Yeobh 4th Gear September 5, 2009 Share September 5, 2009 Get yr mech to do a test with a digital moisture tester. ↡ Advertisement Link to post Share on other sites More sharing options...
Mk1 Neutral Newbie December 28, 2009 Share December 28, 2009 how about STP brake fluid? Link to post Share on other sites More sharing options...
Desong Neutral Newbie December 29, 2009 Share December 29, 2009 do u guys know that brake fluids are in fact vegetable based Link to post Share on other sites More sharing options...
Nmnhnlm Clutched December 31, 2009 Share December 31, 2009 Changing Brake fluid base on distant travelled or the fluid colour is not accurate, it's best to use a moisture meter to gauge the % of moisture in the system. Wah, don't have to be that fierce lar.... You won't lose your brakes just because of moisture in the fluid. It will just become spongy and less sensitive over time. When that happens, just change the fluid lor. Seriously, I would be more worried about brake pads, rotors and tyres. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched December 31, 2009 Share December 31, 2009 how about STP brake fluid? Yes, it will do fine. Even other brands like Mobil, Caltex etc will do fine as well. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched December 31, 2009 Share December 31, 2009 do u guys know that brake fluids are in fact vegetable based Oh is it? I thought brake fluid is hydraulic oil? Link to post Share on other sites More sharing options...
V2-g Neutral Newbie December 31, 2009 Share December 31, 2009 on Bendix 5.1 now... paid ard 23rm for a bottle...nd ard 3 btls for bleeding my whole system.... now brakes are very responsive... fluid with labour in JB, works out to ard 150rm.... Link to post Share on other sites More sharing options...
Chiangauto Clutched December 31, 2009 Share December 31, 2009 you may try Bosch Dot 4,quite good actually. Link to post Share on other sites More sharing options...
Kel81 Neutral Newbie January 30, 2010 Share January 30, 2010 any side effect if mixed dot 4 and dot 5.1? Link to post Share on other sites More sharing options...
Picanto 3rd Gear January 30, 2010 Share January 30, 2010 any side effect if mixed dot 4 and dot 5.1? it will be a disaster. do not mix Link to post Share on other sites More sharing options...
Darkblue 1st Gear January 30, 2010 Share January 30, 2010 Regular DOT 4 good enough liao... Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 31, 2010 Share January 31, 2010 Both boil at different temp. For some brake systems the seals maybe be affected. ↡ Advertisement Link to post Share on other sites More sharing options...
Meaning of happiness!
Good knee surgeon to rec?
Which brand and model for Smart TV? So many until blur...
