Wish1719 1st Gear May 4, 2010 Share May 4, 2010 Hi to all ICE expertise, Any Good recommandation for a 4 channel amplifier? Budget around $1k plus.... separately if can recommand speakers and sub-woofer, even better.... kam sia! ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear May 4, 2010 Share May 4, 2010 Hi to all ICE expertise, Any Good recommandation for a 4 channel amplifier? Budget around $1k plus.... separately if can recommand speakers and sub-woofer, even better.... kam sia! Go to the weekly ice meetup would be good. Can listen to different setups and people's review and recommendations. Then go sgcaraudio and/or sgsoundsystems to poison yourself further. Then after that, decide what you want. Link to post Share on other sites More sharing options...
Wish1719 1st Gear May 4, 2010 Author Share May 4, 2010 Go to the weekly ice meetup would be good. Can listen to different setups and people's review and recommendations. Then go sgcaraudio and/or sgsoundsystems to poison yourself further. Then after that, decide what you want. Boh Eng leh.....Blue2 also got ask me go.... here is short cut mah.... Link to post Share on other sites More sharing options...
Leclair 3rd Gear May 4, 2010 Share May 4, 2010 there are so many models out there which can satisfy your budget, but many bros will ask you : " what do you want?" What do you like to listen to? what kind of set up are you going for? 2 way/ 3 way/ passive/active? do you have a pair of golden ears to discern the differences between setups? MY advice as someone who went through this as well: read more + talk to pple more+ go workshop ask questions more + wait a bit more then decide what you want. Basic setups can be from few hundred to few tens of thousands. Do you want to go workshop and spend hours everytime to install new things after you find that you cannot take the awful sound of your last set up which was done/bought hastily? Read up here - some info are quite good then proceed to sgsounds - more detailed info are there and the bros there are well-equipped to advice(poison) you after you have read through the archive and still have questions. my 1 ct worth Link to post Share on other sites More sharing options...
Yuan 6th Gear May 4, 2010 Share May 4, 2010 Boh Eng leh.....Blue2 also got ask me go.... here is short cut mah.... Some things cannot short cut and have to be patient. This is one of it. Take your time to go around listening to it. You also wanna change speakers? Add sub? Link to post Share on other sites More sharing options...
Dunno Neutral Newbie May 4, 2010 Share May 4, 2010 Different amps, different speakers and different cables give different sound. At the same time, if you have a $1k+ 4ch amp, what speakers and HU are you using? Every equipment has to complement each other, else there will be a bottleneck somewhere. It will be like driving a bus but fixing Pirelli Zero tyres on them....just a waste of the tyres. Best is to join meetups. Try sgcaraudio.net. Link to post Share on other sites More sharing options...
Dunno Neutral Newbie May 4, 2010 Share May 4, 2010 http://www.mycarforum.com/index.php?showtopic=2651298 Link to post Share on other sites More sharing options...
Yuan 6th Gear May 4, 2010 Share May 4, 2010 Different amps, different speakers and different cables give different sound. At the same time, if you have a $1k+ 4ch amp, what speakers and HU are you using? Every equipment has to complement each other, else there will be a bottleneck somewhere. It will be like driving a bus but fixing Pirelli Zero tyres on them....just a waste of the tyres. Best is to join meetups. Try sgcaraudio.net. Er....it is TS asking....Not me.... Link to post Share on other sites More sharing options...
Wish1719 1st Gear May 4, 2010 Author Share May 4, 2010 there are so many models out there which can satisfy your budget, but many bros will ask you : " what do you want?" What do you like to listen to? ans: clarity... what kind of set up are you going for? 2 way/ 3 way/ passive/active? ans: Active do you have a pair of golden ears to discern the differences between setups? ans: No, but just good vocal and bass thanks bro, appreciate it... Link to post Share on other sites More sharing options...
Wish1719 1st Gear May 4, 2010 Author Share May 4, 2010 Some things cannot short cut and have to be patient. This is one of it. Take your time to go around listening to it. You also wanna change speakers? Add sub? thanks bro....may find some time go down , understand most of the time they meet at AMK... Link to post Share on other sites More sharing options...
Wish1719 1st Gear May 4, 2010 Author Share May 4, 2010 Different amps, different speakers and different cables give different sound. At the same time, if you have a $1k+ 4ch amp, what speakers and HU are you using? Every equipment has to complement each other, else there will be a bottleneck somewhere. It will be like driving a bus but fixing Pirelli Zero tyres on them....just a waste of the tyres. Best is to join meetups. Try sgcaraudio.net. Kam sia bro, you go meet up as well? Link to post Share on other sites More sharing options...
Yuan 6th Gear May 4, 2010 Share May 4, 2010 thanks bro....may find some time go down , understand most of the time they meet at AMK... Everybody's preference for music is subjective and different. One man's meat may be another man's poison. What is good to hear by one person may not suit another person's hearing though you can classify the type of music you like to hear, for example, jazz, pop, techno, etc. Link to post Share on other sites More sharing options...
Dunno Neutral Newbie May 4, 2010 Share May 4, 2010 Er....it is TS asking....Not me.... I just clicked on the last reply button do default to your last post lor Link to post Share on other sites More sharing options...
Dunno Neutral Newbie May 4, 2010 Share May 4, 2010 Kam sia bro, you go meet up as well? Yup, mostly on Wed and sometimes also Fri if my OC allows Link to post Share on other sites More sharing options...
Han88 Neutral Newbie June 5, 2010 Share June 5, 2010 Hi bro, I have below items to sell away. Obviously, these are not high end brand. However, sound quality produced are clear and acceptable. - Performa PF-007 Cross Over Pre-amp (S$50) - PlanetAudio ZR200.2 200WATT 2 Channel Power Amplifier (S$100) - PlanetAudio ZR200.4 400WaTT 4 Channel Power Amplifier (S$100) -. PlanetAudio VORTEX 10" sub-woofer comes with box (S$50) - BOSS Audio System Capacitor (S$50) Price nego if you buy all. All are good condition and already out from car. ***** DO NOT PM ***** Please contact me at 91852099 for fast deal. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Good knee surgeon to rec?
Recommend me a good handheld vacuum
What is your favourite radio channel?
Why 'quiet quitting' could be good for you and your employer
