  • Search this thread
  • Reply to this topic
43 replies to this topic | 0 praises
#1
Posted 24 March 2010 - 04:19 AM
Blackseal
  • THREAD STARTER
  • Premium member
    Blackseal
    5th Gear
    Author Image
    2,341
When Peugeot displayed the RCZ concept car in 2007 Frankfurt motor show, I think not many people believed it would be put into production. You know, in the past 30 years or so Peugeot built many radical concept cars but never put one into production. While most other manufacturers use concept cars to showcase new design theme or simply to preview the next production models, Peugeot's concept cars are always decoupled from the production side, strangely. They seemed to be created just for the fun of motor show spectators. Having disappointed for so many years, I didn't expect any exception for the RCZ concept.
To our surprise, two and a half years later the production RCZ stands in front of us. Moreover, its exterior and interior design is virtually the same as the show car. This signals a significant change in the product strategy of Peugeot. The dancing lion used to be rather conservative. Now in the attempt of migrating upmarket, it needs more image-boosting models - certainly more than the lukewarm 407 Coupe. RCZ will be the first one. This car is the French response to Audi TT. It is a very design-led product, or what people called "hairdresser's car".
Unquestionably, style is by far its greatest strength. Everything else is less significant. The RCZ not only looks exactly like a concept car happened on the road, its visual impact is, dare I say, greater than that of Audi TT ! Not believe ? Look at that cab-forward and wide-track proportion, that Zagato-style double-bubble roof and rear screen, those brushed aluminum roof rails and that kick at each shoulder line. They deliver a stronger message about style than the Audi masterpiece. Its road presence is absolutely stunning.
Unfortunately, everything else is rather ordinary. Take the dashboard for example, it comes straight from 308, although the center air-vent is replaced by an analogue clock, oddly. It's an upmarket piece of work by the standard of hatchbacks, but not quite in the league of Audi TT, where you will find more stylish gauges and more extensive use of real aluminum decors. Peugeot's version of flat-bottomed steering wheel is not as tasteful as Audi's. Its seats are not as classy too. One thing it does match the Audi: the tiny rear seats are purely cosmetic. Head and legroom are barely enough for small kids. For this reason, the Peugeot coupe will be compared with 2-seaters like BMW Z4, Mercedes SLK and Nissan 370Z, although its closest rival is still Audi TT.
Price-wise, the Peugeot coupe undercuts all the above rivals by considerable margin. Its price starts from 20,000 and tops out at 25,000, which is about the entry point of Audi TT. Mazda MX-5 is the only cheaper alternative (at sub-20,000), but it is no where as substantial or as visually attractive. Peugeot found a sweet spot in the marketplace.
However, the keen price comes from the simplicity of its mechanicals. This coupe is built on the 308 platform. In other words, it is front-wheel drive and rides on cheap suspensions consisting of MacPherson struts up front and semi-independent torsion-beam at the rear. To save the game, Peugeot lowers its ride height by 20mm, widens its front and rear tracks by 54mm and 72mm respectively. Its center of gravity is 40mm lower than the sportiest 308 hatchback, thanks to the lowered roof, ride height and aluminum roof rails. Besides, the top 200hp model comes with an additional tower brace reinforcing the front suspensions. Springs and dampers are considerably stiffer than the regular 308's. Moreover, to improve steering feel, the electric power steering is reverted to hydraulic one.
The TT-style body profile is likely to generate a great deal of aerodynamic lift at speed, so Peugeot equipped it with a pop-up rear spoiler, which adjusts its height between 2 positions depending on speed.
Engine range also comes from the modest 308. You have the choice of 3 engines: 156hp 1.6 DI turbo, 200hp high-pressure version of the same engine and 163hp 2.0HDi turbo diesel. Even the 200hp engine cannot propel the car much beyond 144 mph and 0-60 mph under 7.2 seconds. Such performance is definitely not as wild as its looks suggested. In isolation, the BMW-sourced engine (with Peugeot's specific tuning) is not bad. It displaces only 1.6 liters yet produces 200 horsepower. Its maximum torque of 188 lb-ft can be lifted momentarily to 203 lb-ft, thanks to overboost, to aid overtaking. It delivers power smoothly and linearly. Its exhaust sounds quite sporty once you rev it to the upper half of rev range. However, owing to the 1300 kilograms it needs to haul, the 1.6 turbo engine feels exactly as it is - a small engine squeezed to work on a large car. Floor down the throttle, acceleration feels soft initially. It takes a moment to gather rev and get into its sweet zone, which spans from 2200 to 6000 rpm, by then it feels reasonably punchy. You will enjoy the shift quality and the closely stacked ratios of the 6-speed manual box. Nevertheless, the powertrain combination is no match with Audi's 2.0TFSI engine and DSG gearbox.
Because of its mechanical basis, the RCZ drives more like a hot hatch than a thoroughbred sports car. Its handling is neat, with plenty of grip from its 235/45 tires, well-contained body roll and precise steering. Its balance is quite neutral thanks to the endless front-end grip. However, it plays neither power slide like a rear-drive sports car nor lift-off oversteer like the old 205GTi. All it does is grip, grip and grip hard on the tarmac. Ultimately, when it runs out of grip, it runs into terminal understeer like most hot hatches the nose-heavy diesel car is especially obvious. Some may prefer such a precise and secured driving manner, but driving enthusiasts will find it quite boring to drive. Regarding ride quality, the RCZ feels firmly suspended. It's by no means uncomfortable, but on rough surfaces the wide tires and semi-independent suspension do transmit more shocks and noise into the cabin than Audi TT, contributing to a less sophisticated impression.
We wish the RCZ could have had more firepower and more driver interaction in its handling. However, this would have required to develop a dedicated platform for the car, which means the keen prices infeasible. By keeping its price in the range between 20,000 and 25,000, the RCZ is safe from competition. It may lure many buyers who put style over driving excitement. Peugeot believes it could find 15,000 such customers every year. Production is to be subcontracted to Magna-Steyr in Austria. Peugeot had a good time of outsourcing production of 206CC, which was a runaway success. RCZ might be the same.
#2
Posted 24 March 2010 - 10:38 AM
Lion-e-motion
  • Lion-e-motion
    2nd Gear
    Author Image
    114
It should be available in Singapore before 2nd Q 2011.
#3
Posted 30 March 2010 - 11:52 AM
Eugn86
  • Premium member
    Eugn86
    4th Gear
    Author Image
    687
What a long wait... but...
#4
Posted 30 March 2010 - 03:17 PM
Manu27
  • Manu27
    Clutched
    Author Image
    31
nice one..
#5
Posted 06 May 2010 - 09:35 PM
Xavina
  • Xavina
    2nd Gear
    Author Image
    153
This is one cool peugeot....All peugeot should be like this ;)
#6
Posted 06 May 2010 - 11:57 PM
Xaser
  • Xaser
    Clutched
    Author Image
    27
such a beautiful car
#7
Posted 07 May 2010 - 01:24 PM
Hwt
  • Hwt
    3rd Gear
    Author Image
    307
A Malaysian-made right-hand-drive Peugeot RCZ.......?
http://yuleehong.com...or-2010-launch/
#8
Posted 07 May 2010 - 01:53 PM
Kelfinity
  • Premium member
    Kelfinity
    4th Gear
    Author Image
    741
#9
Posted 15 February 2011 - 03:45 PM
Limxiaoming
  • Premium member
    Limxiaoming
    4th Gear
    Author Image
    784
Saw 1 drove past me this morning with a temporary number plate.
Really nice! How come no reviews on this car. At 160k, should be a fair buy for such presence on road.
#10
Posted 15 February 2011 - 03:57 PM
Tohto
  • Premium member
    Tohto
    2Fast2Furious
    Author Image
    70,896
The latest Torque mag had a review.
#11
Posted 15 February 2011 - 04:03 PM
Karu
  • Premium member
    Karu
    6th Gear
    Author Image
    4,918
Very nice. But 0-100 in 9secs isn't exactly fast for its look...
Edited by Karu, 15 February 2011 - 04:03 PM.
#12
Posted 02 May 2011 - 11:56 AM
Newkidontheblock
  • Premium member
    Newkidontheblock
    2nd Gear
    Author Image
    125
saw a white one that zoomed past me on the PIE slightly over midnight...
damn this car is nice !
if i had more money i'll go for this car.. i wonder how the resale value is like...
#13
Posted 02 May 2011 - 11:59 AM
Aeromania
  • Aeromania
    5th Gear
    Author Image
    1,387
was expecting a 3 litre v6 but in the end 1.6 in line 4.... but I'll give it for the look. it's really good looking.
#14
Posted 02 May 2011 - 02:23 PM
Lammy84
  • Lammy84
    4th Gear
    Author Image
    592
peugeot, had 1 before, will never own another.
All show and no substance, i rather get an alfa spyder 2nd hand at that price.
screw peugeots.
#15
Posted 07 June 2011 - 04:17 PM
Initialp
  • Initialp
    1st Gear
    Author Image
    53
The RCZ uses the Prince engine developed by PSA & BMW. The auto box is 156HP and the manual is 200HP. The manual is alomost $10k more than the auto. Both are avialable in Singapore. Should be around $170k+-. Build quality high. Good value for money and drives well too.
#16
Posted 07 June 2011 - 04:28 PM
Tom_kkh
  • Tom_kkh
    6th Gear
    Author Image
    3,885
saw a black 1 last month at IMM
#17
Posted 07 June 2011 - 04:29 PM
Mockngbrd
  • Mockngbrd
    2Fast2Furious
    Author Image
    49,426
rubbish pricing
Garage36.com
#18
Posted 07 June 2011 - 04:53 PM
Celicar
  • Celicar
    NOS-ed
    Author Image
    11,596
真的吗?
#19
Posted 14 June 2011 - 01:14 PM
Andycheng9110
went to have a look at autofrance over the weekend and interior is impressive. but unfortunately the performance is not as superb compare to the looks. Well the Peugeot 508 attracted me more :)
#20
Posted 14 June 2011 - 01:43 PM
Fourth
  • Fourth
    5th Gear
    Author Image
    1,174
508 looks great from the TV advert. RCZ is also not bad looking, saw 1-2 on the road.
Back to Conti Talk  ·  Car Brands Top Reply to this topic
Quick Reply
Tags: Peugeot
