  • Search this thread
  • Reply to this topic
82 replies to this topic | 0 praises
#1
Posted 09 December 2009 - 05:53 PM
Beregond
  • THREAD STARTER
  • Beregond
    NOS-ed
    Author Image
    12,298
Any 1 use the liqui moly engine flush b4?
now they having a package promotion , 3 in 1 or 3 can.
1:engine flush
2: mos2 anti-frictioin engine treatment
3: fuel injection cleaner
any 1 try the above package b4?? its going around for 68 sgd+- package.
need some feed back b4 i try it LOL . cheers.
#2
Posted 09 December 2009 - 10:39 PM
Picanto
which shop offer this?
#3
Posted 09 December 2009 - 11:36 PM
Darkblue
  • Darkblue
    5th Gear
    Author Image
    1,033
1 + 2 - Pour into engine oil sump
3 - Pour into petrol tank
#4
Posted 10 December 2009 - 09:45 AM
Beregond
  • THREAD STARTER
  • Beregond
    NOS-ed
    Author Image
    12,298
i saw a shop along loyang way having a promotion 78sgd full synthetic oil and filter change , i go ask abit, they intro to me the liqui moly flush , 68 sgd .
but i think all shop that carry liquimoly oil should have this 3 bottles, package,
just wanna know how is the effect. really tempted to try . LOL.
#5
Posted 10 December 2009 - 04:49 PM
Zyrofillica
  • Premium member
    Zyrofillica
    6th Gear
    Author Image
    4,740
anyone know which shop sells liqui moly products? such things can easily diy just before you go to your workshop to get your oil changed.
#6
Zyrofillica
  • Premium member
    Zyrofillica
    6th Gear
    Author Image
    4,740
#7
Posted 10 December 2009 - 05:22 PM
Beregond
  • THREAD STARTER
  • Beregond
    NOS-ed
    Author Image
    12,298
i dun think any retail shop got sell. if got pls share the place , lol , i check diy need how much . if i save only a bot i rather let them service shop do for me . kekeke.
#8
Posted 10 December 2009 - 05:40 PM
Contax
  • Premium member
    Contax
    6th Gear
    Author Image
    4,557
Yes there is.But if you buy individual item... bo-wah liao .
Try:
iEnergi
1 kaki bukit road 1
Enterprise one #03-33
Tel:67476063
#9
Posted 10 December 2009 - 06:01 PM
Tigershark1976
  • Premium member
    Tigershark1976
    2Fast2Furious
    Author Image
    22,233
u meant $68 for the flush?? then forget it. just get some cheap mineral oil, like toyota 10W30 mineral oil, Only $17/4 litres.... Change it with this cheap oil...run for 500kmto 1000km and drain, repeat 2 times and you engine is as clean as new. Best part is, u can use it while flushing your engine + no worries of the oil leak problem after flushing.
Edited by Tigershark1976, 10 December 2009 - 06:03 PM.
#10
Posted 10 December 2009 - 06:05 PM
Tigershark1976
  • Premium member
    Tigershark1976
    2Fast2Furious
    Author Image
    22,233
no... never drive your car with these engine flush liquid. it will damage your car. The workshop usually pour in the engine flush liquid, start your car and rev it to 2K to 4K RPM for a minutes b4 draining the oil + engine flush mixture out.
#11
Posted 10 December 2009 - 06:29 PM
Zyrofillica
  • Premium member
    Zyrofillica
    6th Gear
    Author Image
    4,740
yup you cant drive under load with it thats why you shd put it in when u are just around the corner to your workshop and then drive slowly into your shop and let it idle till you think its done before getting your mech to change oil.
didnt know changing normal engine oil can get rid of deposits. here is a vid showing how normal oil changes (even every 100km is not enough)
engine flush pro tec
#12
Posted 10 December 2009 - 07:02 PM
Beregond
  • THREAD STARTER
  • Beregond
    NOS-ed
    Author Image
    12,298
wow , i like that video . nice intro to engine flush .
#13
Posted 12 December 2009 - 01:06 AM
Jasonlim8213
  • Jasonlim8213
    Banned
hi will try to find out the workshop address that sell this products
Edited by Jasonlim8213, 12 December 2009 - 01:06 AM.
#14
Posted 12 December 2009 - 01:54 PM
Tseusus
  • Tseusus
    Clutched
    Author Image
    27
stay away from these engine flush if you can. They usually contain large amount of harsh solvants
#15
Posted 14 December 2009 - 12:16 AM
Tigershark1976
  • Premium member
    Tigershark1976
    2Fast2Furious
    Author Image
    22,233
yup. fully agree. if die die wanna flush, get some cheap but established dino oil for flushing. I always use tpyota 10W30 fo such purpose (only $18/4L). simply change the engine oil using the mentioned cheap oil, use it for 500km to 1000km and repeat another 1 round if you are really kiasu, another 2 rounds if you have too much money... i usually do it every 20k or 30k. down side is... its not so environmental friendy n may cost you more....
#16
Posted 14 December 2009 - 04:31 PM
Da_editor
  • Premium member
    Da_editor
    4th Gear
    Author Image
    519
Hi Bro
saw this promotion under the thread.
Liqui Moly servicing, with engine flush at $118.
Liqui Moly Servicing from Lee Sheng
Any bros try it before?
Is it consider as cheap or good deal?
My Favourite Singapore Car Reviews.
#17
Posted 27 December 2009 - 01:31 PM
Nmnhnlm
  • Nmnhnlm
    4th Gear
    Author Image
    682
As long as you change your oil regularly, engine flush is not needed at all.
Also engine flush can do more harm than good esp. to old engines. Deposits can actually act as seals to prevent oil leakage and reduce blow by etc. Removing these deposits can cause problems.
#18
Posted 27 December 2009 - 01:39 PM
Nmnhnlm
  • Nmnhnlm
    4th Gear
    Author Image
    682
Badly flawed video..........
Deposits settled at bottom of crank case only if your engine is cold..... Thats why its recommended to warm up the engine before changing oil. Engine oil already contains additives to keep the engine reasonably clean. Thus flushing is not needed unless you never change engine oil for a long long time.
New engines don't need flushing because there isnt much deposits. Old engines needs to becareful about flushing.....
#19
Posted 27 December 2009 - 05:46 PM
Evilernie
  • Premium member
    Evilernie
    5th Gear
    Author Image
    1,239
How about for those OPC car?
Honda:EG6~FD1~FD2R
Spirit of Honda
SJG
Confidence in Motion
#20
Posted 27 December 2009 - 06:09 PM
Maroon5
  • Maroon5
    Supercharged
    Author Image
    7,310
last time my coe car used to go in JB for oil change n servicing, engine oil flush is a standard. pour in, let engine idle for few min then drain out. did not encounter any issues. believe regulars to Hawk Tayar shd know abt this.
Paul Scholes. He scores goals.
Dynamics Mechanic Pte Ltd
Quick Reply
Tags: LIQUI, MOLY, ENGINE, FLUSH
