Hamburger Hypersonic February 2, 2013 Share February 2, 2013 Jus went down to check. My radiator fan came off!!! Got dislodged from the fitting. Thats y not turning! My aircon moving, coolant level ok. Will any workshop b able to fix the fan? I wanted to try...but can seem to fit my hand inside. need to take out the whole bracket casing to do it properly. its actually not difficult to take it out. ↡ Advertisement Link to post Share on other sites More sharing options...
Shorty Turbocharged February 2, 2013 Share February 2, 2013 I think better to let shop do it. Going to motec later n see if they can fix. Link to post Share on other sites More sharing options...
13177 Supersonic February 2, 2013 Share February 2, 2013 Any recommeded workshop that fix air-con problem? Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 3, 2013 Share February 3, 2013 Having this prob now. When idling or caught in jam, my engine will heat up n aircon not cold. Normally temp gaug will b 3 bars out of 7. But when this happen, will go up to 4 bars. The probs mentioned in this thread is only abt aircon...but mine affect my engine temp also. Any advise? Should i add water to my radiator? Chk yr radiator n ac fans. Likely one is not working. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 3, 2013 Share February 3, 2013 Jus went down to check. My radiator fan came off!!! Got dislodged from the fitting. Thats y not turning! My aircon moving, coolant level ok. Will any workshop b able to fix the fan? I wanted to try...but can seem to fit my hand inside. If u good at diy u can try to fix yrself. Just make sure ignition switch is off all e way. Otherwise just get a ws to do fr u. A few bucks only. Or send to a good ac repair shop just so ty can chk everything fr u. Link to post Share on other sites More sharing options...
Eliter Neutral Newbie February 16, 2013 Share February 16, 2013 The earlier problem it seem similar as mine. Aircon compressor issue. Get it change. Can anyone recommend where to get a recon Aircon compressor for grandis? Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 16, 2013 Share February 16, 2013 The earlier problem it seem similar as mine. Aircon compressor issue. Get it change. Can anyone recommend where to get a recon Aircon compressor for grandis? If woodlands is ok go to Markcool. Look fr foreman Ah Huat. He very good n honest. No cheating nonsense. Ive been using him fr abt 20 yrs already. Just let him check n give u options n quote then u decide. Dun do also he no problem. Link to post Share on other sites More sharing options...
Shanhz 3rd Gear February 16, 2013 Share February 16, 2013 Most work shops will say compressor spoilt and cost will be around $600 plus to replace new ones. I would not be surprise this is how all re-con compressors start sprouting. From my limited experience, why dont u do the following before spending big money. a. Check your air-con clutch. Maybe just need cleaning up. b. Sent your air-con for maintenace. This will diagnose the "strength" of your aircon and drain off old liquid and replace new ones. It works for me both times on my previous car. Yes this worked for me too. Five yr old honda. Link to post Share on other sites More sharing options...
Eliter Neutral Newbie February 17, 2013 Share February 17, 2013 If woodlands is ok go to Markcool. Look fr foreman Ah Huat. He very good n honest. No cheating nonsense. Ive been using him fr abt 20 yrs already. Just let him check n give u options n quote then u decide. Dun do also he no problem. Thkq.. I want to keep it low bcos left slightly more than couple more year I'm gg to chg another toy. Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 18, 2013 Share February 18, 2013 Thkq.. I want to keep it low bcos left slightly more than couple more year I'm gg to chg another toy. Ok good luck in getting yr ac fixed. Link to post Share on other sites More sharing options...
Edmemail 1st Gear February 18, 2013 Share February 18, 2013 best to leave it to the professional to check Link to post Share on other sites More sharing options...
Koktong2000 Neutral Newbie April 2, 2013 Share April 2, 2013 Just done ac refresher at 1st auto . They plug in a machine to the aircon gas inlet (2pt) , than start to vacuum dry ac gas from ac system, took 20min or so . The mech say this will also such out compressor oil. Does the ac refresher also such out compressor oil ? Link to post Share on other sites More sharing options...
Koktong2000 Neutral Newbie April 3, 2013 Share April 3, 2013 Just done ac refresher at 1st auto . They plug in a machine to the aircon gas inlet (2pt) , than start to vacuum dry ac gas from ac system, took 20min or so . The mech say this will also such out compressor oil. Does the ac refresher also such out compressor oil ? Anyone can help , today aircon not cold again Link to post Share on other sites More sharing options...
13177 Supersonic April 3, 2013 Share April 3, 2013 If the workshop already refresh your air-con and top up air-con gas, and after a while air-con still not cold then maybe compressor kaput lo. Link to post Share on other sites More sharing options...
Donut Supercharged April 3, 2013 Share April 3, 2013 Just done ac refresher at 1st auto . They plug in a machine to the aircon gas inlet (2pt) , than start to vacuum dry ac gas from ac system, took 20min or so . The mech say this will also such out compressor oil. Does the ac refresher also such out compressor oil ? I also did the same ac refresher at 1st auto recently. If your problem still persistent, then most likely your compressor or coil up lorry liao. Go back to 1st auto or other reputable ws Link to post Share on other sites More sharing options...
Koktong2000 Neutral Newbie April 4, 2013 Share April 4, 2013 Today cold again. Question is the ac refresher really such out compressor oil? Becos the mech only put in 2pt at ac ,nv touch compressor at all . So wondering the mech got Smoke me anot. Any expert can advise? Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 4, 2013 Share April 4, 2013 dont pin point so quickly its the compressor. Firstly need to check the freon gas pressure. If there is no pressure, a major leak has occurred along the line. If the gas pressure is still present, then its the compressor konk out. Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 4, 2013 Share April 4, 2013 Today cold again. Question is the ac refresher really such out compressor oil? Becos the mech only put in 2pt at ac ,nv touch compressor at all . So wondering the mech got Smoke me anot. Any expert can advise? fresh compressor oil is introduced along with the filling of freon gas. do not think you simply pour into the compressor... ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
All new 2021 Kia Carnival / Sedona GUV
Car air-con
Car air-con
Autobahn Motors Building is damn cool!
