  • Search this thread
  • Reply to this topic
88 replies to this topic | 150 praises
#1
Posted 06 June 2010 - 08:36 PM
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
Hi peeps,
Earlier when I started my engine and wanted to move off, the engine died. After subsequent starts I noticed my idle speed is lower than usual. The car died a number of times before I managed to drive home.
Any idea what is the problem of my car? My ride is a Lancer GLX and is 4 yrs old now. Tomorrow I'll send in to C&C. Hopefully I do not have to burn my pockets dead.gif
Thanks!!
#2
Posted 06 June 2010 - 08:38 PM
Ferraricalifornia
  • Ferraricalifornia
    Author Image
    9,382
sounds like your alternator is weak....
or could be a battery problem too....
The Married Men 91.3FM
#3
Posted 06 June 2010 - 08:57 PM
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
Hmm not so high chance it's the battery. I changed it last year.
What does alternator do? How's the damage for a replacement?
#4
Posted 06 June 2010 - 09:00 PM
Ferraricalifornia
  • Ferraricalifornia
    Author Image
    9,382
don't ask me what the alternator does to the car, i'm not so profound in car electricals and mechanics yet....
do google it if you wanna know more about it,
however, i think it has something to do with the driving of your car- converting DC to AC or some sorts....
it should be some mechanical wear and tear....
shouldn't be too costly to replace....
#5
Posted 06 June 2010 - 09:02 PM
Ferraricalifornia
  • Ferraricalifornia
    Author Image
    9,382
well, i've just googled it,
and it says
"to charge the battery and to power a car's electric system when its engine is running"....
if it's not working properly, the engine of the car wouldn't be running....
#6
Posted 06 June 2010 - 09:16 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    50,187
biggrin.gif Pls dun use words like car died or engine died. They are non living things btw. The correct use of words should be engine stalled.
There could be many reasons due to the engine stalling. It could range from things like the fuel system eg. the fuel pump failing to the clogged fuel injectors. Or it could be ignition problem like spark plug needs replacement. Or the throttle body assembly needs cleaning. Or the head gasket is leaking small amount of coolant into the combustion chambers, the coolant cannot be compressed and ignited hence it will cause the engine to stall.
Can be any of the above. If you are lucky your mechanic might find the cause quickly. If not, your car might have to spend some time in the workshop.
#7
Posted 06 June 2010 - 09:27 PM
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
You listed out so many reasons. Sounds so complex leh.
Probably I'll print out what you listed and pass it to the mechanic laugh.gif
#8
Posted 06 June 2010 - 09:45 PM
Maroon5
  • Maroon5
    Supercharged
    Author Image
    7,318
techincally if u cld stil drive back, its unlikely the alternator...4 yr old lancer hmm...any mods? unichip?
anyw im driving same car bro...there are better wkshops out there hehe... tongue.gif
Paul Scholes. He scores goals.
#9
Posted 06 June 2010 - 09:57 PM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,392
1st thing u sud do is check & clean your throttle body. Its prob dirty.
Also might b your fuel filter is dirty/clogged causing too little fuel reaching your cylinders.
Throttle body u can DIY so u dont get chopped by CnC.
If all else fails then see your mechanic. If u got a good outside workshop, better cos CnC charges r knife.gif .
#10
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
Stock engine.. but i drove back with the engine stalling a few times. I had to rev to maintain the engine.
You got a reputable workshop to recommend?
All along I have been servicing with C&C and since the time is up for my servicing, and now my car got problem, might as well I go back let them see.
#11
Posted 07 June 2010 - 01:00 AM
Itsec
  • Itsec
    5th Gear
    Author Image
    2,014
check sensors and TB ...
I'm a nobody, but try to convey my message across uniquely :)
#12
Posted 07 June 2010 - 01:16 AM
Mike80
  • Mike80
    1st Gear
    Author Image
    59
Bro, ur ride is manual or auto?
#13
Posted 07 June 2010 - 01:21 AM
Tsr729
  • Premium member
    Tsr729
    4th Gear
    Author Image
    587
if your engine jerk and jerk before stalling then probably fuel filter clogged.
#14
Posted 07 June 2010 - 11:09 PM
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
It's a manual bro.
#15
Posted 07 June 2010 - 11:14 PM
Shanhz
  • Premium member
    Shanhz
    5th Gear
    Author Image
    1,137
Hi peeps,
Thanks!!
duno if your batch is still plagued with throttle body problems..the earlier models did. if it is, it's a $700 repair i think
#16
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
No it didn't jerk before stalling. It just lose the rpm and stalls.
Btw I went to C&C and was told that my aircon and air filter is very dirty. They cleaned it for me and told me they clean the sensor as well (not sure what) and told me to monitor for the coming days.
Now it seems ok. Could it be due to the filters that may have caused it? confused.gif
#17
Posted 08 June 2010 - 12:53 AM
Dscheng
  • Premium member
    Dscheng
    5th Gear
    Author Image
    1,338
Alamak C&C hor.. Aircon fliter dirty will not cause engine to stall lo. A dirty air fliter will cause. I think your throttle body dirty la. Plus they clean the sensor for u.. U continue monitor lo. Just curious how much C&C charge u?
** Riding passion
Car
2007-Civic EG, 2009-Lancer EX, 2012-JDM WRX,
2012-Civic FD, 2014-Lancer CS3M, 2015- RN6-Z,
2018 - GB7.
Bike
2000 - Hornet 125R, 2002 - CBR400R-L, 2007- Super 4 Spec II
2018 - Finally, i am back in riding, ZX10R.
#18
Posted 08 June 2010 - 04:20 PM
MLS
  • THREAD STARTER
  • MLS
    3rd Gear
    Author Image
    375
They told me aircon filter and air filter both dirty, ready to change. They quote me $87 and $60 respectively knife.gif
I called another workshop and was quoted $30 each. Don't understand how come the price diff so huge. Anyway I bidded C&C goodbye wave.gif
After work going to collect ride cause I just sent in this morning.
#19
Posted 08 June 2010 - 05:15 PM
Acevin
  • Acevin
    3rd Gear
    Author Image
    493
If ur rpm drop so low till it stalls, and if I'm not wrong, cld b TB / sensors dirty.. can go get it clean first to see how as its inexp to do it.
Worst case can b ur oxygen sensor gone case..
#20
Posted 08 June 2010 - 11:21 PM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,392
U still dare to go C n C???? Wah u damm loaded ah?
AC filter = $87. I go Markcool he charge me only $20. I now buy myself & DIY only $15.
Air filter I DIY cost only $20 for ORIGINAL air filter. OEM about $15 only.
Back to General Car Discussion  ·  Cars Top Reply to this topic
SgCarMart Quotz
Quick Reply
Tags: Advise, needed, ride
