Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 2L shlb b enuh......... Check yr brake system total requirement - add 50% more for flushing all the old fluid and clean up the system. Noted ↡ Advertisement Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 18, 2009 Share July 18, 2009 Brake fluid of dot 3 & 4 cannot be mix and also need to see the spec that the brake system should be. But all new car should not be a problem and brake system should be able to take dot 4 brake fluid. Replace and bleed brake fluid after a period of time is recommended and good pratice. Actually Dot 3, Dot 4 and Dot 5.1 is same category, can be mix. But Dot 5 is different, should not be mix with the rest. Link to post Share on other sites More sharing options...
Route88 2nd Gear July 18, 2009 Author Share July 18, 2009 Any good w/shop to recommend for a good bleeding job? If not comfortable can pm me. Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 18, 2009 Share July 18, 2009 Any good w/shop to recommend for a good bleeding job? If not comfortable can pm me. I like to know too, my car also due for a brake fluid replacement soon.... Previously I went Stamford Tyre for brake fluid flush, using their brand which was Caltex.... Link to post Share on other sites More sharing options...
Yuan 6th Gear July 20, 2009 Share July 20, 2009 Actually, brand is one but maintenance, is in my opinion, equally important. Brake fluids should be changed and renewed especially when we are driving in Singapore where there are a lot of start stop situations and as a result of such situations, a lot of moisture are being absorbed into the brake fluid during the frequent start stop. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 20, 2009 Share July 20, 2009 Changing Brake fluid base on distant travelled or the fluid colour is not accurate, it's best to use a moisture meter to gauge the % of moisture in the system. Link to post Share on other sites More sharing options...
Route88 2nd Gear July 20, 2009 Author Share July 20, 2009 I like to know too, my car also due for a brake fluid replacement soon.... Previously I went Stamford Tyre for brake fluid flush, using their brand which was Caltex.... Yes,same same, not sure can bring own oil to service there? If not gotto find other w/shop. Still searching for a good one Link to post Share on other sites More sharing options...
Yuan 6th Gear July 20, 2009 Share July 20, 2009 Yes,same same, not sure can bring own oil to service there? If not gotto find other w/shop. Still searching for a good one Link to post Share on other sites More sharing options...
Route88 2nd Gear July 20, 2009 Author Share July 20, 2009 Previously I had used Fuchs which I bought from stockist and it was good. Now I am using Volker brand. It is fine and acceptable to me. Thank thanks ~ Mintex also have their own brake fluid. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie July 20, 2009 Share July 20, 2009 ATE brand of brake fluids is the way to go. Been using this for years. Link to post Share on other sites More sharing options...
Route88 2nd Gear July 20, 2009 Author Share July 20, 2009 ATE brand of brake fluids is the way to go. Been using this for years. Manage to dig out old thread,tis is wat i found Link to post Share on other sites More sharing options...
Kyojin 1st Gear July 20, 2009 Share July 20, 2009 i second ATE. even the regular DOT4 is good enough. Link to post Share on other sites More sharing options...
Fkadir Neutral Newbie July 25, 2009 Share July 25, 2009 Any DOT4 should be ok I think. Just get it from the Esso or Shell petrol station? Link to post Share on other sites More sharing options...
Weiming 1st Gear July 25, 2009 Share July 25, 2009 If you do not track or drive the car aggressively, then any OTC brake fluid will do (check to make sure if your braking system accepts DOT 3 or 4). For most drivers, the important thing is not the brand but the duration between bleeds. I do it once every two years together with my clutch fluid (mine is a manual transmission). Your regular mechanic should be able to do the bleeding job as it is rather straight forward. Link to post Share on other sites More sharing options...
Seanboi 1st Gear July 29, 2009 Share July 29, 2009 the industrial park at bkt merah, opposite queensway shopping centre is selling. there are 2 type, the normal 1 is $14/tin of 1 liter, another type "sports edidtion" . blue colour fuild, $18/ tin of 1 liter. both dot 4 rating. Bro that time i went to Bkt Merah, he told me the ATE changed packaging to some OEM Audi/BMW packaging? From the usual squarish shape to a cylindrical shape? Or did i kena conned? Link to post Share on other sites More sharing options...
Lordau Neutral Newbie September 3, 2009 Share September 3, 2009 err..guys how do we noe when we need to change the brake fluid ah? Link to post Share on other sites More sharing options...
Yuan 6th Gear September 3, 2009 Share September 3, 2009 err..guys how do we noe when we need to change the brake fluid ah? Due to our frequent start-stop traffic situations in Singapore, it is advisable to renew the brake fluid once every 2 years. Notwithstanding the above, if you feel that your brakes are spongy, change of brake fluid is one of the options you might want to consider. The start-stop situations may result in moisture being absorbed into the brake fluid and thus causes the brakes to be spongy. Link to post Share on other sites More sharing options...
Maroon5 5th Gear September 4, 2009 Share September 4, 2009 act jus to add...for normal driving, brand or not makes little difference...im using voltronic now but it seems no difference at all with my previous stock fluid...try it only if u r really itchy... ↡ Advertisement Link to post Share on other sites More sharing options...
Good knee surgeon to rec?
Which brand and model for Smart TV? So many until blur...
Recommend me a good handheld vacuum
Brake Pads
Brake Pads
