Replace and bleed brake fluid after a period of time is recommended and good pratice. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 17, 2009 Share July 17, 2009 ATE Dot 4, very good wet and dry boiling point. Link to post Share on other sites More sharing options...
Route88 2nd Gear July 17, 2009 Author Share July 17, 2009 Thanks bro,will pin it on my list Link to post Share on other sites More sharing options...
Route88 2nd Gear July 17, 2009 Author Share July 17, 2009 I heard cannot use DOT 5.but 5.1 can, any reason? Link to post Share on other sites More sharing options...
Route88 2nd Gear July 17, 2009 Author Share July 17, 2009 Heard tis brand ATE b4, but never actually seen the bottle,where to get it? Link to post Share on other sites More sharing options...
Gary84 1st Gear July 17, 2009 Share July 17, 2009 Amsoil or Motul Dot 5.1 are recommended..... Link to post Share on other sites More sharing options...
Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 Motul added, Thanks. Roughly hw much bottle for bleeding required? 4 disc brake all round Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged July 18, 2009 Share July 18, 2009 Heard tis brand ATE b4, but never actually seen the bottle,where to get it? Link to post Share on other sites More sharing options...
Kb27 Supersonic July 18, 2009 Share July 18, 2009 Heard tis brand ATE b4, but never actually seen the bottle,where to get it? ATE Super Blue Racing can get from Torino, a row of shophouses along AMK Ave 3, Ind Park 2 which is closed to the Caltex. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 18, 2009 Share July 18, 2009 Dot 5 is glycol base and 5.1 is silicon base Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 18, 2009 Share July 18, 2009 a dot 4 @$7/L is gd enuh....more than tat is overkill unless u track Link to post Share on other sites More sharing options...
Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 the industrial park at bkt merah, opposite queensway shopping centre is selling. there are 2 type, the normal 1 is $14/tin of 1 liter, another type "sports edidtion" . blue colour fuild, $18/ tin of 1 liter. both dot 4 rating. ATE Super Blue Racing can get from Torino, a row of shophouses along AMK Ave 3, Ind Park 2 which is closed to the Caltex. Thanks for the pointers Link to post Share on other sites More sharing options...
Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 Dot 5 is glycol base and 5.1 is silicon base How much quantity of Brake fluid needed to bleed? 4 dics all round TIA Link to post Share on other sites More sharing options...
Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 a dot 4 @$7/L is gd enuh....more than tat is overkill unless u track Yes ,intend to use DOT 4 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 18, 2009 Share July 18, 2009 2L shlb b enuh......... Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 18, 2009 Share July 18, 2009 Check yr brake system total requirement - add 50% more for flushing all the old fluid and clean up the system. ↡ Advertisement Link to post Share on other sites More sharing options...
Meaning of happiness!
Good knee surgeon to rec?
Which brand and model for Smart TV? So many until blur...
