Nmnhnlm Clutched January 28, 2010 Share January 28, 2010 oh mothballs. Yes I read abt it. It can be used as octane booster though I never try it. ↡ Advertisement Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 28, 2010 Share January 28, 2010 (edited) dont drop in the mothball to the oil tank directly!!! u need to use a bottle to mix the mothball with petrol 1st b4 pouring into the tank. otherwise, the mothball may choked the oil filter! thank god i didnt have time to try today... if not maybe kanna choke liao... haha... how long will it take to dissolve? i can throw it in the tank and leave it inside for 1-2 hours should be ok right? i saw the myth buster clip... they tried adding so many other stuff... including bleach... haha... Edited January 28, 2010 by Ken4555 Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 28, 2010 Share January 28, 2010 thank god i didnt have time to try today... if not maybe kanna choke liao... haha... how long will it take to dissolve? i can throw it in the tank and leave it inside for 1-2 hours should be ok right? i saw the myth buster clip... they tried adding so many other stuff... including bleach... haha... i used to crushed it and throw into a bottle, then mixed with petrol and leave it overnight. mostly disolved but there is some residue at the bottom of the bottle. guess the petrol i put in is too little to disolve so many mothball. i pour in the mixture and then add in more petrol to disolve the remaining crushed mothball.... Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 29, 2010 Share January 29, 2010 i used to crushed it and throw into a bottle, then mixed with petrol and leave it overnight. mostly disolved but there is some residue at the bottom of the bottle. guess the petrol i put in is too little to disolve so many mothball. i pour in the mixture and then add in more petrol to disolve the remaining crushed mothball.... i read your post and it looks like you do it o a regular basis... some moth balls tat i use... evaporate completely in my cupboard after some time... but some cheaper ones used for toilets... they do not completely evaporate... guess the cheaper ones will end up a chunk in the oil tank or have excessive carbon built up... wats ur take on this? Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 29, 2010 Share January 29, 2010 dont drop in the mothball to the oil tank directly!!! u need to use a bottle to mix the mothball with petrol 1st b4 pouring into the tank. otherwise, the mothball may choked the oil filter! Actually, it doesn't really matter. cause your intake pipe comes with a pickup screen. Its a lifetime filter thats meant to prevent big particles from getting into the pump. Whatever that gets thru the pump will stuck and dissolve at the filter. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 29, 2010 Share January 29, 2010 Actually, it doesn't really matter. cause your intake pipe comes with a pickup screen. Its a lifetime filter thats meant to prevent big particles from getting into the pump. Whatever that gets thru the pump will stuck and dissolve at the filter. hmm... thats true also.. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged January 29, 2010 Share January 29, 2010 i read your post and it looks like you do it o a regular basis... some moth balls tat i use... evaporate completely in my cupboard after some time... but some cheaper ones used for toilets... they do not completely evaporate... guess the cheaper ones will end up a chunk in the oil tank or have excessive carbon built up... wats ur take on this? hahaha... no lah, 1 round nia. Scared liao.. the one 1 bot are those standard white balls. not very easy to disolved completely but given some time and enof petrol, it will disolved. those toilets type? guess you r refering to those big big piece type?? nvr tried b4 but i guess it not easy to disolve easily cos i see some coffeeshop using those in urinal bowl and it seems to be very lasting despite hundreds of flushing by water + urine everyday.. Link to post Share on other sites More sharing options...
Singaporeforest Neutral Newbie January 30, 2010 Share January 30, 2010 Sorry newbie here but happened to see this thread about the engine flush. my dad old bmw can go for it anot as his car engine seem not smooth anymore. any place around ang mo kio can intro? Link to post Share on other sites More sharing options...
Ken4555 1st Gear January 31, 2010 Share January 31, 2010 Sorry newbie here but happened to see this thread about the engine flush. my dad old bmw can go for it anot as his car engine seem not smooth anymore. any place around ang mo kio can intro? have a bottle of OWS engine flush... would you like to buy from me? just quote a price... reasonable i will send to you.. :-) just pour in the engine when you are at the mech workshop... run for 10mins and change your oil as per normal... thats wats the shops do anyways... and auto bacs charges $80 to do wat i just described... Link to post Share on other sites More sharing options...
Ronleech 2nd Gear January 27, 2011 Share January 27, 2011 My Mech told me not necessary...it might do harm to have a super clean engine then a seasoned one..... Maybe have to do "runin" again after flushing???!!! Lol.... Link to post Share on other sites More sharing options...
Ong80 Neutral Newbie November 9, 2017 Share November 9, 2017 FB_IMG_1510207668944 ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
Why aren't there any Formula 1 Wiki in here? Just merge all the threads.
