Drive 1st Gear April 12, 2010 Share April 12, 2010 Hi Anyone or anywhere can it be done? Or anywhere sell the OEM type? ↡ Advertisement Link to post Share on other sites More sharing options...
Esppppp 1st Gear April 12, 2010 Share April 12, 2010 How about getting something like this http://www.mycarforum.com/index.php?autoco...mp;product=1348 Link to post Share on other sites More sharing options...
Higgsboson Clutched April 12, 2010 Share April 12, 2010 try before. it has not enough wattage to support regular notebooks. try to get those car adapters from the notebook suppliers. Link to post Share on other sites More sharing options...
Esppppp 1st Gear April 12, 2010 Share April 12, 2010 ok ok... Thanks. I have not used it personally before. Appreciate your views. Link to post Share on other sites More sharing options...
Joajas Neutral Newbie April 12, 2010 Share April 12, 2010 get a 1000w inverter. that should solve your problem. Link to post Share on other sites More sharing options...
Theone2010 Neutral Newbie April 12, 2010 Share April 12, 2010 (edited) Hi Anyone or anywhere can it be done? Or anywhere sell the OEM type? !2 DC to 215-230 VAC invertor, can plug into cigarette port. Those computer shop got sell, price about $40. need to check wattage got power or not. Edited April 12, 2010 by Theone2010 Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 12, 2010 Share April 12, 2010 Cigarette lighter socket has a safe output of 10amp x12 volt = 120watt. If you are thinking of higher wattage you need to connect the inverter directly to the battery. Link to post Share on other sites More sharing options...
Ender Hypersonic April 12, 2010 Share April 12, 2010 (edited) I bought from sim lim tower those 12 volts power supply for notebook (no need for convert to AC). think less than $50, can't recall the exact price. It has mutliple heads and volatge selector for various types of notebook. This looks like the one I bought from sim lim. http://cgi.ebay.com.sg/IN-CAR-12v-LAPTOP-C...f#ht_3996wt_939 Edited April 12, 2010 by Ender Link to post Share on other sites More sharing options...
Joajas Neutral Newbie April 12, 2010 Share April 12, 2010 Cigarette lighter socket has a safe output of 10amp x12 volt = 120watt. If you are thinking of higher wattage you need to connect the inverter directly to the battery. ya, should connect direct to battery via a properly rated fuse. Those inverters don't come with cigarette connector, they come with those ring type terminal lugs meant for us to connect direct to battery. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 12, 2010 Share April 12, 2010 (edited) Here is one super slim unit that comes with cigarette lighter male plug. For connecting direct to battery most of them come equipped with lead acid battery crocodile clips. Edited April 12, 2010 by Yeobh Link to post Share on other sites More sharing options...
Drive 1st Gear April 13, 2010 Author Share April 13, 2010 Thanks guys for your replies. My laptop charger says "Input: 100V-240V 0.8A-0.5A 50-60Hz, Output: 16V =2.2A", can the above devices be used? Also found this cheap on epay: http://cgi.ebay.com.sg/Universal-Car-Lapto...=item35a86ee21a, can this be used? Link to post Share on other sites More sharing options...
Joajas Neutral Newbie April 13, 2010 Share April 13, 2010 Thanks guys for your replies. My laptop charger says "Input: 100V-240V 0.8A-0.5A 50-60Hz, Output: 16V =2.2A", can the above devices be used? Also found this cheap on epay: http://cgi.ebay.com.sg/Universal-Car-Lapto...=item35a86ee21a, can this be used? yeobh's device converts 12VDC to ~240VAC, ~240VAC is what you have in your home all socket. So you just plug your 3pin plug into the device and use as per normal. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 13, 2010 Share April 13, 2010 Thats right. The unit can take both 220volt 1ph 50hz three pin and two pin plug. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
New car discount/price/promo
