ok have decided to take the risk and install a set of VTTR bake calipers n rotors...
i'll pray hard no leaks... pads easy to run in... wont be too noisy...
cant seem to find any other better looking ones at this $ range...
Any comments? many thanks...
VTTR Brake rotors and calipers....
#1
Posted 14 December 2009 - 12:56 PM
#2
Posted 14 December 2009 - 01:01 PM
#5
Posted 14 December 2009 - 03:35 PM
the VTTR mini 6pot 303mm calpier dont have the same wordings on it as the normal 6 pot... haiz... cause i using 16"... unless i change 17".... but my tyres only 2months old... arghhhhh.... now again cant decide...
to change my brakes for better braking is BS... i only changing for looks... need bigger rotor...
#8
Posted 14 December 2009 - 09:59 PM
Your rotor is single pc or 2-pcs floating? If not wrong 2pc floating is ard $2200 +-.. so if you get it at $1800, it is a gd price with 2pcs type!
#10
Posted 14 December 2009 - 11:14 PM
vttr considered one of the few top range brand among other taiwan branded BBK. so far did not hear any bad reviews, but heard quite limited brake pads to chose from when changing it (switching to other brands).
alamak... dont know single or 2piece leh... cause today i went there but no stock... arghhh... but i think should be single cause usually 330mm above then got 2piece corect? btw sg carmart got a bad review... the guy change all four calipers and 3 leaked... damaged his expensive rims all... dont know how true...
i keeping my 16" so only can get up to 303mm... limited colour/rotor choice i guess... i called Chuan Lee the gal who answered said she thinks my 16" might be able to fit 324mm rotors... cant be correct? i ask her very sure anot then she said come down and check... but i was in the east so another day bah... i still rather VTTR over Nishim cause price not much difference... And VTTR looks nicer...
#11
Posted 14 December 2009 - 11:52 PM
why good?
because I don't like brembo brake.~
and VTTR is worth the price tag with good braking power.~
The Sky's The Limit!
![[angel]](http://www.mycarforum.com/public/style_emoticons/default/angel.gif)
#12
Posted 15 December 2009 - 12:00 AM
i think bremo is one of the best in the market... but too expensive i guess...
i think VTTR is worth the price in the market... for now...
how long you been using VTTR?
#13
Posted 15 December 2009 - 09:48 AM
For 16" rims, 303mm rotor is good enough. 324 is an overkilled and not necessary - dun even know can fit or not.
#14
Posted 15 December 2009 - 09:52 AM
thats wat i thought...
324mm wont even fit... even if can fit until hairs touching, calipers how????
but the way, i dont believe in overkill for brakes...
#15
Posted 15 December 2009 - 02:12 PM
anyways while filpping through hot stuff... i saw that Exotic Tuner has started to carry the K-SPORT brake kit set... Geoveen claims its better than VTTR, comes with repair kit, very light i carried it, lighter than a brembo, 2 piece rotor 304mm... very well priced... (lower than VTTR)...
http://www.k-sportra....com/index.html
http://www.ksport.co...ts.asp?f=brakes
http://www.k-sportra...technical2.html
I AM SUPER TEMPTED!!!!!!!!!!!!!!! anyone has reviews feedback please? thanks...
Edited by Ken4555, 15 December 2009 - 02:27 PM.
#16
Posted 15 December 2009 - 11:38 PM
We can spent those money on bodykits that serve no practical purpose why not on a brake set that looks good and enhance safety?
That why I consider it money well spend.
VTTR all 1 pc that why not so ex.
Try ATS, no regret buying that. Very good finishing.
Edited by Johorat, 15 December 2009 - 11:46 PM.
#17
Posted 16 December 2009 - 12:39 AM
303mm got 2 pcs type..
the gal say 16"can fit in 324mm?? can, but just the rotor only lor, no calipers. Do sales but don't know the products...
16" can go up to 303mm and depends on offset and the rim design. For my case, I cant fit due to my 16" rim design unless put spacer. But some having 15" can fit in without spacer.
#20
Posted 16 December 2009 - 08:02 AM
agreed... but worried hoses leak lah... OEM safest... Best for safety is actually just change better pads... but looks no difference lah... hahaha
Edited by Ken4555, 16 December 2009 - 08:04 AM.
Also tagged with these keywords: vttr
