Y2k_tay Neutral Newbie May 6, 2011 Share May 6, 2011 Lets give him the benefit of doubt, he maybe referring to combustion gases leaking into the cooling system via the cylinder head gasket. We must not assume that all mechanics have the opportunity to undergo formal or approved training programms. Sorry for bringing up the OT. I am driving a pre-fl nissan sunny n16. My car has this symptom and I suspect my car's cylinder head gasket is leaking gases. Because every morning before I start the car, I noticed the coolant reservoir will overflow while the coolant in radiator remained low. And while opening the rad cap, I can hear the air/gas escaping. I tried siphoning the excess and reused it to top-up the radiator. It will go back to the same overflow problem after a few days i.e. I'll siphone the coolant down to the minimum level, not max, while the coolant in the radiator is top-up to the neck, but after a few days it went back to the max level of the reserved reservoir. My temp gauge does not shows overheating. Is it head gasket problem or thermostats or other problem? Anyone has encountered this problem before and how much is the damage? Any reliable and reputable workshop to recommend? I'm asking around so that won't kenna ↡ Advertisement Link to post Share on other sites More sharing options...
Acerchan2002 Clutched May 6, 2011 Share May 6, 2011 Put ur hand into the radiator cooler, den u will automatically know why there is bubble. Link to post Share on other sites More sharing options...
Ithunk 1st Gear May 6, 2011 Share May 6, 2011 Hi all recently i was testing the integrity of my fl n16 sunny's cooling system. Wat i did was open the rad cap after park overnight. Noted water slightly below the lower brim of rad. Start engine & idle. During initial idle the water level started rising till overflow the brim however when its hot ard 1/2 on the temp gauge & fan started running the water level started going down & bubbles started forming on the water surface. When fan stop the water level rises again & cycle repeats. Is this normal? no problem even with the previous EG there were some bubbles Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear May 6, 2011 Share May 6, 2011 To think that he troubleshoots other peoples car! It just gives me the shudders. http://dennischiang.blogspot.com/ I am scared of this type Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear May 6, 2011 Share May 6, 2011 Put ur hand into the radiator cooler, den u will automatically know why there is bubble. Mercy-mercy. Do not be like PAP. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged May 6, 2011 Share May 6, 2011 Put ur hand into the radiator cooler, den u will automatically know why there is bubble. he wont know unless u tell him to put his hand into the radiator cooler after driving his car for at least 1/2 an hour... ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator slight crack
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
Radiator tank leaks
Radiator tank leaks
Plastic weld
Plastic weld
How to protect your radiator from debris and damages
Radiator change
Radiator change
Radiator Repair - Any good lobang/contact nos?
