Goodspeed Clutched August 10, 2010 Share August 10, 2010 Hi to all, I have recently picked up a Porter Cable 7424XP and some LC polishing pads. Enjoying every minute with these. However how do you all clean your pads? I understand that some use a bucket of soap and sort of spin them clean. Can i instead use washing detergent to clean? Hand wash ? When then need to change pad? ↡ Advertisement Link to post Share on other sites More sharing options...
Optivax 1st Gear August 10, 2010 Share August 10, 2010 (edited) This is what I normally do.. Soak in warm water with detergent powder..leave it overnight..the next day..I will put detergent powder on surface..use either hand or a soft brush to rub off the polishes.. As for how long you can use the pads depends on the frequency u use...i replace my wool pads after 1 or 2 usage..cutting pad until it dun really cut and can see it starts to create fine hairlines..finishing pads will last you longer.. Edited August 10, 2010 by Optivax Link to post Share on other sites More sharing options...
Goodspeed Clutched August 11, 2010 Author Share August 11, 2010 Thanks for the info Link to post Share on other sites More sharing options...
Krismas Neutral Newbie August 19, 2010 Share August 19, 2010 Hi to all, I have recently picked up a Porter Cable 7424XP and some LC polishing pads. Enjoying every minute with these. However how do you all clean your pads? I understand that some use a bucket of soap and sort of spin them clean. Can i instead use washing detergent to clean? Hand wash ? When then need to change pad? Which LC pads do you have? The CCS or the Flat? Anyway, about cleaning the pads, it all depends on what polish you use. Basically, there are two type of polishes, one is water based and the other is oil based. For water based polishes, it's very easy to clean. Spray some diluted APC or soapy water would do. For oil based polishes or polish that contained oil/silicon, you'd need something that can dissolve oil. For this, you can use diluted dishwashing liquid. On both occasions, what I do is the followings: 1. Spray the APC or detergent onto the face of the pad 2. Let it soak for a few minutes (I prefer around 1/2 hr) 3. Work it in with your thumb 4. Rinse and squeeze under running water to remove the polish and detergent residue. 5. With the CCS DA pads you can press/wring dry. 6. Attach the pads to the DA and spin dry on speed 5 or 6. 7. Leave to air dry (do not dry directly under the sun) Just a side note, you might need to use the dishwashing liquid and do it a few times if you're using the pad to apply liquid sealant as they are the most stubborn to clean. So far I only found one thing that can effectively remove liquid sealant from the pads - Dawn Power Dissolver. And I do find that Optimum Power Clean is the best cleaner for the pads. Best of regards. Link to post Share on other sites More sharing options...
Goodspeed Clutched August 20, 2010 Author Share August 20, 2010 Which LC pads do you have? The CCS or the Flat? Anyway, about cleaning the pads, it all depends on what polish you use. Basically, there are two type of polishes, one is water based and the other is oil based. For water based polishes, it's very easy to clean. Spray some diluted APC or soapy water would do. For oil based polishes or polish that contained oil/silicon, you'd need something that can dissolve oil. For this, you can use diluted dishwashing liquid. On both occasions, what I do is the followings: 1. Spray the APC or detergent onto the face of the pad 2. Let it soak for a few minutes (I prefer around 1/2 hr) 3. Work it in with your thumb 4. Rinse and squeeze under running water to remove the polish and detergent residue. 5. With the CCS DA pads you can press/wring dry. 6. Attach the pads to the DA and spin dry on speed 5 or 6. 7. Leave to air dry (do not dry directly under the sun) Just a side note, you might need to use the dishwashing liquid and do it a few times if you're using the pad to apply liquid sealant as they are the most stubborn to clean. So far I only found one thing that can effectively remove liquid sealant from the pads - Dawn Power Dissolver. And I do find that Optimum Power Clean is the best cleaner for the pads. Best of regards. Hi Bro... I am using the LC flat type I am using orange pad with Meguiar Ultimate compound follow by white pad with Mazerna Super finish. Are they oil or water base? Link to post Share on other sites More sharing options...
DonNuTs 1st Gear August 20, 2010 Share August 20, 2010 BTW where do u all get ur pads ? Link to post Share on other sites More sharing options...
Krismas Neutral Newbie August 20, 2010 Share August 20, 2010 Hi Bro... I am using the LC flat type I am using orange pad with Meguiar Ultimate compound follow by white pad with Mazerna Super finish. Are they oil or water base? Meg's UC is water based so cleaning it would be easy. Did you mean Menz Power Finish 106FA, grayish in color? If that's so then it's polishing oil is a bit harder to wash off. You'd need a degreaser to effectively remove that. Something like Optimum Power Clean, Meg's Super Degreaser, DG Ultimate Orange or the like. If not, dishwashing liquid would do but make sure you rinse very well. Regards. Link to post Share on other sites More sharing options...
Goodspeed Clutched August 21, 2010 Author Share August 21, 2010 Bro...u are rite. I wash the orange pad coated with UC with ease. However when i wash the white pad with Super finish, quite hard. Link to post Share on other sites More sharing options...
Goodspeed Clutched August 21, 2010 Author Share August 21, 2010 Hi Bro...i get my pads from Shinecars.sg Cheers Link to post Share on other sites More sharing options...
Jasmnprk Neutral Newbie August 21, 2010 Share August 21, 2010 That's a very good advise about washing the car without causing much harm to the polish. This something that people are not quite efficient at following as this something that really matters. You should not be exerting much pressure on the polish as there is chance that it might damage the polish. The soft polishing pad you use should be changed at regular intervals. Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie August 31, 2010 Share August 31, 2010 I use my DIY pad washer. hahaha Either that i will clean with Megs APC and agitate with my fingers or let it soak overnight in CG MF cleaner. But till now i still can seem to get my blue pads totally clean of BF WetDiamond. ZZ Link to post Share on other sites More sharing options...
Krismas Neutral Newbie September 1, 2010 Share September 1, 2010 But till now i still can seem to get my blue pads totally clean of BF WetDiamond. ZZ Have you tried Dawn Power Dissolver? Don't know about BFWD but I've successfully removed zaino, dg, megs nxt, m21 and most other sealants using it. Below is 50/50 of meg's W9006, left side is M21 leftovers after using all sort of APC and degreaser, right is after using DPD. Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie September 2, 2010 Share September 2, 2010 I did use the dish soap to wash my pads before, even after reading online that it will degrade the glue that is holding the pad and the velcro together. One of my 5.5 CCS pad seperated.. :( Link to post Share on other sites More sharing options...
Eddy_theddeus 1st Gear January 17, 2011 Share January 17, 2011 Hi all bro how many type of pad do I need to buy to polish up my car for the pc ? Link to post Share on other sites More sharing options...
Fcuktion Neutral Newbie January 17, 2011 Share January 17, 2011 Depends on what kind of polishes yo have also. The most common one will be LC white polishing pad. But currently my go to one stepper will be the LC Tangerine pad + M205 Link to post Share on other sites More sharing options...
Eddy_theddeus 1st Gear January 19, 2011 Share January 19, 2011 Depends on what kind of polishes yo have also. The most common one will be LC white polishing pad. But currently my go to one stepper will be the LC Tangerine pad + M205 Hi bro me using dg 111n dg105,may I know where can I buy those pad ? Link to post Share on other sites More sharing options...
Davc Neutral Newbie January 19, 2011 Share January 19, 2011 Try those Lake Country pad washer. I wash the pad every 1-2 panels to ensure a very good job. Consider the better result and less time consumed, it is a good product. Link to post Share on other sites More sharing options...
Eddy_theddeus 1st Gear January 19, 2011 Share January 19, 2011 Try those Lake Country pad washer. I wash the pad every 1-2 panels to ensure a very good job. Consider the better result and less time consumed, it is a good product. Where can I buy ? ↡ Advertisement Link to post Share on other sites More sharing options...
New Age Polish -->Land Rover Portfolio
Car carpet cleaning
Car carpet cleaning
New Age Polish --> Honda Portfolio
New Age Polish --> Nissan Portfolio
Roomba - Vacuum Cleaning Robot (VCR)
Interior Cleaning
Interior Cleaning
What's Your Come Home SOP during COVID?
