Xefera 6th Gear July 30, 2010 Share July 30, 2010 yes, i feel the same way also. even though it is raining the next day morning, the interior still feels warm. this is esp. more evident if the interior is leather wrapped and black in color ↡ Advertisement Link to post Share on other sites More sharing options...
Lamemonster Clutched July 30, 2010 Share July 30, 2010 You know that hot gush of air when you open your car door? How do we reduce the temp when the car is parked in the open? Do we leave gaps in the windows? You can do that if you have window visors installed I guess. Is there any solar powered device in the market which can be installed to provide ventilation and does it help? another good way is to install "sound proof" mat on your car roof.... ive done mine for about $120. it cannot totally reduced the heat 100% but can lower the heat to about 50% which is ok for me ... 2cents Link to post Share on other sites More sharing options...
5936 1st Gear July 30, 2010 Share July 30, 2010 (edited) Putting another pressurised spray in car under hot sun. This should be a no no.- If want to be hero, no afraid of exploding canister, there is also another problem: It may be a daily ritual, so running cost to buy the spray cans. I tried many years ago, it did not work for me. Basically, it is vaporising water/alcohol mist to soak up the heat. For me, sun shade on wind screen is enough. Open doors to ventilate for a while, drive off with windows wind down, and fan at full blast.. This for few minutes before turning on air con. if plan to park for whole day, I will not leave small gap-- insects will fly or crawl in. Edited July 30, 2010 by 5936 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 30, 2010 Share July 30, 2010 Thanks! see the comments save the $ http://www.amazon.com/Auto-Vent-Car-Ventil...s/dp/B000ADJ5M6 Link to post Share on other sites More sharing options...
5936 1st Gear July 31, 2010 Share July 31, 2010 I got one of this. Installed once but removed after one day. Very noisy. Not from the fan, but from wind entering through the seals. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear July 31, 2010 Share July 31, 2010 I got one of this. Installed once but removed after one day. Very noisy. Not from the fan, but from wind entering through the seals. i thought u onlt install when parking, u had it on full time? Link to post Share on other sites More sharing options...
Aeromania 1st Gear July 31, 2010 Share July 31, 2010 my car has no visor. And if die die bo bian have to park sunny spot i will leave a small opening on all 4 windows. this will create ventilation inside the car. It will be alot better than u close it totally. Link to post Share on other sites More sharing options...
5936 1st Gear July 31, 2010 Share July 31, 2010 It's meant for permanent. Came with weatherstripe rubber but wind still enter. Link to post Share on other sites More sharing options...
5936 1st Gear August 3, 2010 Share August 3, 2010 How strong is your window visor? Easy to break in by pulling the visors off. Use a stick to unlock door. Pee remember this when parking with windows partially down Link to post Share on other sites More sharing options...
Itsec 2nd Gear August 3, 2010 Share August 3, 2010 (edited) y not remote start?? Edited August 3, 2010 by Itsec Link to post Share on other sites More sharing options...
Soniakwok Neutral Newbie September 5, 2010 Share September 5, 2010 Yes, using those car alarm remote control which can also start up the engine and aircon and cool down the car 10-15mins before you jump in your car. My friend has one, loves sitting in his car. Thinking of installing one for my car too... Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 5, 2010 Share September 5, 2010 to reduce the heat inside your car, the secret is to use something to cover the dashboard, because it is the dashboard that gets heated up the most when under sun for long, dont believe, touch the dashboard and it is hot as a piece of fried chicken. by doing so, you greatly reduce the heat build up. I agree on this point. Just wondering where to get those fold-able reflector boards in for dashboard in Singapore. Link to post Share on other sites More sharing options...
Methamoss Neutral Newbie September 5, 2010 Share September 5, 2010 Do both. install visors, leave a gap and install good window film Link to post Share on other sites More sharing options...
Famwc Neutral Newbie September 5, 2010 Share September 5, 2010 actually i dun think those good window film really helps if u going to park for long duration under the sun, it's good for those who park sheltered and drive out their car into the sun. The good film will propel the heat better. But if park long duration under direct sun, the heat will still get through and will sort of create a greenhouse effect and i think the film will also make the heat hard to escape out bah... Link to post Share on other sites More sharing options...
Famwc Neutral Newbie September 5, 2010 Share September 5, 2010 I agree on this point. Just wondering where to get those fold-able reflector boards in for dashboard in Singapore. u can get those reflector at autobacs, think i have seen them at Esso petrol kioks also. Link to post Share on other sites More sharing options...
Famwc Neutral Newbie September 5, 2010 Share September 5, 2010 my car has no visor. And if die die bo bian have to park sunny spot i will leave a small opening on all 4 windows. this will create ventilation inside the car. It will be alot better than u close it totally. It's better to get a visor if u do tat often. u wun wanna experience forgetting bout it and it rains... btw, make sure u dun leave the window open when parked at those forested area, u might have unwanted pests getting into yr vehicle... Link to post Share on other sites More sharing options...
E-Jazz Neutral Newbie September 6, 2010 Share September 6, 2010 u can get those reflector at autobacs, think i have seen them at Esso petrol kioks also. Hi Famwc, thanks =) Link to post Share on other sites More sharing options...
Si4dr 5th Gear September 6, 2010 Share September 6, 2010 (edited) I had a cheapo thermometer in car which max reading 70DEG C, always over shoot the max line if park under hot sun for more than 3hrs.... (solar film installed). So I install visor now and leave a gap on window. It did cool down a bit, I think 5-10DEG(better than none) Edited September 6, 2010 by Si4dr ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
