  • Search this thread
  • Reply to this topic
30 replies to this topic | 20 praises
#1
Posted 04 November 2009 - 04:40 PM
Sabian
  • THREAD STARTER
  • Sabian
    NOS-ed
    Author Image
    15,416
Tyre Noob here.
Trawled through the forum, it seems different tyre shop has different practice.
What is your normal SOP and what are the charges like?
#2
Posted 04 November 2009 - 04:52 PM
Colin03
  • Premium member
    Colin03
    4th Gear
    Author Image
    796
Tyres balancing will do if you did not change rims.
rdgs
#3
Posted 04 November 2009 - 04:56 PM
Furrynadz
  • Premium member
    Furrynadz
    Author Image
    8,362
best to check all suspension components / bushings and do alignment every tyre change
#4
Posted 04 November 2009 - 05:02 PM
Help1
  • Premium member
    Help1
    5th Gear
    Author Image
    1,997
whenever change new tyres, balancing is a must
rotate tyres....
if u change 2 tyres only, then the older one will put to the front and newer one will put to the back (usually this case) as u want the older one to wear out faster but to some ppl, they want the newer one to put infront
if u change all 4, no need to rotate liao
do alignment only if you feel your steering goes to one side when driving or upon changing tyres, one side is botak (uneven wear)....however no one is stopping u from doing alignment whenever u change tyres if u have deep pockets
#5
Posted 04 November 2009 - 05:08 PM
Mzrmazda3
  • Premium member
    Mzrmazda3
    2Fast2Furious
    Author Image
    27,868
If your previous set of tyres have no uneven wear then balance it would be fine nod.gif else then go for alignment nod.gif
#6
Posted 04 November 2009 - 05:43 PM
Dscheng
  • Premium member
    Dscheng
    5th Gear
    Author Image
    1,272
It is better to do alignment & high speed balancing also.
** 100V, the power of electric.
2007-Civic EG, 2009-Lancer EX, 2012-JDM WRX,
2012-Civic FD, 2014-Lancer CS3M, 2015- H Stream RSZ.
#7
Posted 04 November 2009 - 06:11 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    47,147
After tire change, the tire shop ppl will balance the wheel by putting the wheel on a rotation device and "free spin" & pasting small counter balance on your rims where it stops. Think scotch taping a 20cent coin onto your standing fan's plastic blade, when you switch on your fan you can see that the one blade which is heavier will rotate in an awkward way. If you let it spin like that long term the shaft will eventually give way.
Now the new tire & rim together is like the fan blade with a 20cent coin. What ppl do is add little strips of square metal weights to balance the lighter part of the wheel to balance it.
Rotation is a swap between your front 2 wheels(to the back) & rear 2 wheels(to the front). Most ppl will do that on 10k km intervals for even tire wear.
Front wheel alignment is about the same at 10k or 20k km intervals. You are the driver, you know best when to do it. Note that roads are gently sloped to the drainage system to prevent standing water after rain. So dun vent your anger at the alignment workshops when your car starts to pull one side all the time. When your car's steering is light, the pull is quite obvious. In an event of an accident like a slight bump from the rear, the alignment will be out also.
Edited by Watwheels, 04 November 2009 - 06:15 PM.
#8
Posted 04 November 2009 - 06:33 PM
Sabian
  • THREAD STARTER
  • Sabian
    NOS-ed
    Author Image
    15,416
Kum siah for all the advice!
#9
Posted 05 November 2009 - 10:16 AM
Beregond
  • Beregond
    NOS-ed
    Author Image
    12,759
rotate tyres....
most shop balance the front tyres, reason ??? not that the tyres need balancing , instead they balance BECAUSE the driver can feel the virbation from the front tyres.
BUT is it the correct thing to do ?? DOES it mean you cannot feel the virbation from the rear tyres , SO u dun need to balance it??
some of the old uncle or new tyre man dun even know why they are doing the balancing, they are doing 'dead work' only front 2 balance.
drivers? , worst , 80-90 % dun even know what is balancing .
#10
Posted 05 November 2009 - 10:30 AM
Help1
  • Premium member
    Help1
    5th Gear
    Author Image
    1,997
it depends on the car whether is FD, RD or AWD...how many really can feel rear tyres vibrate whereas most of the feedback from the front and is very noticebly, vibrate can be due to many factors like warped rims, uneven wear etc etc...looks like u have indepth knowledge and experience, may i know u from which trade...tyre????
#11
Posted 05 November 2009 - 10:32 AM
GoodCar
  • Premium member
    GoodCar
    6th Gear
    Author Image
    3,876
When I change my tyre every two years, I do it all at one go, save down time lah.
I prefer planned maintenance work.
#12
Posted 05 November 2009 - 10:38 AM
Help1
  • Premium member
    Help1
    5th Gear
    Author Image
    1,997
true...planned maintenance work is good but also a routine maintenance (i.e. balance every 8-12k depends on ppl preference but usually at 10k) is best recommended rather than u wait for every 2 yrs.... :)
#13
Posted 05 November 2009 - 11:16 AM
Beregond
  • Beregond
    NOS-ed
    Author Image
    12,759
i am doing tyres, but i only want to discuss here, tyre rotating is like a 'top' spinning on a table.
imagine how the 'top' will spin if it is unbalance?? (woobleing etc etc) now imagine the top is spinning at the speed u are driving , 90 km/h??
imagine your tyre is unbalance, of couse at the rear u wont feel the virbation , but after a long period, u will have uneven wear of rear tyres.
when u do tyres rotation , and swap the rear tyres in front, u might have problem, of course most of the time the problem is over look, they thought tyres is old, normal, etc etc .
but 1 thing i can be sure is, even if u go to MAJOR shop like stamford or autobak, the same thing happen, only front 2 wheel is balance . -.-
#14
Posted 05 November 2009 - 11:33 AM
Help1
  • Premium member
    Help1
    5th Gear
    Author Image
    1,997
uneven wear on rear tyres are affected by many factors such as overinflate/underinflate air pressure, rim warp, incorrect balancing, suspension, irregular or no rotate n balance. the practice and proven of performing front 2 wheel balancing has been going on for so many yrs and majority of car owners has no such problem. Of course as i said, to have a peace of mind, pamper the tyres abit and dun mind paying abit more for the effort, one can always opt for all 4 wheels to be balance when comes to rotate and balance maintenance....:)
#15
Posted 05 November 2009 - 11:37 AM
GoodCar
  • Premium member
    GoodCar
    6th Gear
    Author Image
    3,876
Is on wheel balancing good?
#16
Posted 06 November 2009 - 11:05 PM
Coconut23
  • Coconut23
    Clutched
    Author Image
    26
Mr Coconut23
#17
Posted 07 November 2009 - 12:14 AM
Emils
  • Emils
    4th Gear
    Author Image
    560
Mm... After hearing out all of you, seems like there are quite worthy reasons to do a balancing of the tyres. So how much should one expect to pay for balancing of 2 and 4 tyres? Thanks!
#18
Posted 07 November 2009 - 10:48 AM
Yuan
  • Premium member
    Yuan
    2Fast2Furious
    Author Image
    28,826
Wheel balancing can be done during your regular servicing with your trusted mechanic. Wheel alignment is best done every 10k or 20k mileage.
|1994|Legum Baccalaureus-Legum Magister|Financial Prudence|HDB|MedisaveApproveIntegratedPlan-Insurance|Manchester United FC|Genuine Original Equipment Manufacturer (OEM) Specifications-Parts-Accessories|Suzuki Swift GS|Mitsubishi Lancer CS 3|Volkswagen Golf MKVI|Audi A4B9|
#19
Posted 07 November 2009 - 10:49 AM
Yuan
  • Premium member
    Yuan
    2Fast2Furious
    Author Image
    28,826
Actually the cost would have pay off in terms of better driveability and safety on the road since the tyres are the car's only contact with the road.
#20
Posted 24 December 2009 - 10:05 PM
Picanto
at what speeds would the vibration be felt if the tyres/wheels are not well balanced?
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: After, Tyre, Change, Balancing and 3 more...
