Nismo Neutral Newbie September 21, 2009 Share September 21, 2009 If your PCD comes in odd size.. whr to find such rims? Mine's 5x105.. ↡ Advertisement Link to post Share on other sites More sharing options...
Try_conti 2nd Gear September 21, 2009 Share September 21, 2009 what ride is that ? Link to post Share on other sites More sharing options...
Nismo Neutral Newbie September 21, 2009 Author Share September 21, 2009 its the Cruze... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear September 21, 2009 Share September 21, 2009 u may want to try to pm fishycat to see if he has lubang ..... Link to post Share on other sites More sharing options...
Rmteamrims 1st Gear September 22, 2009 Share September 22, 2009 (edited) the pcd nt 115? Edited September 22, 2009 by Rmteamrims Link to post Share on other sites More sharing options...
Sturtles 6th Gear September 22, 2009 Share September 22, 2009 pcd shld be 115. Source? Chevrolet and Chrysler are similarly bankrupt, but in different ways Link to post Share on other sites More sharing options...
Nismo Neutral Newbie September 23, 2009 Author Share September 23, 2009 the pcd nt 115? 115 is for the 2.0TDI which is not avail in sg as of yet ... the 1.6 and 1.8 petrol is 105...headache Link to post Share on other sites More sharing options...
Rmteamrims 1st Gear September 24, 2009 Share September 24, 2009 YES, its confirmed. 5x105 1 more month time will have 17" rims available.. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged September 24, 2009 Share September 24, 2009 Just go to the larger or more reputable tyre shop and they should be able to order for you if they don't already have. But 1st, look on the internet and make sure the model you like come in the specific PCD and offset. Mine is 5X100...not a common size too....very limited design, offset, etc...often have to make special order. Link to post Share on other sites More sharing options...
Essilor Neutral Newbie September 24, 2009 Share September 24, 2009 If your PCD comes in odd size.. whr to find such rims? Mine's 5x105.. Hi, PM u.... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear September 24, 2009 Share September 24, 2009 5x100 ? not many make use that pcd. i know cos mine also 5x100 Link to post Share on other sites More sharing options...
Nismo Neutral Newbie September 25, 2009 Author Share September 25, 2009 YES, its confirmed. 5x105 1 more month time will have 17" rims available.. 17".. wat brand?..the brand u carry isit? got 18"s or not bro... Link to post Share on other sites More sharing options...
Nismo Neutral Newbie September 25, 2009 Author Share September 25, 2009 Just go to the larger or more reputable tyre shop and they should be able to order for you if they don't already have. But 1st, look on the internet and make sure the model you like come in the specific PCD and offset. Mine is 5X100...not a common size too....very limited design, offset, etc...often have to make special order. yup.. thanks lots for the info.. maybe have to special order rims liao.. argh.. gona cost extra... Link to post Share on other sites More sharing options...
Nismo Neutral Newbie October 24, 2009 Author Share October 24, 2009 YES, its confirmed. 5x105 1 more month time will have 17" rims available.. bro... so the rims are here already?.. got 18"? Link to post Share on other sites More sharing options...
Wreckwrx 1st Gear October 24, 2009 Share October 24, 2009 If your PCD comes in odd size.. whr to find such rims? Mine's 5x105.. Don't have to use the exact same offset if you don't mind using spacers... and worst case if spacers still not good enuff, you can also go to the workshop to roll the wheel arch to accomodate the rims... Just some suggestions. Link to post Share on other sites More sharing options...
Nismo Neutral Newbie October 26, 2009 Author Share October 26, 2009 stock rim are 16" et39.. if i put a pcd adapter which minimally measures 20mm to fit other pcd wheels.. and i get a set of 18" et45... will it fit?.. i wonder... any wheel fitment gurus.. i like a flushed look. btw.. pcd adapters on the front wheel.. many ppl says its safe as long the fitment of the hub centric is made to fit the rim.. but im still skeptical.. anybody using? Link to post Share on other sites More sharing options...
Omu Neutral Newbie October 28, 2009 Share October 28, 2009 What a headache . Need new driller then.... Link to post Share on other sites More sharing options...
Nismo Neutral Newbie November 24, 2009 Author Share November 24, 2009 any new of any rims avail now? ↡ Advertisement Link to post Share on other sites More sharing options...
Does rims change shape/warp over time?
Where can I get rubber sheet
Shipping USA Rims
Shipping USA Rims
Singapore Brand Rims VS China Brand Rims
Scientists find rich and poor are 'biologically different'
